![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Another example of my cloth simulator...
Two notes:
* it's probably still a bit stiff but to get something better, I'd have
to increase the resolution with the corresponding increase in time :-(
* the simulator doesn't stop when nothing moves, but rather after a
certain number of simulation steps. I think in this case it hadn't
finished which is why the net seems to hang in mid-air on the right...
* Abandon the search for truth, * mailto:ber### [at] iname com
* Settle for a good fantasy. * http://www.enst.fr/~jberger
Download 'net.jpg' (28 KB)
Preview of image 'net.jpg'
![net.jpg](/povray.binaries.images/attachment/%3C3A110A14.E388E108%40tapasmail.net%3E/net.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That is very impressive, what are you doing the simulating with??
Kitty5 WebDesign - http://www.kitty5.com
TEL - +44 (01625) 266358 : FAX +44 (01625) 611913
PGP Public Key
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Two notes:
That looks neat, still a mesh ?
You seem to be right about the unfinished calculation on the right side,
although it's also a difficult case in real world. If i understand things
right it's probably not that problematic to add some kind of 'unfinished
warning' to the program.
If it's an external program, i wonder what kind of shapes it can handle
for draping the cloth onto.
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I wrote a C++ program to do the simulation
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Still a mesh, with a combination of two gradients as a pigment to give
the illusion of a net
Right, I'll probably do this
Right now, it can handle any number of cylinders in any position, any
number of boxes whose sides are parallel to the axis and an horizontal
plane at any given altitude. It's not very difficult to add new shapes,
but those are all I need for the moment...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A 'heightfield' would probably be useful, one could generate it from any
complicated shape with povray and it would work in nearly all cases.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
An idea : using the "trace" function to "scan" the geometry below the
cloth piece, and use the resulting height data into your utility...
Fabien.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A112510.9DB97405@skynet.be>, Fabien Mosen
Or just render an image from above the scene and use the depth
post_process...
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> post_process...
Or a gradient pigment with black/white color_map and
finish { ambient 1 diffuse 0 ) combined with an orthographic camera.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Pretty. From what you're saying about increasing resolution, it sounds like
you're not using the Provot method, but rather the Elias method... The
latter is slower and the first doesn't need increases in resolution to lower
stiffness. You merely change a variable or two.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
