POV-Ray : Newsgroups : povray.binaries.images : Capriccio 16B Server Time
29 Mar 2026 00:47:07 EDT (-0400)
  Capriccio 16B (Message 6 to 15 of 35)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Capriccio 16B
Date: 26 May 2003 21:15:48
Message: <slrnbd5ddi.99f.steve@zeropps.org.uk>
On Mon, 26 May 2003 08:41:36 -0700, Gena Obukhov wrote:
> Steve wrote:
>> Off the top of my head, create your 8 segment section, texture it and
>> then rotate/translate, that way you'll have the same part of the image
>> map on all secitons.  That's if I understand the problem correctly.
> Spherical mapping wraps the whole texture (8 sections) around the whole
> object (32 sections). So using your approach you have to make texture
> for 32 sections with transparent 24 sections and make layered texture
> (4 layers) rotating that texture 4 times. I thought maybe there is another
> way around.
> Gena.
No I don't think I understand what you're trying to do.
                                             or http://start.at/zero-pps
  1:46am  up 79 days, 22:14,  1 user,  load average: 1.39, 1.59, 1.39
Subject: Capriccio 17
Date: 27 May 2003 00:40:22
Message: <3ED2EA5A.8B1A6A@mail.com>
New version with some details.
Added wooden posts and changed light source position.
The source is in p.b.s.-f.
Gena.
Download 'capriccio.jpg' (90 KB) Download 'capriccio1.jpg' (56 KB)
Preview of image 'capriccio.jpg'
Preview of image 'capriccio1.jpg'
Date: 27 May 2003 00:49:56
Message: <3ED2EC9D.A3348F2D@mail.com>
Here is the problem. I'm making image map for the dome
and I'll use spherical mapping. When you use spherical mapping
you have to make the image which covers the whole object.
There is no way to use 'once' keyword and cover just a part
of the object. It doesn't work for the spherical mapping.
But detailed image for the whole objects is so huge that
I have out of memory message (384 Mb RAM in my machine).
That's why I was wondering if there is any way to use just
a map for 8 sections and duplicate it somehow for the rest
24 sections (32 sections total).
Gena.
Date: 27 May 2003 01:40:09
Message: <o9u5dv0v97tdi1vt4fusvstmk637562dfm@4ax.com>
On Mon, 26 May 2003 21:42:05 -0700, Gena Obukhov <obu### [at] mailcom> wrote:
You can use image with 'once', scale it down to fit your section unrolled into
<0,0,0>-<1,1,0> area, and then use spherical warp. Then you can duplicate
sections with layered textures. Similiar method was recently described by me in
a thread: http://news.povray.org/povray.newusers/31686/ with working example. I
hope it could work for you.
ABX
Date: 27 May 2003 02:32:00
Message: <3ED30488.630BAA40@mail.com>
Thanks a lot! That's exactly what I need. Does POV-Ray take memory only
for one map in this case ?:
#local DomeMap = pigment{
 image_map{jpeg "cathedral/dome1.jpg" once}
 scale<1/4, 1/2, 1/4>
 translate y*0.5
 warp{spherical}
sphere {
   0, 1
   texture{
     pigment{DomeMap}
     rotate y*0
   texture{
     pigment{DomeMap}
     rotate y*90
   texture{
     pigment{DomeMap}
     rotate y*180
   texture{
     pigment{DomeMap}
     rotate y*270
Gena.
Date: 27 May 2003 02:45:48
Message: <4126dvguirml7mn1a1deoddoorlnt9cmob@4ax.com>
On Mon, 26 May 2003 23:24:08 -0700, Gena Obukhov <obu### [at] mailcom> wrote:
Good. So I finally contributed Capriccio. I'm happy about that :-)
AFAIK yes, but if you unsure you can verify it with "Memory used" section in
povray messages.
>  translate y*0.5
>  warp{spherical}
BTW: After looking into your code I know more what you do - do you know instead
using layared texture you can use repeating warp? This should be fastest
solution.
ABX
Date: 27 May 2003 02:52:43
Message: <5n26dvk6g5adqas7gpmmi9av5qe2udnvi2@4ax.com>
Wouldn't it be faster if Gena didn't use 'once' but rather scale
<1/32,1,1> and then use the spherical warp? This would spare the
layered texture overhead (which is quite major with radiosity).
Peter Popov ICQ : 15002700
Subject: Re: Capriccio 17
Date: 27 May 2003 02:54:43
Message: <sq26dvgjqfdrm3oknsuj469ive9cams0dv@4ax.com>
On Mon, 26 May 2003 21:32:26 -0700, Gena Obukhov <obu### [at] mailcom>
I think the figures in the boats are not up to the same level of
detail as the other parts of the picture, even as compared to the
figures on the stairs. No offense to the contributor, just some
constructive criticism :)
Date: 27 May 2003 02:58:25
Message: <jt26dvgt4nj4q1dkrkgbtc6v824ilvhh5p@4ax.com>
If you would foollow link I posted you could read that spherical warp is
mentioned there :-). And I proposed layers since I was somehow sure he need
partial transparency for other texture under.
ABX
Date: 27 May 2003 10:42:14
Message: <3ED37945.E815152A@gmx.de>
Nice posts.  I did not yet study the code but i suppose it won't be that
easy to make their cylindrical shape a bit less uniform.
Ib's work on the building is impressive as well.  The texture should
probably be somewhat patina-like - somethinbg quite difficult to achieve
without being too slow.
I'm not sure about the change of the light position.  The left side
buildings are different from the original now but of course we have to
find a compromise because the lighting in the painting is not consistent.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
