![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Very cool. How about adding some discoloration to the metal
> on the roof? If it's weathered enough to turn green,
> you would think that it would have acquired a little bit of
> a warmer patina.
Actually, the colour of the cobber on the real building,
that I am modelling it from, is very uniform. The cobber part
under the top row of windows has a bit more variation, but frankly,
since it is only going to be used as a backdrop for another building,
I don't want to use too much time on details.
> It looks really neat. Don't know what else to say ...
Nothing more is needed :)
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ib Rasmussen wrote:
> Just thought I would show you what I'm working on at the moment.
The talent pool around here is making me want to give up my job and
start working on a POV movie full time.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't know if this is my monitor playing tricks on me, but the bricks seem
to form strange semicircular shapes and they flow in odd patterns... It's
probably all positioned perfectly, but to me the wall-texture appears warped
in odd ways...
but else it looks truely wonderful, certainly for some background thingy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> in odd ways...
off. I have tried a number of different anti-alias settings but nothing
helped. Higher resolution helps, as you can see in the attached detail
image, but I didn't want to post a 2400x1200 image in the news group.
Thank you.
have a sneak preview page at
http://www.ibras.ishoejby.dk/sktmarkus/stmarkus.htm
/Ib
Download 'bygning4detail.jpg' (9 KB)
Preview of image 'bygning4detail.jpg'
![bygning4detail.jpg](/povray.binaries.images/attachment/%3C3D732B4A.6020606%40ibras.dk%3E/bygning4detail.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> The building is only intended as background for a church model, so it is
> not done with the same level of details, as I usually do, but at this
> distance I think it is passable.
When I saw your name I knew that I would see a very nice model, which is
indeed what happend. It looks a little bit artificial more like a model
than the real thing, but if I remember correctly, that's what you're after.
Congratulations
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There were some threads dealing with such antialiasing problems.
For me, Kari Kivisalo presented a convincing solution.
In http://news.povray.org/povray.newusers/23381/ you can find the according
discussion.
Perhaps there will be a time, when you will share the source code with us.
Norbert
>> in odd ways...
>Thank you.
>/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, his technique does seem to give better results, than I was able to
get with antialiasing alone.
Well, there is not much to be learned from my source. It is just
thousands of lines of unions and differences of boxes, spheres, planes,
cylinders, torii and the occasional cone. But if you insists, I am
willing to post the code for this model. It is 4100+ lines of code, with
very few comments (and those there are, is in Danish :)
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I do like the hyperrealistic (if that's a word) perfection, that
only raytracing can produce. If I wanted photorealism, I could use my
camera, since most of the buildings, I model, exists.
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ib Rasmussen wrote:
>... But if you insists, I am
>/Ib
Hi Ib,
if that is all I have to do, I do insist. ;-)
I always like rendering pov code, because with very good models I
intuitively can imagine a realistic scene.
By example I always render all IRTC source code. It is my way to learn
Pov-Ray.
Norbert
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>... But if you insists, I am willing to post the code for this model.
OK, you will find it in p.b.s-f. There is a couple of pre-defined camera
positions you can try.
Oh, and I just remembered: it is set up for a 3:2 format. If you'd
rather use 4:3 change the imageratio vector in the .pov-file.
And please note that the glass texture is, eh.. experimental.
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
