POV-Ray : Newsgroups : povray.binaries.images : Landscape... WIP? (86k jpg) Server Time
5 Jun 2026 11:34:17 EDT (-0400)
  Landscape... WIP? (86k jpg) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Landscape... WIP? (86k jpg)
Date: 12 Jul 2002 01:02:11
Message: <3D2E62D3.60601@caltel.com>
marabou wrote:
> i do not know if the part of image is (only) well chosen. but it looks very
> realistic to me. ain't there an IRTC for realistic pics? that is one for it.
Actually, I chose the part you see so you wouldn't be able to see the edges of the hf
Samuel Benge
sbe### [at] caltelcom
Date: 12 Jul 2002 03:10:07
Message: <3d2e80cf$1@news.povray.org>
Are you aware that you're doing it again?  :o)  Posting a great great image,
with realism that gives me hope that I can do what I want without expensive
radiosity... At the moment I'm playing with a procedural sandy texture and
heightfield, but for a close-up purpose.. I hope the final result will be
good, too.. Maybe I should ask, how do you position those point lights to
give such realism?  Do you exploit the fact that it's sunraise / sundown?
Could you make it work in "daylight" without radiosity?
Hugo
Date: 12 Jul 2002 04:42:36
Message: <3d2e967c$1@news.povray.org>
Do you used a 10GHz processor ?  ;-)
3D2### [at] caltelcom...
> Not very inspired lately, so I've been playing with height_fields and
> isosurfaces.
> This scene has one hf, skewed, about 200 isosurface rocks, also skewed,
> 3 area_lights and one greenish isosurface sitting on the ground.
> For the most part the rocks blend in with the bedrock, which I suppose
> is a good thing. They use the granite pattern for displacement and were
> given the same texture as the hf.
> I purposely made the color of the sky a little extreme, attempting to
> emulate the great turn of the century painter, Maxfield Parrish.
> The greenish isosurface is a cylinder displaced with multiple cos
> functions added in a while loop. I think it may be related to the
> Fourier Series, though I don't really know much about them.
> Render time was just shy of 20 minutes, thanks to the very simple
> area_lights (all 2x2).
> Any questions, comments etc. are always welcome!
> Samuel Benge
Date: 12 Jul 2002 14:07:01
Message: <3D2F1AC3.2080708@caltel.com>
Hi Hugo. I place the area_lights according to how the sunlight falls. I
first place the sunlight, then I see where the brightest lit patch is. I
put the second area_light right near that lit patch and try to
approximate the width/breadth of it. I make this light about 1/2 to
3/4ths as bright as the original sunlight, usually. I also add a little
of the lit patch's color to the light. Next, if it's an outdoor scene(
on Earth), I make a blue area_light and place it in such a way as to
give the impression blue light could only come from that direction. In
this scene I made it look like the sky could only shine effectively from
direction <1,1,1>. If I would have placed a reflective sphere in the
center of the image, you would see blue sky directly behind, and that
would ruin the effect.
Samuel Benge
Date: 12 Jul 2002 14:28:20
Message: <3D2F1FC4.569CC77F@gmx.de>
> isosurfaces.
Very impressive and astonishingly without radiosity...
Last updated 30 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 13 Jul 2002 06:59:34
Message: <3d300816$1@news.povray.org>
> Next, if it's an outdoor scene (on Earth), I make a blue
> area_light and place it in such a way as to give the impression
Hmm, from what direction?  How can I choose an arbitary direction for the
blue light, when physically, most skylight comes from the same place as the
sun?
> In this scene I made it look like the sky could only
> shine effectively from direction <1,1,1>.
Is that opposite from the sun, in this case?
Thanks for the info and all the pictures you're posting!  :o)
Hugo
Date: 13 Jul 2002 07:17:24
Message: <slrnaj0320.hep.steve@zeropps.org.uk>
Somehow this one reminds me of those cards you used to get in packets
with chewing gum, particularly the "Planet Of The Apes" cards, it just
has that 70s sci-fi look and feel to it.
                                             or http://start.at/zero-pps
 12:15pm  up 15 days, 22:34,  1 user,  load average: 1.03, 1.04, 1.01
Date: 15 Jul 2002 00:08:02
Message: <3D324A9E.1080802@caltel.com>
> sun?
Imagine where more light from the sky would be coming from and place a
light there.
Not exactly. It's probably about 150 degrees from the sun.
Samuel Benge
Date: 15 Jul 2002 00:15:03
Message: <3D324C42.8010602@caltel.com>
Never seen the cards, but I'm familiar with the style. Science-fiction
artists have to make up something that isn't real, which means faking
the natural interaction of light in their paintings. Usually this
results in two of more general sources of light. You will often see a
brightly-lit scene with a sharp blue reflecting from a different
direction, which is what I did with this picture.
Samuel Benge
Date: 15 Jul 2002 03:24:55
Message: <3d3278c7@news.povray.org>
the
the
> > sun?
> light there.
It's still difficult for me to understand this. There are no other angle
where the sky is 'more lit' other than the sun angle.. Maybe you mean, I
should choose the angle where the sky is "most blue" and not most "lit" ?
Hugo
