![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Tim Nikias wrote:
> I got that one during the initial few rows (max_trace was too low for the planes),
so
> I've
> spotted the error early on. It's now set to 256, which should be sufficient for all
> reflections taking
> place on woman and ocean.
Actually for 70 planes something like 75 should work for sure (since the planes are
not reflective), but if your system can handle that without problems... :)
> Does anyone know why the max_trace has been limited to 256? No big room for
hundreds of
> planes there...
Higher values can lead to unpredictable crashes on Windows systems. Since it seems
that many users reported this as a bug (which truly is a system limitation) the
POV-Team decided to place a roof.
> Oh, another thing. The REAL final render uses 70 planes spread of 400 POV-Units
worth of
> height
> and definetely look good!
Can't wait to see it.
> And tracing is not too bad either: Finishes in roughly 40 mins on a 1.4 GHZ Athlon
with
> 512 MB RAM...
> (That was my personal present for me from myself for christmas)
You're very fond of yourself. ;)
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov //New: Kitchen WIP.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Hear hand is filled! (This is really it)
Date: 5 Jan 2002 18:19:31
Message: <3C3789C1.52513025@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It can, and as mentioned in the docs: Max-Trace has only an effect if really required
by
the scene. Perhaps it is on some spots where reflection goes nuts on the woman...
Have a look at www.digitaltwilight.de/no_lights/index.html , you'll find the finished
version in the gallery with some explanations on the making.
Not that much, but yes, I like it. Parsing and Tracing have increased significantly
after
switching from 256 MB Ram with 800 MHZ Athlon to the new one (about threefold), and
especially images like these are only endurable to make because lowres versions (with
some objects switched off) don't take hours. It's a real improvement, and helps me
going
on with my hobby... ;)
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
finished
Definitely a work you can be proud of. :)
after
(with
going
I would be still using my good old P 90, if only it hadn't decided to leave me last
year.
But yeah, Athlon has improved my POV-life quality.
Home: http://digilander.iol.it/jrgpov //New: Kitchen scene WIP
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> you'll find the finished version in the gallery with some
This is a very beautiful image!
I don't personally think it expresses warmth as you write it was your
intention, but I don't think that's a bad thing.
You have great artistic skill - keep up the good work!
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Jan 2)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Tim Nikias" <Tim### [at] gmx de> wrote in message
news:3C36E19E.CFF497C3@gmx.de...
> So, after various comments, I worked a little more on the image, and
> this is
> the final version. You may comment again, of course!
Amazing! The piece just seems very serene...I like it! I'm looking forward
to more of your work.
Your site is now bookmarked, btw :-)
#macro S(M)cylinder{E(M)<A,C,5>,<B,D,5>,.1,15}#end#macro E(P)#if(div(P,16)
)#declare B=-1;#declare D=-2;#end#if(div(P,32))#declare A=1;#declare C=0;#
end#if(div(P,64))#declare B=-1;#declare D=0;#end#if(div(P,128))#declare A=
1;#declare C=2;#end#end blob{S(192)S(96)S(48)pigment{rgb 8*z}} /** Ian **/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Jan 2002 05:32:30
Message: <3C382782.16C884F9@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you! It's something I don't hear that often from someone nearby...
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Jan 2002 05:34:05
Message: <3C3827E1.3B5249CA@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks!
I think, the expression changed during the creation process, but I think
the title "Tranquility" still somehow fits...
Thanks again for the first part, regarding the second: I will.
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Jan 2002 05:35:07
Message: <3C382820.F6DE1F01@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you!
Now that's an improvement the site I had hoped for: being bookmarked by someone.
(I really mean it, that's no kidding there)
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I like the heart in take 2 better... I like the deeper color here but i liked
the simple un-rounded shape before... Like Jell-O squares... =]
Did you make this model or did she come from another artist... ??
Are any of the source codes posted from your animation's shown on your web
site... Very nice work here... =]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Jan 2002 09:11:18
Message: <3C385ABE.1E00EC5F@gmx.de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I liked it better at first, but now it sort of has more "volume", like being of
greater,
"heavier" importance.
Well, it's a Poser4 Modell, converted for POVRay, 9 MB size, so I won't
put it up for download. But I positioned her, so you might say that I was
the artist... ;)
Not yet. The animations found there are all (as of yet) made with the
Particle-System
I wrote for POVRay. It's not fully functional and finished yet, and the help
needs some
work as well, but it'll be found there (hopefully someday soon).
Tim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
