![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I wonder if adaptive accuracy would be useful for isosurfaces. As visible
> in the near foreground the accuracy value is too high here, but the
> horizon part would look all right with even higher values and would be
> much faster then. Of course I could try to split it up in several
> objects, but avoiding the gap between is difficult.
That's an interesting idea... Anyone have any ideas on how to actually do it
or fake it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Awesome.
The sky is perfect too.
I only have to complain of the foregroung, which looks like it needs better
precision...
Several days with your Athlon?! You must be a very patient person.
p.s. Just curious: how much slower the first half was compared to the second
one?
Jonathan.
"Christoph Hormann" <chr### [at] gmx de> ha scritto nel messaggio
news:3BD52FDF.36E0175B@gmx.de...
> Isosurfaces with pigment functions are a really nice thing to play with.
> You can spend hours searching for nice structures in the noise...
> But in combination with radiosity it is really slow. I rendered this in
> several parts and no more know the exact render time, but it has been
> several days in total.
> Radiosity quality settings are fairly high (error_bound 0.05) but the
> structures in the shadow could still profit from better settings.
> Christoph
> Christoph Hormann <chr### [at] gmx de>
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The sky seems unnatural to me, and you're right about the error_bound
and need for accuracy in the foreground, but otherwise this is a great pic.
-Xplo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
JRG wrote:
> Awesome.
Thanks.
> precision...
As said, the accuracy value should have been lower, but that would have
been even slower of course.
> one?
I can't say precisely since i did not take that much care, but in general
in such scenes the horizon part is quite slow in comparison to the rest.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> or fake it?
Faking? I doubt that's possible.
Implementing it will probably have to wait until the final version of
Povray 3.5. I will surely have a look when the source code is available.
In general i think it's probably not very problematic to vary the accuracy
value.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks,
concerning the sky, it is meant to look a little unconventional, but i
have seen a lot of photos with much less natural sky than this.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thanks,
> Christoph
I personally feel that here is a very impressive computer generated
image ! The atmosphere seems to be almost perfect; I mean, something
serious "stand out" of the pict. We are looking through a very nice and cool
world.
I think this image is a good part of what CGI should be.
Alex P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's impressive image!
Have you tried "adaptive max_gradient" technique, which is already
implemented in 3.5 beta?
I think "adaptive accuracy" is not so useful as "adaptive max_gradient",
The below code is an example.
If you render it with accuracy=0.002 instead of 0.0001, you will
see artifacts near the top of small peaks.
On the other hand, if you render it with adaptive max_gradient
(e.g. "evaluate 2, 1.2, 0.9" instead of "max_gradient 5") and with
accuracy=0.0001, the image quality will be much better and the
rendering speed will be comparable or rather faster than the above.
Note that this technique does not guarantee artifact-free image
and requires experiences to determine the "evaluate" parameters.
(So, this should be only for advanced users.)
BTW, have you tried normal function pattern like below
(commented out) for the foreground? I usually use it in such
cases.
R. Suzuki
//--- the code ------
#version 3.5;
#include "functions.inc"
#declare Radiosity=off;
global_settings {
assumed_gamma 1.0
//max_trace_level 25
#if (Radiosity)
radiosity {
pretrace_start 0.08
pretrace_end 0.04
count 35
nearest_count 5
error_bound 0.05
recursion_limit 3
low_error_factor .5
gray_threshold 0.0
minimum_reuse 0.015
brightness 1
adc_bailout 0.01/2
#default {
pigment {rgb 1}
#if (Radiosity)
finish {
ambient 0.0
diffuse 0.6
specular 0.3
#else
finish {
ambient 0.1
diffuse 0.6
specular 0.3
location <0,1.15,-4>
look_at <0,0.8,0>
light_source {
<500,500,-500>
color rgb <1, 1, 1>
sky_sphere {
gradient y
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.7 rgb <0.0,0.1,0.8>]
isosurface {
function { y+f_noise3d(x/6,0,z/6)*0.5
+f_noise3d(x*12,y*1,z*12)*0.1
+f_noise3d(x*56,y*20,z*56)*0.04
+f_noise3d(x*120,y*20,z*120)*0.01
+f_noise3d(x*311,y*53,z*311)*0.005
contained_by { box { <-150,-3,-150>, <150,0,150> } }
accuracy 0.0001
max_gradient 5
// evaluate 2, 1.2, 0.9
checker
color rgb <1.0, 0.8, 0.6>
color rgb <1.0, 0.0, 0.0>
scale 0.5
/* normal{ function{
f_crackle(x*670,y*270,z*670)*0.2}
slope_map {
[0 <0, 1>]
[0.4 <1, 1>]
[0.65 <1,-1>]
[1 <0,-1>] }
translate y*1.3
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you!
Hmm, seems i don't understand completely how evaluate works, but i
remember in the past (with megapov) that scenes using 'eval' sometimes
were much faster than with a sufficient max_gradient value. I will do
some more experiments on that...
NTL, what i meant with adaptive accuracy was adapting it to the distance
from viewpoint. Of course it could be useful to adapt max_gradient in the
same way.
> cases.
No, but it's an interesting idea, anyway i suppose with 'normal on' in
radiosity this will be quite slow too.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> world.
Thanks, i think one could do quite a lot more with such a scene scene, if
it wasn't that slow. You could call it somehow 'brute force realism'
since there is really not much apart from the isosurface function and
radiosity.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
