POV-Ray : Newsgroups : povray.binaries.images : How can I get around this problem? Server Time
18 Aug 2024 18:16:25 EDT (-0400)
  How can I get around this problem? (Message 1 to 4 of 4)
Subject: How can I get around this problem?
Date: 2 Apr 2001 13:24:07
Message: <3ac8b5b7@news.povray.org>
When I use texture maps, my textures are flipped in four directions. Maybe
that isn't clear, but I've supplied an example. Is there a way around this?
Download 'scenetexlab.jpg' (6 KB)
Preview of image 'scenetexlab.jpg'
Subject: Re: How can I get around this problem?
Date: 2 Apr 2001 13:36:55
Message: <3AC8B8B7.1596F4F4@gmx.de>
I'm not totally sure what your problem is, but you seem to wonder about
the gradient pattern being mirrored at the origin.
You can translate the texture until the origin is out of view or, if you
are useing megapov, use a self made function that isn't symmetrical.
Date: 2 Apr 2001 17:01:08
Message: <chrishuff-084CAC.16010802042001@news.povray.org>
In article <3ac8b5b7@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> Maybe that isn't clear, but I've supplied an example. Is there a way
> around this?
You may be able to get the results you want with the repeat warp...
Christopher James Huff
Date: 3 Apr 2001 00:19:55
Message: <jdhictcqsobh2jlf38l5a7of9648k7f6ag@4ax.com>
Looks like you're layering or averaging two gradient patterns. The
gradient pattern is symmetrical about the origin. Use a marble pattern
or a planar pattern with a displace warp instead.
Peter Popov ICQ : 15002700
