POV-Ray : Newsgroups : povray.binaries.images : Earth at Dusk Server Time
23 Jun 2026 02:31:14 EDT (-0400)
  Earth at Dusk (Message 1 to 7 of 7)
Subject: Earth at Dusk
Date: 1 Dec 2000 18:15:31
Message: <3A283113.D206431A@spiritone.com>
This is a quick example of how I would blend the two images for Earth,
but it needs a lot of tweaking, the maps dont' line up exactly and the
terminus of the shadow is too strict, right now there's too much
contrast.
Here is the snippet of relevant code:
#declare day = texture {
  pigment {image_map {png "earth-land.png" map_type 1 interpolate 2} }
  finish { diffuse 0.3 brilliance 0.1 ambient 0}
  rotate 90*y}
#declare night = texture {
  pigment {image_map {tga "earthnight.tga" map_type 1 interpolate 2} }
  finish { ambient 0.2 }
  rotate 90*y }
sphere { 0.0, 1
         texture {radial
                  texture_map { [0.0 day ]
                                [0.3 day ]
                                [0.6 night ]
                                [1.0 night ] }
                  rotate 0*y}
eng### [at] spiritonecom
Download 'nightandday.jpg' (26 KB)
Preview of image 'nightandday.jpg'
Subject: Re: Earth at Dusk
Date: 1 Dec 2000 21:34:10
Message: <slrn92gnmm.sj5.steve@zero-pps.localdomain>
Looks like some snow there in Baja California, I would have
thought that it was always too hot for snow even at a high
altitude.
  2:06am  up 52 days,  4:30,  2 users,  load average: 1.00, 1.00, 1.00
Date: 1 Dec 2000 23:38:24
Message: <3a287cc0$1@news.povray.org>
You might have to go with a sine_wave for the radial pattern instead or at
least blend at the start and end of the map as well as the middle.  Anyway, the
terminator (shadow line) region is awfully sharp in that.
I forget exactly how I did it but it also had a gradient masking texture for
the dark side so the daylight didn't have lights showing.  Wasn't a clean
attempt but it worked enough.
Date: 2 Dec 2000 13:22:25
Message: <3a293de1@news.povray.org>
What date is it in your scene ???
You know that only two times in the year the night/day-line goes
the way you showed ...
Most time it is not orthogonal to your current view ...
I think it would look quite nice, if you would make the
night/day-line not that sharp and rotate it about 5-10 degrees
around z...
But of course, well done
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Josh English <eng### [at] spiritonecom> schrieb in im Newsbeitrag:
3A283113.D206431A@spiritone.com...
Earth,
and the
much
> contrast.
interpolate 2} }
>   rotate 90*y}
interpolate 2} }
>   rotate 90*y }
> sphere { 0.0, 1
>          texture {radial
>                                 [0.3 day ]
>                                 [0.6 night ]
>                                 [1.0 night ] }
>                   rotate 0*y}
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia
http://www.spiritone.com/~english/cyclopedia/
Date: 4 Dec 2000 11:57:30
Message: <3A2BCCF5.4BEE09A9@spiritone.com>
Quite probably. It's an image map that I got somewhere off of a NASA
server, I believe.
Josh
> altitude.
> Cheers
> Steve              email mailto:ste### [at] zeroppsuklinuxnet
> %HAV-A-NICEDAY Error not enough coffee  0 pps.
> web http://www.zeropps.uklinux.net/
> or  http://start.at/zero-pps
Date: 4 Dec 2000 12:19:48
Message: <3A2BD1FE.DF35BF4D@spiritone.com>
Like I said, a rough skecth, I completely ignored axial tilt to make it
easier for me to see what was going on with the scene.
Josh
> around z...
> Earth,
> and the
> much
> > contrast.
> interpolate 2} }
> >   rotate 90*y}
> interpolate 2} }
> >   rotate 90*y }
> > sphere { 0.0, 1
> >          texture {radial
> >                                 [0.3 day ]
> >                                 [0.6 night ]
> >                                 [1.0 night ] }
> >                   rotate 0*y}
Date: 4 Dec 2000 12:19:53
Message: <3A2BD234.595FA92A@spiritone.com>
Yep. I was just roughing in my method of how I would do it. Even this creates a bit
of darker shadow along the terminus. I know it needs a lot of work.
Josh
> Bob
