POV-Ray : Newsgroups : povray.binaries.images : can any one tell me what's wrong with my iso? Server Time
23 Jun 2026 10:44:31 EDT (-0400)
  can any one tell me what's wrong with my iso? (Message 1 to 10 of 10)
Subject: can any one tell me what's wrong with my iso?
Date: 15 Oct 2000 14:34:32
Message: <39e9f8b8@news.povray.org>
here is a source of an iso, when rendering i get the result attached to this
message.
i do not understand why I get a flat shape,
probably there are problems calculating the normal
Or maybe something else...
If anyone knows what the problem might be...
Ill be glad to thank him
    thanks for reading
        Oded
the source :
#version unofficial MegaPov 0.6
#declare g = (1+sqrt(5))/2
#declare V1 = (3*g+1)*0.02
#declare V2 = (4*g+3)*0.02
isosurface {
        function {
                if(-1-V1*x-V2*y,1,0)+
                if(-1-V1*x+V2*y,1,0)+
                if(-1+V1*x-V2*y,1,0)+
                if(-1+V1*x+V2*y,1,0)+
                if(-1-V1*y-V2*z,1,0)+
                if(-1-V1*y+V2*z,1,0)+
                if(-1+V1*y-V2*z,1,0)+
                if(-1+V1*y+V2*z,1,0)+
                if(-1-V1*z-V2*x,1,0)+
                if(-1-V1*z+V2*x,1,0)+
                if(-1+V1*z-V2*x,1,0)+
                if(-1+V1*z+V2*x,1,0)
        threshold 1.5
        contained_by { box {<-10,-10,-10>,<10,10,10>}}
        method 1
        pigment {rgb<0,1,1>}
        no_shadow
light_source {<14,14,14> rgb<1,1,1>}
        location <14,14,14>
        look_at <0,0,0>
Download 'isostar.jpg' (12 KB)
Preview of image 'isostar.jpg'
Subject: Re: can any one tell me what's wrong with my iso?
Date: 15 Oct 2000 15:14:30
Message: <39EA0217.A7D7E452@schunter.etc.tu-bs.de>
> message.
>     thanks for reading
>         Oded
I'm not sure what shape you wanted ;-), but how about:
        function {
                (-V1*x-V2*y)&
                (-V1*x+V2*y)&
                (V1*x-V2*y)&
                (V1*x+V2*y)&
                (-V1*y-V2*z)&
                (-V1*y+V2*z)&
                (V1*y-V2*z)&
                (V1*y+V2*z)&
                (-V1*z-V2*x)&
                (-V1*z+V2*x)&
                (V1*z-V2*x)&
                (V1*z+V2*x)
leading to the attached shape.
Download 'isotest_01.jpg' (3 KB)
Preview of image 'isotest_01.jpg'
Date: 15 Oct 2000 16:55:27
Message: <39ea19bf@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote :
>         function {
>                 (-V1*x-V2*y)&
>                 (-V1*x+V2*y)&
>                 (V1*x-V2*y)&
>                 (V1*x+V2*y)&
>                 (-V1*y-V2*z)&
>                 (-V1*y+V2*z)&
>                 (V1*y-V2*z)&
>                 (V1*y+V2*z)&
>                 (-V1*z-V2*x)&
>                 (-V1*z+V2*x)&
>                 (V1*z-V2*x)&
>                 (V1*z+V2*x)
    I find this fascinating and have no hope of figuring it out. My
love/hate relationship with Isosurface continues.
Date: 15 Oct 2000 20:06:18
Message: <39EA463D.1F0F451F@online.no>
There's nothing wrong with your ISO. =)
> the result attached to this message.
The problem is your camera position and your
light setting.
See code below my suggestion for a new scene with
your iso-surface.
The first enclosed image shows your ISO-shape.
This function also generates an interesting shape:
(The second enclosed image with the red shape)
  function {
    (-V1*x -V2*y)*
    (-V1*x +V2*y)*
    ( V1*x -V2*y)*
    ( V1*x +V2*y)*
    (-V1*y -V2*z)*
    (-V1*y +V2*z)*
    ( V1*y -V2*z)*
    ( V1*y +V2*z)*
    (-V1*z -V2*x)*
    (-V1*z +V2*x)*
    ( V1*z -V2*x)*
    ( V1*z +V2*x)
Tor Olav
mailto:tor### [at] hotmailcom
#version unofficial MegaPov 0.5;
#declare g = (1 + sqrt(5))/2;
#declare V1 = (3*g + 1)*0.02;
#declare V2 = (4*g + 3)*0.02;
isosurface {
  function {
    if(-1 - V1*x - V2*y, 1, 0)+
    if(-1 - V1*x + V2*y, 1, 0)+
    if(-1 + V1*x - V2*y, 1, 0)+
    if(-1 + V1*x + V2*y, 1, 0)+
    if(-1 - V1*y - V2*z, 1, 0)+
    if(-1 - V1*y + V2*z, 1, 0)+
    if(-1 + V1*y - V2*z, 1, 0)+
    if(-1 + V1*y + V2*z, 1, 0)+
    if(-1 - V1*z - V2*x, 1, 0)+
    if(-1 - V1*z + V2*x, 1, 0)+
    if(-1 + V1*z - V2*x, 1, 0)+
    if(-1 + V1*z + V2*x, 1, 0)
  threshold 1.5
  contained_by { box { 10*<-1, -1, -1>, 10*<1, 1, 1> } }
  method 1
  pigment { color Cyan }
  no_shadow
background { color Blue/2 }
light_source { 100*(V1*x - V2*z) color Gray60 }
light_source { 100*(V1*x + V2*y) color White }
  location <2, 4, -7>*8
  look_at <0, 0, 0>
  angle 25
Download 'test_iso01.jpg' (10 KB) Download 'test_iso04.jpg' (10 KB)
Preview of image 'test_iso01.jpg'
Preview of image 'test_iso04.jpg'
Date: 15 Oct 2000 21:55:31
Message: <39EA5D98.E0B1A0CD@faricy.net>
> >         function {
> >                 (-V1*x-V2*y)&
> >                 (-V1*x+V2*y)&
> >                 (V1*x-V2*y)&
> >                 (V1*x+V2*y)&
> >                 (-V1*y-V2*z)&
> >                 (-V1*y+V2*z)&
> >                 (V1*y-V2*z)&
> >                 (V1*y+V2*z)&
> >                 (-V1*z-V2*x)&
> >                 (-V1*z+V2*x)&
> >                 (V1*z-V2*x)&
> >                 (V1*z+V2*x)
It's just an intersection of twelve planes in the form Ax+By+Cz. With a
dodecahedron I believe it is possible to orient it in such a way that
each plane only requires two of these components.
Date: 15 Oct 2000 23:02:29
Message: <39ea6fc5@news.povray.org>
    http://www.shianet.org/~reneenew/calc.html  might tell you why the
phrase "it's just" made me chuckle...
Date: 16 Oct 2000 07:47:43
Message: <39EAEAE0.7EF31B92@schunter.etc.tu-bs.de>
> light setting.
> your iso-surface.
I must admit that i didn't even check if it worked somehow :-) The if(,,)
construct was very unfamiliar to me.
After thinking a bit about it, i believe it is probably the most simple way to
create this particular shape, using a CSG of planes would be quite more
complicated.
On the other hand it does not work with 'method 2' and things like surface
perturbation with noise3d and pigment functions.
Date: 16 Oct 2000 18:46:48
Message: <39EB843E.DC7FEA8D@hotmail.com>
I found out what it really does 1 hour ago   :)
> complicated.
I've done this with CSG and it's not much more complicated - but, yes, the
CSG-code looks uglier.
Ehhh... I know nothing about this.
You see - I'm a newbie to MegaPOV and iso-surfaces.
Tor Olav
Date: 17 Oct 2000 03:08:19
Message: <39EBFAE3.A06B7A4B@schunter.etc.tu-bs.de>
just have a function like:
#declare fnBumps=function { noise3d(x*12, y*12, z*12) }
or
#declare fnBumps=function { pigment { agate color_map {[0 rgb 0][1 rgb 1]} } }
and add/substract it to/from the isosurface function like this:
isosurface{
  function { (sqrt(x*x + y*y + z*z) -0.9) -fnBumps(x,y,z)*0.1 }
  method 2
  accuracy 0.001
  eval
  contained_by{ sphere{ <0,0,0> 1.2 } }
Date: 17 Oct 2000 19:03:26
Message: <39ECD9A6.86F4858D@hotmail.com>
> or
> isosurface{
>   method 2
>   accuracy 0.001
>   eval
OK - Now I understand what you mean.
Thank you for showing me this.
Tor Olav
