POV-Ray : Newsgroups : povray.binaries.images : Cloud test Server Time
22 Mar 2026 00:10:24 EDT (-0400)
  Cloud test (Message 31 to 40 of 43)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Pigmenting Clouds
Date: 27 Aug 2000 14:07:06
Message: <39A9591A.F5C700D4@istar.ca>
Christoph Hormann wrote:
> Simon de Vet wrote:
> > I am planning, however, to create some POV code to generate semi-realistic
> > clouds procedurally. In my experimentation, I have made some progress, and I
> > think it should be do-able.
> But not with that rendering time :-)
I'm not so sure about this.
I've looked at other people's cloud techniques, and they all use 3-d to generate
3-d looking clouds. Some use media, or isosurfaces, or stacked planes, but all use
actuall objects.
When I look at the clouds around me, most are way too far away to look 3-d. 3-d
objects are usually shaded based on the angle of the incomming light (diffuse
shading) and on self shadowing. Clouds, on the other hand, have a bit of this, but
the vast majority of the shading comes from the extinction of light as it passes
through the water vapour.
I've been looking at clouds not as 3-d objects, but as 2-d objects, painted onto a
giant sphere. If treated this way, I think that most of the effects can be
generated with complex textures on a skysphere, which are very quick to render.
http://freespace.virgin.net/hugo.elias/models/m_main.htm has a good (award
winning) example of a pigment based cloud render.
In addition, pigments can generate clouds other than puffy cumulus, like cirrus,
stratus, and realistic haze.
I'm attaching a test image I made before I gave up on this technique, due to time
limitations. It's a very early image, with no pseudo-3-d effects, but it shows how
pigments can be used to create the shape of distant thunderclouds. It's all one
pigment, generated with the 'pigment control trick' and MegaPov's spline.
Simon
Download 'cloudtest1.jpg' (43 KB)
Preview of image 'cloudtest1.jpg'
Subject: Re: The Solution! (Re: Cloud test)
Date: 27 Aug 2000 14:22:15
Message: <39A95C30.6B651783@mailme.dk>
A total cheat, mister!
Sure it looks good, but imagemaps are not very flexible, cause they are
not very real... Okay I use them too, but I have found that the greatest
realism is achieved when objects are modelled like in real life.
Well, your clouds are in the horisont, so unless you plan an animation
of them, or a sundown, it doesn't matter if they're real or not. And as
long as you put enough real things into the picture, people will look at
mostly them, and not the clouds... In which case you can receieve praise
with a clean conscience.
- Hugo
Simon wrote:
>> I guess this shows that, on occasion, imagemaps aren't the terrible
>> solution they're made out to be.
Subject: Re: Pigmenting Clouds
Date: 27 Aug 2000 15:01:35
Message: <39A965D1.CC03617E@schunter.etc.tu-bs.de>
> actuall objects.
Your description of the clouds lighting seems perfectly right, but i don't agree
about the distance.  Clouds like the ones in your scene are about 3-6 km high.
In a large scale movement animation or a fast motion film you could perfectly
see the 3d structure of those clouds.
I have seen that one before and i like it too, but NTL, the lighting used there
is not very convincing for roundish clouds, because it only makes clouds lighter
according to their general distance to the sun, while each cloud should be
somewhat lighter on it's sun side and dark on the opposite side.
I agree, especially for high cirrus clouds the plain texture approach seems most
efficient.
That already looks quite promising for some kind of near horizon cumulus
clouds.  It only will be quite difficult to achieve realism on both near the sun
and on the opposite side.
Date: 27 Aug 2000 15:44:01
Message: <39A96F22.93E28E7F@taconic.net>
Simon de Vet wrote:
--snip--
> actuall objects.
--snip--
If I may beat my own drum for a sec, I posted a non-media 2D cloud
example not too far back. The method provided for some 3D lighting
effect. For the results, the rendering times were pretty fast. I'll take
the liberty of sticking in another example my pigment clouds below.
(This was from an effort to copy the technique from the TGLTLSBFSSP page
which you mentioned).
I have always thought that simple bump mapping should do the trick of
providing the correct shadows to pigment. So far though, I have had very
little success with it in POV. Not sure why ...
Abe
Download 'clouds_simple.jpg' (33 KB)
Preview of image 'clouds_simple.jpg'
Date: 27 Aug 2000 15:49:35
Message: <39A97080.BAB2F935@taconic.net>
Regarding the clouds at Hugo Elias' page, he _does_ apply cloud shading
via bump mapping in the snippet of pseudo-code at the end. You can also
see it in the example image.
Abe
Subject: Re: Cloud test
Date: 27 Aug 2000 16:05:07
Message: <39a97473$1@news.povray.org>
"Paul Vanukoff" <van### [at] primenetcom> wrote in message
news:39a71fe1@news.povray.org...
> AWSOME ROLEX! even.
I guess I should post another of my stern warnings against posting photos
and trying to pass them off as POV.
[ ;-) Good work]
Eric
Date: 27 Aug 2000 16:15:56
Message: <39A9773D.708A3560@schunter.etc.tu-bs.de>
> Abe
Seems you are right, but the effect is not very strong.  I think simple bump
maps probably are not sufficient in many cases like this:
http://www.wolkenatlas.de/wolken/wo12625.htm
Of course these are somewhat extreme, but the general type of those clouds is
very common.
Date: 27 Aug 2000 18:26:52
Message: <39A9955B.B54B2DD4@taconic.net>
An understatement.
> very common.
...and very desirable ;)
Abe
Date: 27 Aug 2000 19:30:39
Message: <39A9A67D.29090A1A@pilot.msu.edu>
Why are image maps so frowned upon in the POV community?  Almost all of
the big wig renderers use them solely.
GrimDude wrote:
> Image_map and IRTC? Bite your tongue!
> Grim
Date: 27 Aug 2000 20:27:07
Message: <39a9b1db@news.povray.org>
generate
all use
> actuall objects.
[snip]
to time
shows how
all one
Yes, I think this method does hold a lot of promise.  A while ago I put
together a few animations of various types of clouds, which do include
sun-shading (see the Current Projects page at
http://www.geocities.com/ccolefax/projects.html).  The code is all quite
basic POV 3.1, and I've parametised most aspects of the clouds.  I think the
trick is to find pigments that look effective at high resolutions...
