POV-Ray : Newsgroups : povray.binaries.images : concept to visualization Server Time
3 May 2026 04:21:01 EDT (-0400)
  concept to visualization (Message 1 to 10 of 10)
Subject: concept to visualization
Date: 19 Aug 2000 01:18:53
Message: <399E1926.98732528@ij.net>
I took an interest in exploring order in chaos from a different
direction. I was inspired by a suggestion in a research report
that in the long run (enough iterations) clearly non-random
results appear. This first approach was simply getting the
process to work. There was no methodology in the report.
Using the attachment as an example --
	It starts with an array 0..257 by 0..257 with all the pairs
containing 0 and 257 (the edges, boundary values) constrained to
zero.
Step 1. Each of the other array elements, 1..128,1..128 are given
a random number between -0.5 and +0.5.
Step 2. Then each cell is averaged with its nearest neighbors (8
neighbors + itself for 9).
Step 3. Return to step 1, twenty times in the case of the
attached image.
Step 4. convert the final array of numbers into triangles in mesh
object format.
Setp 5. Render
	It's a 19Meg POV source file if anyone is realy desperate. The
generating program is only 2k but you have to have Turbo Pascal
or download Free Pascal. (Go to Google.com and search 'free
pascal'. There are plenty places to get it.) Of course it is a
first attempt
	All that aside, speaking of the image, the scale is linear, that
is 258 units on a side with the added increments of +/- 0.5 at
each step. Visually I see some extended patterns in the image. It
is also visually interesting but then so are the holes in
acoustic ceilings if you have nothing better to do with your
time.
	Eventually I intend to produce an animation of this, one frame
per iteration (step 3).
	/*Ignore the little thing in the lower left corner. I just
dropped the mesh into an existing scene file.*/
Kareoke is Japanese for tone deaf.
    -- The Iron Webmaster, 15
Download 'array2.jpg' (27 KB) Download 'array2a.jpg' (21 KB)
Preview of image 'array2.jpg'
Preview of image 'array2a.jpg'
Subject: Re: concept to visualization
Date: 19 Aug 2000 02:03:36
Message: <399E24DA.A9D04FCB@pobox.com>
This gives me an idea that I'll never follow up ...
Among the screensavers that came with Red Hat is "Demon", by David
Bagley.
(http://www.jwz.org/xscreensaver/screenshots.html)  It's a cellular
automaton which a simple rule (that baffled me until I read about it
elsewhere): If the color next after yours appears on any neighboring
cell, change to that color.  Spirals almost always result.
So my thought is: make a moving hf, where the height is the sine of the
phase (color).  Initialize randomly, and watch lakes sloshing around,
nibbling gradually at their chaotic edges until they join to form the
spirals.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 19 Aug 2000 03:58:55
Message: <399E3EAB.27810E7C@ij.net>
> Bagley.
	Have to look at that one.
> spirals.
	I can say this now that I have run it a few times and more
iterations. As it is a real number +/- 0.5, I have yet to find a
number that is +/- 10.0 or greater. Lots of +/- 9.xxx's. That
indicates a valid random number generator to me while I consider
the 256x256 a test of calling it.
	Something I did not mention, I have to kill apps and 'sync' else
povray complains that it has run out of RAM at 128M of same.
	That said, I don't quite see what you are saying.
	But I could do the pigment {color calculated} and dark to light
blue between -10 and +10 to make a shot at waves.
If you quit smoking now you can live long enough
to get Altzheimer's.
           -- The Iron Webmaster, 24
Date: 19 Aug 2000 04:51:56
Message: <399E4AD0.76CFE222@schunter.etc.tu-bs.de>
> first attempt
Looks interesting, btw you should try a heightfield for that, it's much faster
and occupies less HD space.
Date: 19 Aug 2000 12:49:38
Message: <399EBB14.BE28E1EB@ij.net>
> > first attempt
	But how do I get the date into an image file?
Date: 19 Aug 2000 13:07:27
Message: <399EBEF5.A36D99A2@schunter.etc.tu-bs.de>
Maybe i missed something in your description but IMO it's much easier to write
an array of numbers into a heightfield file than to a povray mesh definition.
Date: 19 Aug 2000 14:06:23
Message: <399ECD12.A02E6B90@ij.net>
	I look at the docs for heightfield.
HEIGHT_FIELD:
     height_field{ HF_TYPE "filename" [HF_MODIFIER...] }
HF_TYPE:
     gif | tga | pot | png | pgm | ppm | sys <<<<<<<<
HF_MODIFIER:
     hierarchy [Boolean] |
     smooth [Boolean] |
     water_level Level |
     OBJECT_MODIFIER
	All the HF_TYPEs are image formats. I have hacked the
uncompressed .tga format but haven't tried to implement it yet.
Is there an easier way?
There is never any reason to be angry with the
enemy because whatever they do they are doing
it because the believe it is the right thing
to do. -- Marcus Aurelius
	-- The Iron Webmaster, 33
Date: 19 Aug 2000 14:39:59
Message: <399ED4A5.334BF693@schunter.etc.tu-bs.de>
uncompressed tga is the simplest IMO, pgm is quite simple too.
Date: 19 Aug 2000 15:27:46
Message: <399EE027.2DE1BBE5@ij.net>
	One can always hope for simpler. Thanks.
In WWII Britain used the old "start a world war to prevent
a world war" trick. Some say it worked better than could
have been imagined.
	-- The Iron Webmaster, 28
Date: 23 Aug 2000 11:27:41
Message: <39A3EC3C.22F9DE8A@my-dejanews.com>
Matt's approach is probably brilliant for other fractal problems, but methinks
this is really a duplication of one of the noise functions.  An isosurface scene
file with 19 lines, instead of 19 MB,  could do the same thing, no?
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
