POV-Ray : Newsgroups : povray.binaries.images : Aircraft Design Server Time
31 Mar 2026 07:08:44 EDT (-0400)
  Aircraft Design (Message 1 to 10 of 22)
Subject: Aircraft Design
Date: 14 Aug 2000 07:50:51
Message: <3997DD26.6A2CDC13@tu-bs.de>
This is a general aviation sports aircraft I designed in my spare time.
It is a single-seater, has limited aerobatic capabilites (-/+ 6 g)
and uses a pusher engine and rectractable main landing gear.
MTOW is about 500 kg, top speed is 450 km per hour. Wing span is 6 m.
(You must know that I am a post-graduate aerospace engineering student.)
"Designed" does not mean "paint" with POVRAY in this case.
What you see is the result of months of hard work and lots
of calculations and sketches and "what-if's", so there is a reason why
the
plane looks like this and not any other way.
I used POVRAY for design visualization because I had
no other CAD-Tool at hand.
I send you this not to judge the image, but the plane !
Any comments on the aircraft would be nice.
Thanks !
Jens
Download 'draft.jpg' (43 KB)
Preview of image 'draft.jpg'
Subject: Re: Aircraft Design
Date: 14 Aug 2000 09:28:04
Message: <3997f3e4$1@news.povray.org>
"Jens Strohmeyer" <j.s### [at] tu-bsde> wrote in message
news:3997DD26.6A2CDC13@tu-bs.de...
I like it.  I especially like the canopy, although I'm speaking of the 3D CG
aspect of how it looks more than the CAD aspect.  I just can't help but to
enjoy things that look the way that canopy does.  Guess because of the scale
model prototype appearance.
Do you have MegaPov?  Would be very good for that propeller to use motion
blur instead of just a disc there.
Date: 14 Aug 2000 12:16:24
Message: <slrn8pfrq6.eai.steve@zero-pps.localdomain>
It's a nice image, well displayed.
I'd think that the length and shape of the glass would cause a considerable
increase in production costs compared to a more conservative design in
that particular area.
  1:58pm  up 30 days, 12:25,  2 users,  load average: 1.03, 1.08, 1.06
Date: 14 Aug 2000 13:14:19
Message: <39982909.C935275D@tu-bs.de>
> Cheers
> Steve              email mailto:ste### [at] zeroppsuklinuxnet
> %HAV-A-NICEDAY Error not enough coffee  0 pps.
> web http://www.zeropps.uklinux.net/
> or  http://start.at/zero-pps
No, not at all.
Just think of the modern soaring planes.
Canopy is about the same,
I already thought about adapting one from there.
Greetings ! - Jens
Date: 14 Aug 2000 13:34:26
Message: <39982B9D.32FDC3D7@faricy.net>
Looks fun! What, no wingtip static dischargers or plates to prevent airflow
around the tip? ;-)
Date: 14 Aug 2000 14:28:28
Message: <39983a4c@news.povray.org>
Look like it would be a little nose heavy. Where is the center of gravity?
C.J. - POV User
www.crosswinds.net/~povstudy
Jens Strohmeyer <j.s### [at] tu-bsde> wrote in message
> the
> Thanks !
> Jens
Date: 14 Aug 2000 14:30:14
Message: <39983ab6$1@news.povray.org>
I do like it though....
Regards again.....
C.J. - POV User
C.J. <hou### [at] yahoocom> wrote in message
news:39983a4c@news.povray.org...
> Regards,
> C.J. - POV User
> > the
> > Thanks !
> > Jens
Date: 14 Aug 2000 14:59:16
Message: <hgfgpssultg833377ok9kfok74u25hdon4@4ax.com>
On Mon, 14 Aug 2000 13:51:02 +0200, Jens Strohmeyer <j.s### [at] tu-bsde>
Jens this is most appropriate.  We have just been trying to answer the question
"What use is POV"  in p.newusers - you have provided an excellent example.
I like the look of your plane.  The concept is interesting and it looks if it
would handle in a sporty way.  It appears to have zero dihedral so I suppose you
designed it to be flown by an experienced pilot.  The junction of the booms with
the tailpane seems rather slender for a high stress region.  Is the construction
mainly fibreglass?
BTW I like the image :-)
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 14 Aug 2000 16:37:04
Message: <39985870@news.povray.org>
    I have the full version of AutoCAD 12 but I use POV for all my work that
does not need wireframe or dimensions. Actually I will often do it in POV
and then once I am satisfied, translate it over to AC by typing in the
proportions and use AC to mark the dimensions.
    I doubt that there are many here that can actually judge the plane on
anything other than aesthetics. I certainly cannot. But as an image of a
work in progress, it looks quite promising. Details and textures are all it
really needs.
Date: 14 Aug 2000 18:19:21
Message: <39987051.152DAAFE@yahoo.com>
where do the landing gear go? doesn't look like there is room.  and how
about engine exhaust?  is that under the wings?  which direction does
the canopy open?  does the pilot lay down?  why are the wing tips
'cut'?  i only recall seeing rounded wing tips.  does the pilot get to
sit on something and use controls or just flop around inside the
cockpit?  just kidding with that last one. considering the wingspan is 6
meters, it looks like the fuselage is about a meter wide and the canopy
would be 2 meters long.  and the engine compartment seems a bit small
maybe.  a friend of mine had a push plane called a cozy.  it had canards
in the front, wings that swept back and had the tails at the wingtips.
it was a three seater and very aerobatic although i'm not sure of how
many g's it could handle.  they sold it to get a 5-seater twin engine
boring plane and shortly after that, the new owner crashed on landing.
it was deemed unrepairable.  i must say, your design is visually
appealling.  i like it.
> the
> Thanks !
> Jens
