Can a routine be made to do wind erosion? Desert landscapes could be made with
these mushroom shaped rocks that get eroded more at the bottom. However, I'm not
sure if that can be done with height fields.
Brendan
Christoph Hormann wrote:
> Just made some tests with an Erosion routine I programmed some time ago. The
> result has some similarity with ridged multifractal but it is an editing
> function modifying any existing heightfield.
> And it is quite fast (about 800 milliseconds for a single run on a 256x256
> point heightfield on my K6/500)
> The first one is the starting heightfield, the second one after about 15 runs
> with smoothing between, the third after 15 additional runs.
> Please tell me what you think of it, I wonder if anybody has done something
> similar before.
> I am already planning some addition to stop erosion process, when a certain
> slope is reached, which would be more realistic.
> Christoph
> Christoph Hormann <chr### [at] gmxde>
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
> [Image] [Image] [Image]
Bill DeWitt wrote:
> Some mountains look sharp because they have been recently pushed up.
> Even old mountains look that way if they are still being pushed up. But old
> mountains in areas with no recent plate activity are rounded by erosion.
> Your photo is clearly one of an upthrust formation of some sort. In a
> billion years it will be a rounded boulder.
Agreed, but on the other hand, the sharp structures often correspond with the
river network, which suggests, that they are also partly formed by erosion.
The photo is not a very good example, very good are usually satellite pictures
where you can see the sharp edges in the light *and* the rivers.
just found one (sorry for the many pictures), well in fact it's a radar image,
but it should work...
Download 'mount2.jpg' (44 KB)
Preview of image 'mount2.jpg'
have you seen any of the tutorials and utilities made for positioning
items on a height field? i think there is something out there that can
define areas of height fields to be worked on. i think it is genesis
toolkit found at www.rhein-ruhr.de/~schrammel/index.htm. i'm not sure
it's usefull, but there you go.
> ryan constantine wrote:
> > i think it depends on whether it is wind erosion or water erosion. wind
> > rounds, water peaks.
> IMO this type of erosion is mainly caused by the changing temperatures
> destroying the structure of the material at the surface. Of course water and
> wind are major factors for transportation of material.
> > if you could define areas most and least likely to erode, that would be
> > cool. for example, areas with a lot of ground cover don't erode as fast
> > as open areas. dirt erodes faster than rock, etc.
> That's a good idea, it is only a problem how to define those areas.
> BTW, my code partly already does this, because it erodes more on steeper areas,
> where there is normally fewer vegetation.
> Christoph
Could you perhaps allow the user to provide an erosion_map for it?
Interesting.
Is it a POV-script doing this ?
And if so, then how is it done ?
Tor Olav
mailto:tor### [at] hotmailcom
Maybe an animation would help illustrate your technique? (O.k., so I just
like animations a lot... :)
Dave
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:396A0D1D.2B382007@schunter.etc.tu-bs.de...
The
runs
something
> similar before.
certain
> Christoph
Christoph Hormann wrote in message
<396A32E4.CF4A5F18@schunter.etc.tu-bs.de>...
Allow a user to provide a second greyscale image that specifies the
"hardness" of parts of the map.
Mark
Andrea Ryan wrote in message <396A333F.8A101D00@global2000.net>...
with
I'm not
>Brendan
It can't be done with a heightfield, but a .df3-based isosurface would work
quite well for this.
Mark
> Regards,
> Dave
Never did an animation before :-) so i will have to learn it first...
NTL, it is a good idea.
Tor Olav Kristensen wrote:
> Interesting.
> Tor Olav
No, it's a delphi program.
BTW, that leads to an interesting idea for a new feature:
height_field {
pov {
"hf.pov"
width=512
height=512
or similar...
Recursive implementation could occupy povray forever :-)
