Mike Weber wrote:
> Looks like it could be used as advertisement for the Leveller program..
Grin. Now I now what those transparent objects (Wasserwaage) are
called in english. Leveller, right?
Markus
I love it, and the title of course is "Water level", right?.
The next step would be putting the little bubbles
in the tubes :-)
Harold
"Sax" <qua### [at] freegatesbe> wrote in message
news:3965C6CE.55765523@freegates.be...
> Hi all,
> Here is my first real scene i worked on...
> Is there a way in povray to make real waves, I mean not a texture but a
> "surface" with wave you could surf on ?
Just "level".
David Fontaine <dav### [at] faricynet> ICQ 55354965
On Fri, 07 Jul 2000 16:48:29 +0200, Markus Becker wrote...
I'm not sure exactly what they are, but they look a bit like Spirit
Levels, maybe that's the term you're looking for.
Bye for now,
Jamie.
I think this particular (carpenters?) level is using those green cylinders
instead of bubbles, Sax said before it was an "air" level so it probably has
those resting in vacuum or air. They should be moved according to position so
it looks like they are working properly. Never seen a type like this if it is
that and I don't see how it could operate friction-free enough unless there is
supposed to be fluid in the tubes; in which it's also called a spirit level,
like those with the bubbles.
"Harold Baize" <bai### [at] itsaucsfedu> wrote in message
news:39661a8e@news.povray.org...
| in the tubes :-)
In article <MPG### [at] newsstmuccom>,
I've usually heard them called bubble levels. Except these seem to be
missing the bubbles...
Christopher James Huff - Personal e-mail: chr### [at] maccom
TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
Yep, I didn't manage (nor tried) to put bubbles in the levels...yet
The title is in fact :'Invasion'. The idea behind it is that bubble levels
are used to make thinks levelled, perfectly horzontal or vertical. In this
little world, the aliens are bubble levels and their job is to lower
everything at sea level... . Er, ok, i'll follow the white guys with the red
cross...
Sax
> in the tubes :-)
> Harold
> > Hi all,
Please post the function.
I get paid to do -anything- while connected to the internet.
Please use my referral id to find out more
http://www.getpaid4.com/?billdewitt
>in the tubes :-)
From what I know a spirit level is what you're all talking about
(the one with the little bubble in), a water level is quite
different and consists of two small transparent tubes with a mark
at the middle of each, each transparent tube/cylinder is then
connected to a very long flexible but crumple proof tube a bit like
a hose pipe, you fill the pipe up untill the water reaches the mark
in each transparent cylinder. You put the lids on the transparent
cylinders, and you can check items at long distances to see if they're
level or not, one person holds one transparent tube up to the wall
or roof at his end and a second person takes the other transparent tube
(on the other end of the pipe), to the second location and holds the
tube up to the appropriate place, if the water in each transparent tube
is touching the line, then the two locations are leve. And that is a
water level.
Steve email mailto:ste### [at] zeroppsuklinuxnet
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
12:49am up 23:15, 2 users, load average: 1.08, 1.02, 1.01
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
| is touching the line, then the two locations are level. And that is a
| water level.
And that was also interesting to learn.
