Subject: Towards a procedural tree macro (62kbbu)
Date: 25 Mar 2000 22:50:10
Message: <38dd88f2@news.povray.org>
I've seen some tree makers here which are breathtaking in their visual
beauty. I think that the coolest alorgithm for a tree, however, would
be procedural and not involve lots of translate & rotate statements.
Here's my first stab at a procedurally derived tree. Further
experimentation underway. Feel free to take this and improve it.
#declare rag=function{ 1/(x^2+y^2+z^2)^0.5*5} // 35;
#macro Treegent(gent,tx,ty,tz)
//gent is currently useless randomizer, translate to tx, ty, tz
union{
isosurface{
function{
noise3d((x+gent)/rag,(y+gent)/rag,(z+gent)/rag)&(-y-1) }
accuracy .001
threshold .01
contained_by {sphere{0,15} }
bounded_by {sphere{0,2 } }
isosurface{
function{ noise3d((x+gent)/rag,(y+gent)/20/rag,(z+gent)/rag)}
accuracy .001
threshold .08
contained_by { sphere{0,5} }
bounded_by { sphere{0,1} }
pigment{
spherical
pigment_map{
[0 Green]
[.2 Brown]
[1 Brown]
scale 12
finish{ambient 0.1}
translate <tx,ty,tz>
Download 'noiseforest2.jpg' (62 KB)
Preview of image 'noiseforest2.jpg'
I love the look. I m going to give it a try.
> union{
> isosurface{
> function{
> accuracy .001
> threshold .01
> isosurface{
> accuracy .001
> threshold .08
> pigment{
> spherical
> pigment_map{
> [0 Green]
> [.2 Brown]
> [1 Brown]
> scale 12
> finish{ambient 0.1}
> #end
> [Image]
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Looks OK for bushes or background trees. Keep up the work. Good luck. :)
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:38dd88f2@news.povray.org...
Not too shabby! Looks like an Orange Grove.
I haven't tried to play with your code yet... looks like fun...
Could you tell us what the value for gent you used in the posted scene?
All my attempts have given bad results, not at all like yours.
Thanks.
Mr. Art
Bill DeWitt 2000
Subject: Re: Towards a procedural tree macro (62kbbu)
Date: 26 Mar 2000 11:00:33
Message: <38de3421@news.povray.org>
Again, not too shabby. But I think that starting from this it will be
hard to improve it much. I would rather see something that is more like the
lparser system that can start from a basic trunk and then divides into
branches and twigs. Then you could use trace or something to put leaves on
it...
I am really interested in this and am pounding away at it. But I have
little hope of accomplishing it. I can't get a division, not even a simple
Y... once I get that the rest should just be tedium.
Date: 26 Mar 2000 12:32:39
Message: <38de49b7@news.povray.org>
ZERO.
I initially thought I could get it to given randomized appearance of each
tree, but then realized that I was too lazy to code it that way. Lemme know
if zero gives you trouble.......
> Thanks.
Date: 26 Mar 2000 12:47:10
Message: <38de4d1e@news.povray.org>
I chose the noise3d function because it has its own 'branchability' built into
it.
See the following image, with a slightly higher threshold, and a cross section
through the branches.
> it...
Download 'noiseforest02.jpg' (43 KB)
Preview of image 'noiseforest02.jpg'
I'm thinking a marriage between standard pov objects for branches, and
isosurfaces for leaves might be the best we can do to make good, and hopefully
fast-rendering trees. I might have to try it. :)
> union{
> isosurface{
> function{
> accuracy .001
> threshold .01
> isosurface{
> accuracy .001
> threshold .08
> pigment{
> spherical
> pigment_map{
> [0 Green]
> [.2 Brown]
> [1 Brown]
> scale 12
> finish{ambient 0.1}
> #end
> [Image]
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Date: 26 Mar 2000 19:31:41
Message: <38DEAD4C.78E3@aol.com>
These trees would look just great in a background, I think; not as good
in the foreground, though.
Two small suggestions:
1) Turbulate the x, y, and z values just slightly based on their
distance from the center. This will give the trees a less hemispherical
look.
2) Change all n^2 to sqr(n) and n^0.5 to sqrt(n). As far as I can tell
from the function code, these should always be faster than using an
exponent.
I think I might give this a try in an old scene (where I wanted
background trees but settled for a textured height field) and see what
happens.
Lummox JR
