Kill Rhino and, while your at it, destroy your gifs.
Just My Not So Humble Opinion.
Peter Warren
war### [at] hotmailcom
Very nice.
Is that a bat?
Personal to me: Jr is now #30. But who will break 714(?).
Mac or the Cry Baby?
Peter Warren
On 22 Feb 2000 12:43:01 +0100, as### [at] jeevesstudntnuno (Sigmund Kyrre
>"Eric Freeman" <eri### [at] datasynccom> writes:
>> Very nice image. You might consider Rhino for making that glove. You can
>I'll check it out. I've seen some very nice models done with Rhino, but I
>didn't know there was a trial version. How good is the pov-export? Do you
>have good control of object groups/unions?
The POV export is pretty good. It can export a big POV file or a small
POV file and a separate INC for every object. It would have been good
if all elements on a layer could be made into a single mesh, but even
now preparing a 50 MB exported mesh for rendering takes about 5
minutes.
Peter Popov
pet### [at] usanet
ICQ: 15002700
"Peter Warren" <int### [at] halcyoncom> writes:
> Very nice.
> Is that a bat?
Thanks, and yes. A bat with 100 inch radius.
I don't get it.
But then again I didn't get your statement about gifs either. Surrealism?
personal to me:
Are you sure that personal to you?
Jr is now #30
Is it because of your plans that you say jr is now 30?
Does it bother you that who will break 714?
Is it because of the people you hang around with that you are going through
all this?
Sigmund Kyrre Aas
On Mon, 21 Feb 2000 21:26:23 -0600, "Eric Freeman"
<eri### [at] datasynccom> wrote:
>They must have changed it... I just checked mine and it said I have 25 saves
>left (I haven't made anything good enuf to save yet).
I am seriously considering registering it. I'll have to see the terms
and conditions for a student's license and of course I'll have to
figure a way to pay (I hope they accept cash).
Peter Popov
pet### [at] usanet
ICQ: 15002700
"Peter Popov" <pet### [at] usanet> wrote in message
news:HqWyOM4Yx6HXaCziDQceHNvVKS0I@4ax.com...
> see the terms and conditions for a student's license
If I recall from reading their web page (emphasis on "if") it's just a
discount on price... same terms and conditions.
Eric
"The whole problem with the world is that fools and fanatics are always so
certain of themselves, but wiser people so full of doubts."
--Bertrand Russel
Anton Sherwood wrote:
> Sigmund Kyrre Aas wrote:
> > * How do I prevent the image maps from appearing at the reverse side?
> I haven't used image maps, but isn't there a cylindrical map type?
Yes. But then I have to make the maps 4 times bigger, cause they wrap all the
way around. And I like to keep memory usage down. I'm using a radial pigment
map now, just as Josh English suggested earlier in this thread.
sig.
Just realized how lame this post was. To defend myself, it was Dr. Emacs who
spoke, not me.
sig.
> personal to me:
> Jr is now #30
> all this?
> Sigmund Kyrre Aas
On Sat, 26 Feb 2000 10:53:29 +0100, Sigmund Kyrre Aas <as### [at] studntnuno> wrote:
4.7.8.9.1 The once Option
Normally there are an infinite number of repeating image maps,
bump maps or material maps created over every unit square of the
x-y-plane like tiles. By adding the once keyword after a file
name you can eliminate all other copies of the map except the one
at (0,0) to (1,1). In image maps, areas outside this unit square
are treated as fully transparent. In bump maps, areas outside
this unit square are left flat with no normal modification. In
material maps, areas outside this unit square are textured with
the first texture of the texture list.
For example:
image_map {
gif "mypic.gif"
once
Steve email mailto:sjl### [at] ndirectcouk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
10:52pm up 18:44, 6 users, load average: 2.00, 2.09, 2.10
A cylindrical image map will wrap all the way around the ball, regardless of
wether once is used. My png-s are covering an 40 deg. angle. To avoid they
getting stretched beyond recognition, I would have to make them looong.
sig.
> For example:
> image_map {
> gif "mypic.gif"
> once
> Cheers
> web http://www.ndirect.co.uk/~sjlen/
