Hello. Using the same method as before, and after having battled against the
limitations of the isosurface patch, here is the end result. Again, this is
just demonstrative, and so is relatively simple. This is a torus, with 4
boxes, 2 at the top and bottom and 2 at either sides. I hope you like it and
see the potential for this neat multiplication stuff.
PS: Yes, I had to forget about the cylinders to make it short enough. =(
Download 'boxblob.jpg' (40 KB)
Preview of image 'boxblob.jpg'
Hmm... cool! Looks like one blobs by addition and the next by subtraction...
So.... can we please see your code? I have got a few things to blob but I
don't quite have the idea yet.
TonyB <ben### [at] panamaphoenixnet> wrote in message
news:37f9dfe5@news.povray.org...
the
is
and
subtraction...
Well to be honest, I have no idea why it came out like that. I certainly
didn't expect it. I added the top-bottom ones first, and then the others,
which I expected to blob normally. The end result is what you see.
I'll post the source, although I don't see any need for that...
Thanks! and ... unfortunately... it was indeed needed. My math skills
are improving, but I still don't think in that language.
Well, here's my version after chopping up the function into smaller
pieces. I hit the isosurface function parser limit several year ago with
the version that couldn't parse user functions, so I had to wait a
couple of years before I could try some complex landscapes!
I'll put the code in p.t.s-f (and I'll just do a copy-and-paste this
time after getting a couple of agrieved posts for putting up
attachments) as a reply to the post there.
Bye for now,
Mike Andrews.
> [Image]
Download 'longfunc.jpg' (8 KB)
Preview of image 'longfunc.jpg'
Way to go! I'm sitting here trying to figure out how to do it myself. My idea was
to put all the boxes like this:
((box)|(box)|(box)|(box))
and then multiply the torus to it afterward. I've had success getting an even
result all-around, but the "blobbing" of the objects is not working out correctly.
Perhaps it is the funny torus I made:
(sqr(sqr(x)+sqr(y)-.75)+sqr(z*2)+.95)
I know I have blobbed torii together before, I just don't have the code anymore ;P
I think I will find another way to make a torus (or use the one off the isosurface
website ( http://www.public.usit.net/rsuzuki/e/povray/iso/ ).
> Bye for now,
> Mike Andrews.
> > [Image]
> [Image]
Samuel Benge
E-Mail: STB### [at] aolcom
Website: http://members.aol.com/stbenge
Here's one that works nicely, I think. It has a "seam" at the planes
where abs(x)=abs(y) but I'm not sure if there's anything I can do about
that. It's due to the maxes and mins. I'd post an image, but I don't
have anything here to convert it to jpg with.
#declare x1=-4; #declare x2=-2; #declare x3=-1;
#declare x4=1; #declare x5=2; #declare x6=4;
#declare y1=-4; #declare y2=-2; #declare y3=-1;
#declare y4=1; #declare y5=2; #declare y6=4;
#declare z1=-1; #declare z2=1;
isosurface {
function { max((z-z1)*(z-z2),
min(max((y-y1)*(y-y2)*(y-y5)*(y-y6),(x-x3)*(x-x4)),
max((x-x1)*(x-x2)*(x-x5)*(x-x6),(y-y3)*(y-y4)))) *
(z*z + sqr(sqrt(x*x+y*y)-3)-.25)}
threshold .1
bounded_by { box {-5,5}}
pigment {color rgb 1}
finish {diffuse .5 specular .3 ambient .2 roughness .001}
light_source { <-20,20,-20> rgb <1,.8,.8>}
light_source { <20,20,-20> rgb <.8,.8,1>}
camera {location <2,5,-12> look_at 0 }
