POV-Ray : Newsgroups : povray.binaries.animations : No image Server Time
4 Feb 2026 21:33:39 EST (-0500)
  No image (Message 1 to 10 of 43)
Subject: No image
Date: 26 Jun 2018 22:05:01
Message: <web.5b32f0c22078c5ce458c7afe0@news.povray.org>
Hi jr - I really thought I'd get to this sooner, but this ought to get you on
the right path.
#version 3.8;
// Code by William Pokorny, modified by Bill Walker (Bald Eagle) for jr
2018-06-26
// Animation settings - 50 frames, clock from -1 to 1
global_settings {assumed_gamma 1}
#include "functions.inc"
background {Black}
#declare Camera00 = camera {
     perspective
     location <3,3,-3.001>
     sky y
     angle 35
     right x*(image_width/image_height)
     look_at <0,0,0>
#declare White = srgb <1,1,1>;
#declare Light00 = light_source { <50,150,-250>, White }
#declare Red = srgb <1,0,0>;
#declare CylinderX = cylinder { -1*x, 1*x, 0.01 pigment { Red } }
#declare Green = srgb <0,1,0>;
#declare CylinderY = cylinder { -1*y, 1*y, 0.01 pigment { Green } }
#declare Blue = srgb <0,0,1>;
#declare CylinderZ = cylinder { -1*z, 1*z, 0.01 pigment { Blue } }
#declare Base = box {<-1, -0.51, -1>, <1, -0.5, 1> pigment {Gray10}}
#declare InvisibleObject = sphere {<0,0,0>, 0.5}
#declare InvisibleObjectMediaContainer = sphere {<0,0,0>, 0.6}
#declare S = 0.4;
#declare FnZero = function (x,y,z) {0}
//#declare Scanner = box {-S*<1, 1, 1>, S*<1, 1, 1>}
#declare Scanner = cylinder {-1*x, 1*x, 0.1 translate y*0.5 translate
-y*pow(clock,2)}
#declare FnScanner = function {pattern {object {Scanner}}}
#declare FnInvisibleObject = function {pattern {object {InvisibleObject}}}
// user_defined {FnRed, FnGreen, FnBlue, FnFilter, FnTransmit}
#declare ShowOverlap = density {
     user_defined {
         function { FnZero (x,y,z) },
         function { FnInvisibleObject (x,y,z)*FnScanner(x,y,z) },
         function { FnZero(x,y,z) },,
#declare Media00 = media {
     method       3
     samples      300
     emission     rgb <1,1,1>
     density {ShowOverlap}
#declare Clear100 = srgbt <1,1,1,1>;
#declare Texture00 = texture {pigment {color Clear100}}
#declare Interior00 = interior {ior 1 media {Media00}}
#declare Material00 =
material {
     texture {Texture00}
     interior {Interior00}
#declare ObjectMediaContainer =
object {
     material {Material00}
     hollow
//--- scene ---
    camera {Camera00}
    light_source {Light00}
    //object {CylinderX}
    //object {CylinderY}
    //object {CylinderZ}
    object {Base}
    object {ObjectMediaContainer}
Download 'scanner.mpg' (147 KB)
Subject: Re: No image
Date: 27 Jun 2018 13:15:01
Message: <web.5b33c4e3326cb273635cc5ad0@news.povray.org>
hi,
> the right path.
<code snipped>
wow, thank you very much.  that presentation video is .. natty.  :-)
looking at it all with an extra day's reflection, I now see that I ought to
learn walking before running.  </sighs>  so, the next steps will be using your
and WF Pokorny's code as starting points for "re-construction" to "fit" my aims.
 and this time it'll have to be systematic.  :-)
regards, jr.
Date: 27 Jun 2018 18:50:01
Message: <web.5b341412326cb273458c7afe0@news.povray.org>
Well, yes.  We all develop an individual style, and like they say - you should
stick with what you're good at   ;)
I figured I needed to hammer something functional out that would illustrate the
proof of concept, and I had like 20 minutes to do it...
Never any harm trying to hit the ground running, but sometimes if that doesn't
work, a slow, methodical working up from first-principles seems to be the best
way to achieve success.
Slow is smooth, smooth is fast.
You can't miss fast enough to win.
Sometimes the best thing to do is write a pseudocode / explanatory outline to
lay out the flow of things.   It also helps identify sticky spots, clarify the
order of operations, how things need to be defined, hierarchies, data
structures, how layers should be constructed, etc.
I can't tell you how many times I've answered my own question in the middle of
typing up a post trying to explain what I'm failing at doing.  :D
I'm hoping to get some free time to play with this some more and make something
a bit more refined   ;)
Date: 27 Jun 2018 19:21:16
Message: <5b341bec$1@news.povray.org>
Ditto.
dik
Rendered 328976 of 330000 (99%)
Date: 28 Jun 2018 09:30:03
Message: <5b34e2db@news.povray.org>
Am 28.06.2018 um 00:47 schrieb Bald Eagle:
Word.
Date: 28 Jun 2018 10:33:55
Message: <5b34f1d3$1@news.povray.org>
> Word.
Agreement?
(Is there a prize?)
Regards
Date: 28 Jun 2018 13:10:00
Message: <web.5b35150f326cb273635cc5ad0@news.povray.org>
hi,
visually v accomplished for a 20 minute "job".
there is one drawback, from my perspective, the lack of a second media which
interacts, otoh I now know that the animation related stuff can be taken care of
early, earlier than I thought.
not familiar with that phrase.  like: you can't win a race in the opening lap?
I'm too old to work on-screen exclusively.  :-)  but an outline, no matter how
detailed, cannot compensate for lacking .. in the basics.
yes, as the follow-ups attest, not an uncommon occurrence.  :-)
like, two media?!  ;-)
cheers.
regards, jr.
Date: 28 Jun 2018 15:15:04
Message: <web.5b353372326cb273c437ac910@news.povray.org>
I'd say it would have to be integrated from the start, due to the translations,
etc that are clock dependent.
What would the second media do?  Just produce a different color, and a third
color when all 3 overlap?  I'll give it a go - or you could just change my code
to make one media cylinder 100% red, and 50% green, and another media cylinder
50% green and 100% blue.  Then have them move in opposite directions, or easier
- just rotate one y*90.
It's more of a sporting activity referring to hitting the intended area.
Don't rush - take your time.  That makes things smooth.  The smoother it is, the
faster it will be when you speed it up.
You can be the _fastest_ person to miss the target 1000 times.... no score.
I have mountains of scribble paper, and sometimes use the 3 sides of a cardboard
box (x, y, z)
Unless you beat me to it.  :P
Date: 28 Jun 2018 16:10:48
Message: <5b3540c8@news.povray.org>
> You can be the_fastest_  person to miss the target 1000 times.... no score.
That reminds me of an article that I read years (decades?) ago. It was
times. The younger less experienced players with fast reaction times
would run and jump to catch the ball straight away. Whilst older players
would look and think before they did anything. More often than not the
older player would (statistically) be the better.
team. I think that is what it is called nowadays. We were certainly
taught to look before we leapt.
Regards
Date: 29 Jun 2018 12:05:01
Message: <web.5b36589a326cb273c437ac910@news.povray.org>
So, hopefully this works (completely untested) and it what you're looking for.
#version 3.8;
2018-06-26
background {Black}
     perspective
     sky y
     angle 35
     look_at <0,0,0>
#declare S = 0.4;
-y*pow(clock,2)}
#declare Scanner2 = cylinder {-1*x, 1*x, 0.1 rotate y*90 translate y*0.5
translate -y*pow(clock,2)}
#declare FnScanner2 = function {pattern {object {Scanner}}}
     user_defined {
         function { (0.5*FnInvisibleObject (x,y,z)*FnScanner(x,y,z)) +
(0.5*FnInvisibleObject (x,y,z)*FnScanner2(x,y,z))},
         function { FnInvisibleObject (x,y,z)*FnScanner2(x,y,z) },,
     method       3
     samples      300
material {
     texture {Texture00}
object {
     hollow
//--- scene ---
    camera {Camera00}
    object {Base}
