POV-Ray : Newsgroups : povray.binaries.animations : elastic cube, pov code, 800 kB Server Time
24 Mar 2026 22:48:42 EDT (-0400)
  elastic cube, pov code, 800 kB (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: elastic cube, pov code, 800 kB
Date: 16 May 2002 14:42:09
Message: <3CE3FD7D.B5CBF82D@gmx.de>
Gergely Vandor wrote:
> This one is pure pov code. I don't want to post the source yet, since it's
> ridiculously slow, unreadable and even somewhat buggy. :) At least it
> produces acceptable results now. Spring system, mesh. I'd like to create
> fluid anims too, but it will take some time.
I now managed to view it, looks very good.
How long did it take to calculate it?  I have started to simulate similar
objects with the same system used for the balls and it works well and does
not seem that slow until now.  What system do you use to connect the nodes
with springs?
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 16 May 2002 15:45:25
Message: <3CE40C35.55400D18@gmx.de>
After that Netscape-IE thingy was out, I was able to view it too...
Looks pretty nice, and I hope it doesn't take too long...
How about dropping it from a very high spot, how
would it bounce? Would it get a rotationalo momentum?
> (I hope links are OK in this group.)
> http://www.progressive.hu/gero/egybee.m1v
Tim Nikias
Email: Tim### [at] gmxde
Date: 16 May 2002 16:21:18
Message: <MPG.174e335417ab8560989700@news.povray.org>
In article <3CE3FC6B.E7700D09@gmx.de>, chr### [at] gmxde says...
> That's strange and somewhat disturbing.  Using IE worked, but with
> Netscape it did not.
Because IE doesn't care much about MIME-Types.
The server says it is text/plain, instead of video/mpeg or
application/octet-stream, (you can test this at
http://webtools.mozilla.org/web-sniffer/) so it is not Netscapes fault if
it trys to display it as text instead of showing the download dialog or
directly calling the appropriate viewing programm.
Lutz-Peter
Date: 16 May 2002 18:35:14
Message: <pan.2002.05.17.00.35.14.392875.3430@moravia-it.com>
>> it's ridiculously slow, unreadable and even somewhat buggy. :) At least
>> it produces acceptable results now. Spring system, mesh. I'd like to
>> create fluid anims too, but it will take some time.
Thanks. =)
> similar objects with the same system used for the balls and it works
> well and does not seem that slow until now.  What system do you use to
> connect the nodes with springs?
Did you use pov code for your system? If so, I'd really like to see it. :)
It took 5 mins on an 1400 MHz Athlon XP, which I consider slow, this
thing should be possible realtime on my machine. :) The five mins is a
guess, I did't even check.
System: In every "row", every second node is connected as well as the
adjacent ones, and every "sub-cube" has an X of springs on its sides.
The slowness is due to silly code (this is my first ever try at stuff
like this) and overkill (?) precision (20 steps/frame).
Cheers,
Gergely
Date: 16 May 2002 18:46:44
Message: <pan.2002.05.17.00.46.43.544814.3430@moravia-it.com>
> How about dropping it from a very high spot, how would it bounce? Would
Sure, check this: http://www.progressive.hu/gero/drum.m1v
This is an earlier and simpler version, not really elastic. :)
I guess the current cube would start to "shake" at a very high pace in a
similar situation, unless I implement correct spring damping.
Cheers,
Gergely
Date: 16 May 2002 18:50:58
Message: <pan.2002.05.17.00.50.58.73314.3430@moravia-it.com>
On Thu, 16 May 2002 20:37:31 +0200, Christoph Hormann wrote:
>> worked fine here with team of NT 4, MP 6.4 and IE 5
With the current Mozilla I can't even access the http news interface.
The "Enter the newsgroups" button simply doesn't do a thing...
Gergely
Date: 17 May 2002 00:49:12
Message: <3CE48BA9.565D2D8@gmx.de>
That's pretty neat. Do a larger version
of that one with more elasticity (nodes),
that'd make an interesting animation.
Can several of these interact, or not?
Probably not at an early stage like this...
> Cheers,
> Gergely
Tim Nikias
Date: 17 May 2002 05:16:15
Message: <3CE4CA62.8CB5D1F8@gmx.de>
Yes, it works a lot with functions so it's probably quite difficult to
understand.
I would not call this slow, the recent 12 balls animations usually parse
about 10 seconds per frame and render 5 seconds on a K6/500.
I don't really understand that description, do you use any 3D diagonal
springs?  Maybe just render a still with cylinders where the springs are.
How did you model damping?
Date: 17 May 2002 11:21:53
Message: <Xns9211B0A04A1ABgergelyvamoraviaitco@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3CE4CA62.8CB5D1F8@gmx.de:
> parse about 10 seconds per frame and render 5 seconds on a K6/500.
So it's probably faster than mine, while it's at least as complicated, or?
:) It's the parse time that I consider relevant here.
> are. How did you model damping?
There are no 3D diagonal springs. I'll try to describe the system again :)
So there are diagonal springs on the sides of the subcubes (if you look at
the anim, the cube is made up of 4*4*4=64 pieces of what I call subcubes).
Also if you start from a corner, and go any direction, the first node is
connected with the second *and* the third as well, and so on. (The second
is connected with the third and the fourth, etc.) This is something I read
about in a paper about cloth simulation somewhere. I hope it's more
understandable now, it's not that easy to explain for me. :)
Damping is not really modelled. :) I just multiplied the speed of every
node with a value like 0.9995 or something at every timestep. If you have a
better solution for spring damping pleeeeeaaase let me know. :)
It would be interesting to use the inside macro at the beginning of things,
so with a high number of nodes one could make elastic objects of any shape.
:) Maybe that will be my next project.
I also faintly remember that Hooke's spring constant is in fact *not*
constant when the length of a spring changes beyond a certain point. And
I'd like to try objects with different stiffness at different points...
Physics can really be fascinating. :)
Cheers,
Gergely
Date: 17 May 2002 11:45:05
Message: <3CE52586.FFFA0372@gmx.de>
Not really since i don't know how you number the nodes, but from this and
the last post i conclude you have the cube grid of axis parallel springs
connecting neighboring nodes and two diagonal springs forming an 'x' on
every elementary 'square' in the system.
I have on paper, but i did not yet have success implementing it
('exploding' cubes are funny, but not really useful...)
For materials like rubber there is not much linear elasticity anyway,
metals can be modelled as linear until they experience permanent
deformation (which would also be interesting to model BTW).
