![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Archer - Charcter study 03 kbbu MPEG
Date: 17 Jul 2000 15:33:55
Message: <39735fa3@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I made an Blobman-Archer by 'hand-posing' 70 Frames. As usual I'm not
satisfied with this and I don't even know if it is worth he effort to tweak
one frame or another or if it's better to start a completely new sequence.
So tell me what you think and don't hold back with criticism, please.
Marc-Hendrik
Download 'bogen.mpg' (94 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well I guess that leaves Moray out for doing any IK with it, since he is a
"blob" man. I'm not sure though what Moray might be able to do with it.
Perhaps a stand-in set of primitives and then use the transformations you get.
Could be difficult to transfer.
It didn't look terribly bad to me, a little jerky is all; but hey, that goes
for many things I've seen or made myself.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
i thought you could import blobs into moray, you just couldn't make
them. i'm not sure what that implies, however, as i haven't done it
myself. so why is the archer left-handed?
> Bob
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's very good. I commend you for trying. You might want to use splines
for controlling the movement. It would make things easier for you.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Archer - Charcter study 03 kbbu MPEG
Date: 18 Jul 2000 00:00:49
Message: <3973d671@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Marc-Hendrik Bremer" <Mar### [at] t-online de> wrote in message
news:39735fa3@news.povray.org...
> Hi,
Holy cow! If there's an award for perseverance, you get it!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Hi,
I hand posed a 200 frame animation when I first started using POV-Ray.
That was before the clock variable was available and you had to have
a seperate .pov file for each frame of your animation. My how times
have changed...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 18 Jul 2000 02:18:11
Message: <3973f6a3@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Remember RTAG (Ray-tracing Animation Generator)? Pretty sophisticated, in
it's day, a complete C-like language, entirely replaced by the simple clock
variable. (And of course, the new mathematical functions!)
-Dave
"Ken" <tyl### [at] pacbell net> wrote in message
news:3973D900.CF432DE5@pacbell.net...
> > > Hi,
> have changed...
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -Dave
RTag ? Why of course. I even have a link to it :)
http://sandh.com/__bbs__/share.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Ken" <tyl### [at] pacbell net> wrote in message news:3973D900.CF432DE5@pacbell.net...
| have changed...
Egad! And no math available either? At least I don't think there was before the
clock arrived.
Nor any directives like #if #while #switch #range etcetera, all of which would have
been tedious
to do without.
Separate files per frame sounds almost laughable, especially now so far removed from
that old a
version. I must've been in my 3D-raytraced playpen still back then, metaphorically
that is.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 18 Jul 2000 17:13:14
Message: <3974c86a@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Was not that much work. I used the Blob Man Studio to make the starting- and
end-pose, after that it was stupid work to increment this angle and
decrement another. At first I wanted to automate it, but it turned out to be
a little more complicate so I had to control every pose and correct the
left-hand position (even now the fingers often don't even touch the string).
After posing I just copied the array with the joint angles in one array
which I now access using the clock-variable.
Marc-Hendrik
Dave Blandston schrieb in Nachricht <3973d671@news.povray.org>...
>> Hi,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
