POV-Ray : Newsgroups : povray.binaries.animations : An old one. Filling a container. Server Time
13 Oct 2025 18:51:31 EDT (-0400)
  An old one. Filling a container. (Message 1 to 10 of 15)
Subject: An old one. Filling a container.
Date: 21 Jul 2002 13:20:31
Message: <3d3aed5f@news.povray.org>
I just revisited the *balls filling a container* simulation to test my new
programming skill (hehe just passed my C exam).
While it's not perfect (some balls clearly intersect) it does the job. The program
took ~20 min to calculate 800 frames (30 iterations per frame, 400 balls and ~10
millions collisions). Then each frame took about 9 sec to render with POV.
http://digilander.libero.it/jrgpov/anim/palline.avi (2.7 MB divx 5).
Jonathan.
Subject: Re: An old one. Filling a container.
Date: 21 Jul 2002 14:00:28
Message: <3D3AF6BB.1F0A46E6@gmx.de>
Nice, could you have a few more words on the algorithm used? How do you
handle multiple simultaneous collisions of one ball?
Last updated 15 Jul. 2002 _____./\/^>_*_<^\/\.______
Date: 21 Jul 2002 15:12:15
Message: <3d3b078f@news.povray.org>
I've done this before, without intersections, but 20 minutes for 800 frames
* 30 iterations is very impressive. My algorithm takes about 30 seconds per
frame with *one* iteration, though that iteration catches every intersection
and handles it correctly.
 - Slime
[ http://www.slimeland.com/ ]
Date: 21 Jul 2002 16:47:20
Message: <3d3b1dd8@news.povray.org>
I have to say that the real fun was to handle the vector structs and functions... the
algorithm itself (which I shamelessly copied from my previous POV coded version) is
rather banal. A simple and not too optimised O(N^2) algorithm:
1) For frame = 1 to final_frame.
1.1) For iteration = 1 to num_of_iterations.
1.1.1) For ball = 1 to balls (frame).
1.1.1.1) Update positions and velocities.
1.1.1.2) Check collisions with walls and floor.
1.1.1.3) For other_ball = ball +1 to balls (frame)
1.1.1.3.1) Check collision with other_ball.
That's it. As you can see, I do not handle simutaneous collisions at all. One ball
can collide with another one. After that (point 1.1.1.3.1) its velocity gets updated.
Then it can collide with another ball during the same iteration. The new collision is
treated just as the other one, but with the updated velocity vector.
The main problem is to handle the balls staying one on each other. They rather tend
to *sink*, because the top balls tend to go down for the gravity acceleration while
those on the bottom of the container cannot sink anymore. I've used some trick to
avoid this: for example after a collision loop I save the mean of the distances (a
vector) between the ball considered and those which it collided with, and do not
consider the component of the acceleration along that vector during the next
iteration. This trick helped a lot but it's still not enough.
Any idea? I can post any code you want, but it's pretty ugly :)
Jonathan.
Date: 21 Jul 2002 16:54:49
Message: <3d3b1f99@news.povray.org>
Ouch... the 10 iterations version (which looked pretty much the same...) took 409
sec... (debug not optimised version compiled with Visual Studio) so about half a
second per frame (actually the first hundreds frames get calculated in a
*phhheeeww*).
Anyway my algorithm cannot prevent *every* intersection right now, so it would be
great if you could give me some tips about the one you used. BTW I couldn't enjoy
your anim... just  a single still boring frame...who knows why.
Jonathan.
Date: 21 Jul 2002 18:46:38
Message: <3d3b39ce@news.povray.org>
took 409
half a
> *phhheeeww*).
would be
couldn't enjoy
Ooooh, you wrote this in C++? No wonder it's so fast. Mine's in POV-SDL =)
mainly so I can use the trace() function.
The algorithm basically works like this, for each iteration:
1. find every possible collision that will occur during this iteration
2. take the first collision and react to it, advancing all the balls the
amount of time that has passed
3. repeat until there are no more collisions during this iteration
Now, it doesn't work exactly like that; if it did, it'd be about 10 times as
slow. I've optimized it in various ways, but that's the gist of it. (the
main optimization is only checking for collisions involving balls that have
had collisions earlier during the current iteration, or which *will* have a
collision sometime during the iteration. That is, if a ball is found to have
no collisions during the iteration, ignore it in subsequent loops until the
next iteration.) Hard to explain, as you can see.
 - Slime
Date: 21 Jul 2002 19:25:21
Message: <3d3b42e1$1@news.povray.org>
Yeah, no in C, but hey I told you that :). The POV version was basically the same
thing and, according to my previous post, the last frames took about 9 sec to parse
(200 balls, 10 iterations per frame).
I see. What I don't understand is how this prevents any intersection to happen. I
mean: a collision happens when the distance between two balls (their centres) is
smaller than the diameter of the balls. Now what I do is to update their velocity
vectors accordingly, but their positions don't get touched. That's why intersection
is still possible in very specific cases. Now, do you *fix* the position after a
collision has been detected?
I would like to see your algorithm used to fill up a container just like this, for
comparison :-)
Jonathan.
Date: 21 Jul 2002 21:27:17
Message: <3d3b5f75@news.povray.org>
happen. I
centres) is
velocity
intersection
after a
Yes. Let's say I have a system with two balls. Imagine this now: One ball is
at (0,0) and is heading towards (1,1). The other ball is at (1,0) and
heading towards (0,1). Assume their radii are extremely close to zero.
They're going to bounce off each other at time=0.5 (assuming time=1 is the
end of the iteration, when they reach their destinations).
I detect the collision at t=.5. I then figure out their new velocities. (In
this case, their velocities will simply be swapped, I believe. Or something
like that. Let's say for simplicity that they swap their velocities.)
Then I place the balls at (their current starting position) + (.5*(their old
velocity)) - (.5*(their new velocity))
Their new position is at (1,0) and (0,0), respectively. In this example,
they happen to have swapped starting positions.
Now that I've taken care of that intersection, I ignore any intersections
that occur at t <= 0.5. That way I won't detect their collision again. And
at the end of the iteration, I just add each balls' velocity to it's
position, so the first ball ends up at (0,1) and the second at (1,1).
Did that make sense?
Before long, I'll work on the code and make a new example for you. But not
now... Warcraft III takes priority =) (two levels left! I think.)
 - Slime
Date: 22 Jul 2002 03:36:16
Message: <3D3BB5F0.71E35DBC@gmx.de>
updated.
is
I see.  By updating velocities you probably mean mirroring the velocities
at the normal vector (minus damping factor).
You probably should have a look at some literature about numerical
integration.  Totally avoiding balls overlapping isn't possible with most
methods, but it is not necessary.  You just have to make sure that when
balls overlap there is a force driving them away from each other.
Date: 22 Jul 2002 15:15:34
Message: <3d3c59d6@news.povray.org>
ball
updated.
collision is
Exactly.
tend
while
(a
> integration.
Actually I've just studied numerical calculus at University... but didn't take the
exam yet (I'll probably do it in september) so I still have to read through my papers
before doing something useful with the new notions I have... :-)
Yeah, that's the other way round :) I didn't take into account *forces*, just gravity
acceleration and collisions. Anyway I'll look into it deeplier as soon as I have my
calculus exam done.
Cheers,
Jonathan.
