Seeing all the animations with nice water surfaces I thought I'd make my own
test. :)
What do you think?
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Mar 19)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
Download 'ripples.mpg' (507 KB)
wow
PGP Public Key
Subject: Re: water: test with ripples (506kbu)
Date: 14 Apr 2002 09:31:14
Message: <3CB984A2.DBFC7622@gmx.de>
> test. :)
I'm not sure if the waves around the moving stick are that realistic, but
the interaction with the walls looks promising. Some technical details
would be nice.
Last updated 11 Apr. 2002 _____./\/^>_*_<^\/\.______
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3cb96c33@news.povray.org...
own
> test. :)
No fair using a particle system!
> What do you think?
Really good.
I remember some 5 (?) years ago when I first figured out #while
statements and I said that Pov would soon be capable of modeling any
possible physical interaction.
I didn't think we would be so near that goal so soon...
> that realistic, but the interaction with the walls looks
> promising.
I agree. The waves around the moving stick were a difficult problem that I
haven't been able to solve that well so far. When the stick is non-moving
the waves look more realistic, but I thought I'd try the challenge of having
it move around...
> Some technical details would be nice.
I took basis in the algorithm described here:
http://freespace.virgin.net/hugo.elias/graphics/x_water.htm
The waves reflect off the sides of the rectangular area completely
automatically due to the way the algorithm work, so adding support for a
custom map of blocking walls proved to be very simple and the map can be any
black and white bitmap.
The disturbance that initiates the waves is not described on Hugo's page. I
tried using a raised cone like shape for the disturbance, but other
variations may give better results.
I have quite some other projects to work on, so I probably won't take this
further, but if anybody else feel like making more experiments it would be
very interesting.
Rune
I wondered if anybody would say that... :)
Well, I didn't use a particle system. For this task a particle system would
be rather useless, and especially mine, which doesn't support inter-particle
interaction.
For details on how it's done, see my reply to Christoph.
> Really good.
Thanks!
Rune
By the way, I haven't looked at the code (and can't, since I only know
POV-script), but I think that the 2D Water Effects on this page use
basically the same algorithm:
http://www.darwin3d.com/gdm1999.htm#gdm0499
At least it also has the characteristic not-quite-circular ripples produced
by that algorithm.
Rune
Date: 14 Apr 2002 11:43:46
Message: <3CB9A3B3.8E7AE5C6@gmx.de>
> very interesting.
Although it is a fairly simple model, results seem to be quite good. What
resolution do you use for the grid? Is it implemented in POV SDL? You
only have rectangular walls, does it work correctly with diagonal
boundaries?
Last updated 14 Apr. 2002 _____./\/^>_*_<^\/\.______
> be quite good. What resolution do you use for the grid?
Only 50x50.
It's written in POV SDL.
> You only have rectangular walls, does it work correctly
> with diagonal boundaries?
Yes, the waves adapt to any wall arrangements pretty realistically. I've
just posted a new animation which shows this.
Rune
Hi. I'm trying to look at the page you mentioned
in your post, but I always get a 404 error, the
page is missing or something like that. Do you have
the page with the algorithm description offline some-
where and could send it via ZIP and email to me?
Thanks in advance,
Tim
Tim Nikias
Email: Tim### [at] gmx de
