POV-Ray : Newsgroups : povray.binaries.animations : Grass texture test 2 Server Time
6 Feb 2026 13:36:08 EST (-0500)
  Grass texture test 2 (Message 1 to 8 of 8)
Subject: Grass texture test 2
Date: 28 Mar 2002 15:11:11
Message: <3ca378df@news.povray.org>
I've managed to add turbulence to the grass texture without wrecking the 3d
illusion.
Besides that I've tweaked the color and thickness of the blades of grass.
That's it basically...
Now working on making an include file out of it.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Download 'fgrass2_test2.mpg' (483 KB)
Subject: Re: Grass texture test 2
Date: 28 Mar 2002 15:17:45
Message: <3ca37a69$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3ca378df@news.povray.org...
3d
> illusion.
    This is astounding, to think that this is a texture and not a mesh or
something!
Date: 28 Mar 2002 16:37:01
Message: <3CA38D05.42AD88CE@gmx.de>
This definetely looks better!
Though I still think that placing objects on that sort
of grass looks a little odd. It is good all by itself,
but if there is some possibility, you should look if
you can get something with transparent layers to
make objects "fade" into the grass.
But those matters aside, it looks terrific!
Tim Nikias
Date: 28 Mar 2002 19:12:14
Message: <3ca3b15e@news.povray.org>
looks good!
Hmm...  Looks VERY good! :)
Am I wrong, or could this technique also be used to simulate fur?
cu!
Date: 28 Mar 2002 19:16:12
Message: <3ca3b24c@news.povray.org>
"Zeger Knaepen" wrote:
> looks good!
Thanks! :)
No, it would require me to have access to the normal of a surface inside a
function, just as I currently have access to the intersection point. :(
Rune
Date: 28 Mar 2002 19:33:03
Message: <3ca3b63f$1@news.povray.org>
hmmm, too bad...
cu!
Date: 30 Mar 2002 11:13:03
Message: <3ca5e40f@news.povray.org>
I was about to say that! It just needs scaling to be smaller (I think)
a
> hmmm, too bad...
trace() can give normal vectors
__________________
 RAY
Date: 30 Mar 2002 12:34:13
Message: <3ca5f715$1@news.povray.org>
But I can't use trace() inside a function, now can I...! ;)
Rune
