POV-Ray : Newsgroups : povray.binaries.animations : Particle matrix effect with I/O (277kb mpg) Server Time
31 Mar 2026 02:41:22 EDT (-0400)
  Particle matrix effect with I/O (277kb mpg) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Particle matrix effect with I/O (277kb mpg)
Date: 31 Oct 2002 19:26:51
Message: <3DC1CA38.40301@yahoo.com.au>
Tim Nikias wrote:
> Matrix was used to refer to the bullet-time effects
> of the movie "The Matrix", not the matrix of
> POV...
> And he couldn't have used mine, cause he used an I/O
> system (its in the headline) and mine is non-I/O. People
> always forget that (or never know)... :-)
I remember this only because the non-I/O approach is so different to my own.
MJL
Date: 31 Oct 2002 20:02:29
Message: <3DC1D28B.5010303@yahoo.com.au>
Tim Nikias wrote:
> I knew that it can be done. After all, I/O may be
> modelled in such a way that particle may move
> slower and slower until they stop, its just the
> velocity and gravity have to be influenced appropriately
> as not to negate the realistic effect.
> But, is it possible for your system to run backwards?
It should be able to run backward. I'll have to try.
> But sometimes you want nice, easy and intuitive
> algorithms and setups, and then its sometimes the
> best idea to model programs to fit a certain task.
Yes, I can't agree more here. This was the first time in about 6 months that I
touched my particle system. It was a little more difficult to get back into it
than I had hoped.
> And I do like the animation, though it should go a
> little longer to see the balls drop, and they should
> be stretched a little from speed, like you can see
> in some of Rune's animations (IIRC) and Chris'
> System, and last of all, mine. :-)
Thanks. I think stretching is quite redundant on what is essentially a simple
test, though.
MJL
Date: 31 Oct 2002 20:59:31
Message: <3dc1e003$1@news.povray.org>
Nice.  Would be interesting to see how they bounce on out.  Can they remain
stationary on the floor?
Date: 1 Nov 2002 00:00:55
Message: <3dc20a87@news.povray.org>
Hmm maybe the camera then needs to gradually move into and out of its
rotation.  Rather than a fixed speed?
Date: 1 Nov 2002 14:49:42
Message: <3dc2dad6@news.povray.org>
I loved The Matrix, and I really rather like this test anim too! Nice work.
Andrew.
Date: 2 Nov 2002 21:41:32
Message: <3dc48cdc$1@news.povray.org>
Slowing down to a stop I can understand, but I can't see how you can
make it run backwards, without having to recalculate everything from
scratch in those frames that run backwards (which would parse very
slowly). Unless of course you save the data for each calculation step so
that you have at once the data for the entire simulation, as opposed to
just for one frame at a time. But that can require quite big amounts of
space for simulations with many particles...
Rune
rune|vision:  http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
Date: 3 Nov 2002 17:55:30
Message: <3DC5A95B.8030709@yahoo.com.au>
Thanks you!
MJL
> Andrew.
Date: 3 Nov 2002 18:31:22
Message: <3DC5B1C2.20802@yahoo.com.au>
I haven't tried it yet (hopefully will in a few days), but assuming
V(new) = V(old) + Acceleration*Delta_Time
P(new) = P(old) + V(new)*Delta_Time
I cannot see too much trouble with negative Delta_Time values so long as the
Acceleration term is constant. Environmental collisions shouldn't be too much of
a problem either. Am I missing something here?
As for saving particle data for each frame, I do this sometimes to make
re-rendering a slow-parsing animation faster (eg. if I want to change how the
particles are textured). I can typically save data for 1500-2500 particles before
the data files get larger than a 320X240 frame saved in an uncompressed format. I
don't see this as a major problem considering hard disk sizes nowadays.
MJL
Date: 3 Nov 2002 19:34:44
Message: <3dc5c0a4$1@news.povray.org>
> but assuming
> values so long as the Acceleration term is constant.
Well, to have it work accurately, you have to slow down the rate of the
calculation frames themselves, not the Delta_Time. (I think.)
For a small simulation, simply changing the Delta_Time may seem to work
perfectly, but imagine having a simulation running for 10 seconds, then
going 10 seconds backwards. (Or if you need a more extreme example, make
it one minute both ways.)
The small precision errors can accumulate very much in such a situation,
so you have no guarantee that the particles will end up at exactly the
same positions where they started. And if they can end up a little off,
then they can also end up completely off, given a more complex case.
> before the data files get larger than a 320X240
> frame saved in an uncompressed format. I don't
> sizes nowadays.
2500 particles for how many seconds and with how many steps per second?
And how much data do you have per particle per step?
Rune
Date: 3 Nov 2002 22:32:06
Message: <3DC5EA2F.9010905@yahoo.com.au>
>>but assuming
Using Newton's method (which is what I use) requires a large number of
itterations for accuracy anyway.
For each frame in an animation, I have a variable called Time_Step which is the
amount of time which has passed since the last frame in the animation. The value
of Delta_Time used in each itteration of the calculation depends on both the
number of itterations specified, and the value of Time_Step.
I am well aware of this problem. There is even the concern that you have not
inadvertantly rounded off some important significant figures when saving the data
  between frames.
I do not consider my particle system to be a rigorous physics simulation by any
means. It was designed to automate some effects that I wanted to animate, and for
this it has generally suceeded. If I wanted a more accurate system, I would
probably look into Runge-Kutta methods for solving particle positions.
>>sizes nowadays.
One 320X240 frame bitmap ~ 226kb. Typically, I save particle position, velocity,
age, and mass. On average, each particle uses about 90 bytes to store this
information, and that's about 2500 particles to give a file size equivelent to
the bitmap for that frame.
Saving particle data for each itteration is redundant for re-rendering purposes;
all that is required is the data from the last itteration. If you are doing a 1
minute animation at 25 fps, you'd generate ~ 330 Mb of bitmaps, and 330 Mb of
particle data. I really don't see this as a problem when (a) hard drive sizes are
measured in gigabytes now, and (b) if you wanted to keep the particle data for a
long time, you could create a zip with good compression because the files are
just ascii.
MJL
