POV-Ray : Newsgroups : povray.binaries.animations : Matrix-Effect with PartixGen... (466kb, MPG) Server Time
16 May 2025 09:58:16 EDT (-0400)
  Matrix-Effect with PartixGen... (466kb, MPG) (Message 1 to 5 of 5)
Subject: Matrix-Effect with PartixGen... (466kb, MPG)
Date: 4 Jun 2002 23:13:03
Message: <3CFD817D.40C3D4C8@gmx.de>
So, here it finally is, after some hours rendering time...
The original "Magic Beam" (posted a few days ago) was
used as base. The System-Internal-Clock was modified
to slow down after a second, pause, and then speed
up to normal speed again.
Thus, the original five second animation is stretched to
nine seconds.
The camera was animated by running the location along
a Bezier-Spline, calculated using my macros.
Now, I've just got to find some useful approach to
show off movement backwards in time...
Suggestions, comments, whatever, everything is
appreciated...
Tim Nikias
Email: Tim### [at] gmxde
Download 'mb_timed.mpg' (453 KB)
Subject: Re: Matrix-Effect with PartixGen... (466kb, MPG)
Date: 5 Jun 2002 02:19:02
Message: <3cfdad56@news.povray.org>
That's beautiful! *Very* pretty.
Two things strike me as odd or needing improvement:
1. when time speeds up after the slowdown, it seems to speed up too slowly.
If you're going for the matrix effect, I'd have it return to normal speed
over a *much* shorter period of real time.
2. The smoke trail disappears too quickly, IMO. I think the clouds need to
become larger and more invisible before fading away so quickly, otherwise it
creates a strange effect when they disappear at the same speed and direction
as they appeared in. Maybe you preferred this way to avoid long render
times.
 - Slime
[ http://www.slimeland.com/ ]
Date: 5 Jun 2002 04:23:02
Message: <3CFDCA56.62AB98A1@gmx.de>
Thank you!
I would be easy to do that, but I like it the way it is, at least for this
animation. Perhaps I'll do another, moe complicated one sometime.
> times.
You're right, it prevented long render times (though they are long anyways),
but I'll tweak it and try to achieve something better. I don't like that
ugly trailing effect (when particles disappear as they've come) either.
Thanks for your suggestions!
Tim Nikias
Date: 5 Jun 2002 09:18:59
Message: <3cfe0fc3$1@news.povray.org>
Cool, that'a pretty much like I imagined it. :)
Only, I think it would look better if the camera rotated more (not for
longer time, but faster).
Maybe after the animation is finished, it could rewind back to the start
very quickly.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 5 Jun 2002 10:08:28
Message: <3CFE1B3F.FE5F72CF@gmx.de>
Thanks!
Yeah, perhaps... I'm working on some enhancements right now...
> very quickly.
I should have a blinking "rewind" button somewhere then, shouldn't I? ;)
Tim Nikias
