POV-Ray : Newsgroups : povray.binaries.animations : particle smoke (358kb mpg) Server Time
29 Mar 2026 05:25:40 EDT (-0400)
  particle smoke (358kb mpg) (Message 11 to 16 of 16)
Subject: Re: particle smoke (358kb mpg)
Date: 18 Mar 2002 07:05:18
Message: <3c95d7fe@news.povray.org>
Port the script to C or Perl, and you'll surprised how fast your computer
can calculate the animation data.
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoocom
Date: 18 Mar 2002 11:36:19
Message: <3c961783@news.povray.org>
"Mark James Lewin" <m_j### [at] yahoocomau> wrote
> Reading data for 2000+ particles from file, calculating their next
positions, and
> writing them back to file is not a fast process. There comes a point where
the
> time needed for parsing thousands of particles becomes greater than
rendering a
> few dozen media filled spheres. And unfortunately, this type of smoke sim
needs
> _really_ high particle counts.
yeah - after I posted I started writing my own version and it's kinda-sorta
slow and doesn't look as good as yours
jim
Date: 18 Mar 2002 16:09:30
Message: <3C9656A9.53EF280A@yahoo.com.au>
Unfortunately, I don'y know either of these languages :-( Perhaps one day...
MJL
prism{0,.1,30#local I=1;#while(I<30)#local B=asc(substr(// Mark James Lewin
"#K?U_u`V[RG>3<9DGPL.0EObkcPF'",I,1))-33;<div(B,10)-4mod(B,10)+5*div(I,21)-
6>#local I=I+1;#end,-4pigment{rgb 9}rotate-x*90translate 15*z}//POV-Ray 3.5
Date: 18 Mar 2002 16:32:09
Message: <3C965BF8.CC5139B2@yahoo.com.au>
Hugo wrote:
> > 1800 particles tests my patience
> I don't think that sounds like a whole lot.. That shouldn't take more than a
> second to parse / recalculate..?
> Regards,
> Hugo
I am using pov script here. I would use a faster language if I knew how to
program in it. Ideally I would make my own patch for pov, but this is well beyond
my capabilities.
MJL
Date: 18 Mar 2002 16:58:15
Message: <3c9662f7@news.povray.org>
You need more particles <G>
Seriously, if you want me to take a crack at a particle plug in for Moray, I
might be able to convert it to C++.
Also, I wonder if this could be used for 'heat shimmer'. I was trying to
duplicate something a while ago with a hot exhaust that doesn't have smoke;
I was using spheres with some IOR set to them.  Do you think this would
work?
                  == John ==
"Mark James Lewin" <m_j### [at] yahoocomau> wrote in message
news:3C95105D.BA4A1E76@yahoo.com.au...
> I was fixing my wind algorithm over the weekend, and decided to try some
smoke.
> Instead of the usual media filled spheres, or cunnngly textured spheres, I
> decided to try and use _lots_ of small spheres, just to see how it looked.
> There are about 1800 particles in any one frame (except the first few, of
> course), being blown about by a very turbulent wind. The texture is simply
rgb
> 0.5 with a transmit component based on particle age.
> Doing smoke this way is slow and not terribly effective; I think many more
> particles are needed to pull the effect off. See what you think.
> MJL
Lewin
3.5
Date: 18 Mar 2002 18:42:24
Message: <3C967A80.C5E14F09@yahoo.com.au>
I don't use Moray, but thanks for the offer. At this stage though, I'm not
satisfied with the behaviour of some aspects of my system.
> work?
Possibly. It might be slow. If you only wanted the 'shadow' of the heat, you
could try no_image spheres. It'll be faster.
MJL
