![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
what did you convert to mpeg with and what setting did your render from
within the anim plug at ??
"Mikael Carneholm" <sa9### [at] ida utb hb se> wrote in message
news:38B020BE.1D246341@ida.utb.hb.se...
> Hi;
> This is my somewhat sparsely furnished apartment, or at least - a
> virtual version. Modeled in 3D Home, textured/animated/rendered in Moray
> using POV-Ray. It suffers quite hard from MPEG compression, but it had
> to be done in order to keep the size down. Note: it was mostly a test of
> the animation plugin, that's why I haven't put so much work on the
> lightning/detailing/texturing.
> Mikael Carneholm
> Dep. of Computer Science and Business Administration
> Personal homepage:
> http://www.studenter.hb.se/~arch
> E-mail:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I rendered at 24 fps within Moray, generating separate TGA images. Those were
compressed into AVI with Fast Movie Processor (Radius codec) and then
converted to mpeg with avi2mpg1 (at 15bytes/s). If I was more accustomed to
cmpeg I would have used it, as there is some quality loss in each step in the
current procedure (I guess).
Mikael Carneholm
Personal homepage:
E-mail:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Have you seen and tried my Windows frontend to CMPEG at http://stols.net ?
Sander
Mikael Carneholm <sa9### [at] ida utb hb se> schreef in berichtnieuws
38B0FB52.24470561@ida.utb.hb.se...
were
to
the
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What's 3D-Home?
Markus
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, but not the latest version (I believe there was an older version which was
incapable of long file names?). I will try it for my next version of the
apartment animation, when I'm not in a hurry to get it out the door ;-)
Mikael Carneholm
Personal homepage:
E-mail:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Markus Becker wrote:
> What's 3D-Home?
I believe that was the name of the program - '3d home' or '3d home architect'
or something like that; I used it on a friends computer during the christmas
holiday and exported a .dxf file which I brought home on a ZIP disk. It was
however very easy to model the apartment, just click & draw to make the walls
and lots of ready-made furniture to place in the drawing. If you want, I can
ask him what the exact name of the program was.
Mikael Carneholm
Personal homepage:
E-mail:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <38B020BE.1D246341@ida.utb.hb.se>, Mikael Carneholm
<sa9### [at] ida utb hb se> writes
>Hi;
>[ A MIME video / mpeg part was included here. ]
WOW, I haven't looked at Moray or the animation plugin but I may now
have to. I have though about doing something like this a few times but
it always seemed like a huge project to do so I never started it. How
did you get the great camera movement. Reminds me of the rendered
movement from 7th Guest.
David Parrott E-mail: xam### [at] quayles1 demon co uk
ICQ: 13313977
Website: On it's way
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Just pointing and clicking....using the cubic interpolation of the animation
plugin, this is what it looks like. It's "classical" key framing - i.e., you
just pose the camera as it should be at a certain frame, and the
interpolation will take care of the rest.
I really recommend Moray....it is starting to look really, really good! (IMHO
- but then, I'm also a registered user! =) )
Mikael Carneholm
Personal homepage:
E-mail:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm...
Sander
Serge LAROCQUE <sgl### [at] hotmail com> schreef in berichtnieuws
38B24E3B.DF727905@hotmail.com...
> Here is the step-by-step way of using cmpeg:
> 1. make a folder called 'creation' (or whatever, just a place where you
keep a
> copy of cmpeg.exe and *.ctl files, so you don't delete your originals
> 2. move all your targa image files into that directory
> 3. start a DOS session; cd into the above directory;
> 4. dir /b /on file???.tga > name.txt
> example: orbit01.tga, orbit02.tga.... orbit10.tga --> orbit??.tga
> 5. cmpeg -v1 -f2 ipb.ctl name.txt anyname.mpg
> v1 means level 1 verbosity, f2 means 24 fps
> ipb.ctl is a parameter file, you can replace with i.ctl, pvrg.ctl.
pvrg.ctl seems
> to give better quality, with slightly larger file
> 6. done!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I agree, that is a little unusual, too pedantic perhaps. I will
consider removing this.
Thanks for your constructive criticism.
Sander
38B### [at] hotmail com...
> Ah, I see now, you're writing the cmpeg front-end :)) I'm not competing
> with you, just explaining a little.
> In fact, I tried CMPG and it's ok, I didn't like the fact that when you
> click on the button for the filelist, then it won't let you out when you
> click on cancel.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
