![](/i/fill.gif) |
I've read in some animation books about the importance of easing in and out.
So I wrote an algorithm where the position is along striaght lines, but
moves as per 3*x^2-2*x^3 between the points. I think I'm going to start
using it in my animations, and thought I'd share it in case it's of value to
anyone else.
// Povray 3.5 Scene description file
//your sample array
#declare ary=array[4]{
//an array of four dimensions:
//< time, x_position[n], y_position[n], z_position[n]>
<0.00, -1,1,0>,
<0.35, -2,-0.5,0>,
<0.67232, 0,0,0>,
<1.02341230,-1,1,0>
#macro ease_in(your_clock,your_array)
#local rotdim=dimension_size(your_array,1);
#local ennn=0;
#while(ennn<rotdim)
#if(your_array[ennn].x=your_clock)
your_array[ennn].y,your_array[ennn].z,your_array[ennn].t>
#declare ennn=ennn+1e7;
#else
#if(your_array[ennn].x<your_clock)
#local ennn=ennn+1;
#else
#local why1=your_array[ennn+0];
#local why0=your_array[ennn-1];
#local
teee=(your_clock-why0.x)/(why1.x-why0.x);
#local
teeecubes=3*pow(teee,2)-2*pow(teee,3);
#local
exxx=why0.y+(why1.y-why0.y)*teeecubes;
#local
eyyy=why0.z+(why1.z-why0.z)*teeecubes;
#local
ezzz=why0.t+(why1.t-why0.t)*teeecubes;
<exxx,eyyy,ezzz>
//algorithm for display of points along uniform time increments.
#declare n=0;
#while(n<100)
sphere{ ease_in(n/100,ary), 0.02 pigment {red 1 green 0.5}
finish{ambient 1} }
#declare n=n+1;
// who made this macro, I dunno. Was it Rune or JvS?
#macro FindKnee(pA,pH,lT,lS,vD)
#local lB=vlength(pA-(pH));
#if( (lB>lT+lS) | (lT>lB+lS) | (lS>lT+lB) )
#error "Invalid span lengths.\n"
#declare gk=1/0/0/0/0/0/0/0/0;
#local tX=(lT*lT-lS*lS+lB*lB)/2/lB;
#local tY=sqrt(lT*lT-tX*tX);
#local vO=vnormalize(pA-(pH));
#local vF=vnormalize(vcross(vD,vO));
#local vU=vnormalize(vcross(vO,vF));
(pH+vO*tX+vU*tY)
//complicated example showing use of
// the easein macro for determination of wrist point
#declare bodytexture=texture{pigment{rgb 0.7} finish{ambient 0.2 metallic
phong 0.5} normal{facets scale 0.15}}
#declare shoulderpoint=<2,0.5,0>;
#declare wristpoint=(ease_in(clock,ary));
#declare elbowpoint=FindKnee(wristpoint,shoulderpoint,2.5,2.5,-y);
#declare n=0;
#while(n<5)
cylinder {0,<1,1,0>/2,0.05 rotate y*(90+180*n/5) translate
wristpoint texture{bodytexture}}
sphere {<1,1,0>/2,0.05 rotate y*(90+180*n/5) translate wristpoint
cylinder {<1,1,0>/2,<0.75,2,0>/2,0.05 rotate y*(90+180*n/5)
translate wristpoint texture{bodytexture}}
sphere {<0.75,2,0>/2,0.05 rotate y*(90+180*n/5) translate wristpoint
#declare n=n+1;
sphere{shoulderpoint, 0.2 texture{bodytexture}}
cylinder{shoulderpoint,elbowpoint, 0.1 texture{bodytexture}}
sphere{elbowpoint, 0.2 texture{bodytexture}}
cylinder{elbowpoint,wristpoint,0.1 texture{bodytexture}}
sphere{wristpoint, 0.2 texture{bodytexture}}
light_source{<-0,100,-20> color rgb <1.7,1,0.5>}
light_source{<10,-10,-60> color blue 0.5}
camera{location <0,0,-5>}
Download 'easein0901c.mpg' (293 KB)
![](/i/fill.gif) |
