POV-Ray : Newsgroups : povray.beta-test : non hollow flat disc Server Time
17 Mar 2026 02:12:57 EDT (-0400)
  non hollow flat disc (Message 13 to 22 of 22)
Subject: Re: non hollow flat disc
Date: 11 Jan 2002 11:09:10
Message: <3c3f0e26@news.povray.org>
> What about linux ?
 In my beta 9 it always shows the behavoir you described, consistently.
Perhaps it's something to do with the disc object geometry? I don't know...
I never used disc, and I even don't know its syntax well...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 11 Jan 2002 20:20:38
Message: <Xns9193CEF34F0F9CQ@204.213.191.226>
news:mi9t3uophkvlv9hfah5uv7enn2pamhuvd7@4ax.com:
> then renderer work the same but parser says warning:
> "Camera is inside a non-hollow object."
I've had the same problem with disks going back to at least the initial
release of version 3.1. The workaround is to specify all disks as hollow.
Date: 12 Jan 2002 02:40:06
Message: <lopv3u0tdf1jlmlsh8eedk7iv6ljma8i8n@4ax.com>
IIRC discs, like height fields, are infinitely thin, but nevertheless
the engine considers one side of them to be the 'inside'. And of
course as they don't have an outside... Basically everything below a
height field and everything in the cylinder defined by the disc normal
and radii is considered inside.
You can see if I'm babbling by trying interior_texture on your disc
with +z and -z as normals and see if it changes.
Peter Popov ICQ : 15002700
Date: 12 Jan 2002 03:24:01
Message: <3C3FF297.E99E37E7@gmx.de>
That's not a valid argument i think, bicubic patches can use
interior_texture too, but they don't have an inside and outside.
Date: 12 Jan 2002 03:36:18
Message: <84tv3u0u3agke89a642ro688bv5i74qmv8@4ax.com>
On Sat, 12 Jan 2002 09:23:51 +0100, Christoph Hormann
Ouch, that hurt. They got me at last, and they got me good. Tell mommy
I'm not coming home for Christmas *cough* *spit*
Whatever... I still think the reason behind the warning is the
inherent interior of the disc object.
Date: 12 Jan 2002 21:15:01
Message: <3c40eda4@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
:> You can see if I'm babbling by trying interior_texture on your disc
:> with +z and -z as normals and see if it changes.
: That's not a valid argument i think, bicubic patches can use
: interior_texture too, but they don't have an inside and outside.
  A more reliable test is to difference a properly placed object from the
disc.
Date: 14 Jan 2002 15:51:58
Message: <slrna46h7h.b2g.ron.parker@fwi.com>
And so it is.  Those with access to the source code to 3.1 or higher can
see in discs.c (or discs.cpp) that Inside_Disc is not a simple "return false"
like, say, Inside_Triangle.  The inside of a disc is the inside of the
plane that contains the disc.  NOTE that it is not constrained by the radius
of the disc, either, making the insideness of discs somewhat useless, but
that's how it's defined.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 15 Jan 2002 08:51:28
Message: <3c4433e0$1@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
Is this a bug, or do the docs just need changing?
Date: 15 Jan 2002 10:19:26
Message: <slrna48i42.kt1.ron.parker@fwi.com>
I suppose it should be documented, for those who care.  To be honest, I think
the inside of a disc should respect the disc's radius, or the disc just
shouldn't have an inside (though changing that now might affect scenes of
people who thought it did) but what's most likely is that the docs will just
change to reflect the reality.
Date: 15 Jan 2002 12:07:24
Message: <Xns9197B89883931seed7@povray.org>
in news:slr### [at] fwicom Ron Parker wrote:
> the docs will just
I'll make the change,
Ingo
