POV-Ray : Newsgroups : povray.beta-test : Source code status Server Time
3 Jul 2026 03:46:58 EDT (-0400)
  Source code status (Message 21 to 27 of 27)
Subject: Re: Source code status
Date: 14 Feb 2008 03:25:00
Message: <web.47b3fa66ce3b77ca7d55e4a40@news.povray.org>
Kyle <hob### [at] gatenet> wrote:
> Chris,
> I sent you an email reply outlining my results.  Let me know if you don't get it.
> Kyle
I've done the same.
Tom
Date: 14 Feb 2008 06:02:17
Message: <47b41fb9$1@news.povray.org>
Fredrik Eriksson wrote:
> Using the 'DEVELOPMENT' macro to make POV-Ray search for the editor dlls
> in the 'codemax' directory (as described in the readme) does not work,
> because it looks for them in the wrong place. POV-Ray looks for
> '"..\\codemax\\" BINDIRNAME "\\" EDITDLLNAME', but it should be
> '"..\\..\\codemax\\" BINDIRNAME "\\" EDITDLLNAME'.
strange ... it works here (I built from the same zip you used, loaded the
EXE, then used process explorer to confirm that the local copy of the DLL's
was loaded). note that visual studio (at least, VS 2005) sets the working
directory to that of the project, rather than that containing the EXE.
if you add the '/debug' switch to the command-line options in the project
settings, and then run pvengine, you should get a c:\povdebug.txt file,
containing something like the following:
  CWD is d:\Temp\povwin-src-3.7\windows\vs 2005
What does your one give?
-- Chris
Date: 14 Feb 2008 07:00:07
Message: <op.t6ijmgep7bxctx@e6600.bredbandsbolaget.se>
On Thu, 14 Feb 2008 12:02:17 +0100, Chris Cason
> DLL's
That explains it. I was running pvengine.exe directly from the 'bin32'
directory.
Another thing I noticed:
Since the executable name and path is identical for all configurations
(Debug, Release and SSE2), it is rather cumbersome to switch between them.
It would be preferable to have separate names and/or paths.
FE
Date: 14 Feb 2008 07:03:24
Message: <op.t6ijry2o7bxctx@e6600.bredbandsbolaget.se>
On Thu, 14 Feb 2008 13:00:06 +0100, Fredrik Eriksson
> them. It would be preferable to have separate names and/or paths.
I just noticed that the SSE2 executable did indeed have a different name,
but I think the debug version should too.
FE
Date: 14 Feb 2008 07:16:38
Message: <47b43126@news.povray.org>
>> DLL's
> directory.
ah, I see. the macro is really intended for use when running from the IDE,
particularly if you want to debug the editor code itself.
I really ought to clean the whole project layout up - I've done it for the
version 3.6 project but that was after I did the 3.7 branch. all the
project files should be in the VS 2005 directory, and the DLL's should end
up in the bin32 directory, rather than where they are now.
this is intentional - probably a reflection of the way I tend to develop, I
found the standard Visual Studio habit of separating the EXE's into their
own dir was a hassle, as I'm constantly switching between various builds,
and I simply want my various shortcuts (desktop, objectdock, keyboard
launchpad) to always point at the EXE I most recently built. back when I
had them separate, I too many times ran a multi-hour test render only to
find that I'd launched the wrong EXE :-(
thanks for the feedback anyhow. I have added an additional check for the
codemax DLL's in ..\..\ as well as ..\.
-- Chris
Date: 14 Feb 2008 07:28:24
Message: <47b433e8$1@news.povray.org>
>> Chris,
>> Kyle
> I've done the same.
Got both, thanks.
-- Chris
Date: 18 Feb 2008 07:14:22
Message: <47b9769e$1@news.povray.org>
Thanks to Tom, Kyle and and Fredrik for their assistance - it resulted in
some significant changes and improvements to the presentation of the source
and its readme.txt.
The source is now available - please see the announcement in this group.
-- Chris
