![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
1. '|' and '&'
According to POV-Help 6.5.4.4.1&2, the operator '|' means merge
and '&' means intersection.
But these operators don't work properly on beta 8.
For example, following isosurface is not the intersection
of two spheres.
isosurface{
function { f_sphere(x,y,z,1) & f_sphere(x+0.5,y,z,1)}
These were ok on beta 7.
2. 'int()'
The function 'int()' does not work in isosurface.
Try the following isosurface.
isosurface{
function { int(0.5)}
threshold 0.5
POV-Ray crashes on my PC.
POV-Ray for Windows 3.5 beta 8, Windows Me, Celeron 600MHz
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it R. Suzuki who wrote:
>1. '|' and '&'
> of two spheres.
> isosurface{
>2. 'int()'
> isosurface{
> threshold 0.5
I confirm these, but will entertain suggestions that #1 might be
mathematically correct as long as the intersection and merge of
isosurfaces now get documented this way round.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3c082dbe@news.povray.org> , "R. Suzuki" <r-s### [at] aist go jp>
wrote:
> 1. '|' and '&'
> of two spheres.
The operators work as designed, the documentation hasn't been updated. The
operators don't mean merge or interesection. Unse min and max. Or if there
is demand, I could add a difference and an intersection function (with two
or more arguments!).
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The
there
I used these operators as geometric operators in the isosurface patch
because it seems to be common in this field.
See http://wwwcis.k.hosei.ac.jp/~F-rep/HF_oper.html
If those are not allowed, how about "iso_union(A, B, C, D, ...)" and
"iso_intersection(A, B, C, D, ...)".
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3c091260@news.povray.org> , "R. Suzuki" <r-s### [at] aist go jp>
I know, but unfortunately POV-Ray defines the same operators to work like
logic in the parser, and as functions can be used anywhere and for
consistency they really have to work as in the parser.
I will look into adding union and intersection (no new keywords). BTW, do
you by any chance know how (if possible at all) to implement a 'difference'?
the link you provided suggests it is possible. SO if it would be a really
simple implementation I might be able to add it as well...
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
difference is simply intersection with the inverse (negative in isosurface
if you have threshold 0)
Anyway i think other things are more important. ;-)
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Thorsten Froehlich" wrote:
>BTW, do you by any chance know how (if possible at all) to
>implement a 'difference'? the link you provided suggests it is
>possible. SO if it would be a really simple implementation I might
This is really simple as Christoph pointed out.
See POV Help 3.4.4.5.
(The operators in these documents should be also fixed.)
R. Suzuki.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In MATLAB, which is one of the most commonly used mathematical
programing language, there are UNION(A,B) function and
INTERSECT(A,B) function, but the meaning is totally different.
So, those function names will confuse some people.
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3c09efee@news.povray.org> , "R. Suzuki" <r-s### [at] aist go jp>
Maybe I should just leave it as is and only create a min and max function
that take more than two arguments. It would still keep the syntax as simple
as it was with & and | and avoid misunderstandings.
I will also fix the & and | using min/max so they behave like true boolean
operators...
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>only create a min and max function that take more than two
>arguments.
This would be nice.
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
