POV-Ray : Newsgroups : povray.animations : Jitter in wood textures Server Time
8 Jul 2024 10:41:31 EDT (-0400)
  Jitter in wood textures (Message 1 to 7 of 7)
Subject: Jitter in wood textures
Date: 19 Sep 2003 05:22:28
Message: <4milmv8nqfjeqdrgc3ed16uj75pthqo888@4ax.com>
Can anyone offer advice about how to eliminate jitter in wood during an
animation. I am not using jitter or crand. I am using the standard material
DMFDarkOak which is scaled in the material and in the object. Any advice will be
appreciated.
Regards
Subject: Re: Jitter in wood textures
Date: 19 Sep 2003 07:58:47
Message: <3f6aef77@news.povray.org>
> appreciated.
  Try scaling the texture bigger. If it results in something you don't want
to use, then I suppose there's no other way than to use a very high-quality
antialiasing (and turn antialiasing jittering off).
Date: 19 Sep 2003 08:36:38
Message: <f2ulmvgtv05lrs20gbcgee4is901t283gl@4ax.com>
Thanks Warp, I still get jittering with
Antialias_Threshold = 0.0
Antialias_Depth = 3
Sampling_Method = 1
And I never use jittering in animations, well not after the first one.
I've picked a different wood type and not scaled it down so much.
Regards
Date: 20 Sep 2003 13:28:34
Message: <3f6c8e42$1@news.povray.org>
> an animation. I am not using jitter or crand. I am using the standard
> material DMFDarkOak which is scaled in the material and in the
> object. Any advice will be appreciated.
> Regards
>         Stephen
Hi!
Just an idea: maybe it's not a special jitter with wood, but only especially
visible with it:
Have you only turned jitter off:
Jitter=off
or have you turned down the jitteramount, too:
Jitter_Amount=0.0
I'm not sure, but in former versions of POVRay (pre-3.5) turning off jitter
was not enough. At least that's what I experienced. Maybe this strange
behaviour is still alive...
Kalle
Date: 21 Sep 2003 07:02:24
Message: <o91rmvg2bk6sjr3pbus3hmqsra8l96tn95@4ax.com>
>Jitter=off
>Jitter_Amount=0.0
Yes, I have Jitter=off and Jitter_Amount=0.0 I always use those settings in
animations. I think it is the turbulence in woods that show up. Especially on
the end grain. Warps suggestion about scaling is probably the best advice. I
changed the wood in my model and got better results. I will post the animation
in p.b.a
Regards
Date: 6 May 2004 20:06:38
Message: <409ad30e@news.povray.org>
news:o91rmvg2bk6sjr3pbus3hmqsra8l96tn95@4ax.com...
> >Jitter=off
> >Jitter_Amount=0.0
> in p.b.a
> Regards
>         Stephen
Try using a higher Antialias_Depth value. I have a similar problem when using
planes with checker textures. Near the horizon I get some jitter but it doesn't
change through different frames (unless I change camera angle).
Using a higher depth, I get less jitter, but you can't get completely rid of it.
You can also try using sampling method 2 (slower) or blurring the final image(s)
a bit with a picture modifying program.
Date: 8 May 2004 10:52:43
Message: <j1tp90166pm46rd1ebmj7a3urtjlstppkc@4ax.com>
On Thu, 6 May 2004 19:11:05 -0300, "Nicolas Alvarez"
Gosh, you must have been going through some old posts :-}
Thanks for replying. I've got a lot to do just now but when I get some
time I try your suggestion.
