POV-Ray : Newsgroups : povray.advanced-users : Frosted light globes Server Time
11 Apr 2026 07:04:58 EDT (-0400)
  Frosted light globes (Message 1 to 3 of 3)
Subject: Frosted light globes
Date: 25 Nov 2002 20:30:04
Message: <web.3de2cd784d4a46d15f3c4db30@news.povray.org>
One thing I would like to know how to do is simulate the light emitted from
a frosted light globe. Most light bulbs used around the house are frosted
to reduce sharp shadows. Now, the light sources in pov-ray act like clear
globes, which produce sharp shadows. I would like to simulate frosted light
globes to mach the real ones in the locations in the scene of my living
room. I tried using circular area lights with the orient keyword, but it
didn't help much and slowed the scene down way too much. I made the area
lights cover the same volume as the lightbulb does and used 3*3 lights.
Anyone have any ideas what to do?
Rohan _e_ii
Subject: Re: Frosted light globes
Date: 25 Nov 2002 21:19:13
Message: <3de2da21@news.povray.org>
"Rohan Bernett" <rox### [at] yahoocom> wrote in message
news:web.3de2cd784d4a46d15f3c4db30@news.povray.org...
from
light
You are on the right track with area lights, just fiddle with the parameters
more.  Increase the number of lights in the grid and increase adaptive,
render time will go down though.  Also, for globe lights use 'circular' and
'orient'.  Jitter may help smooth results at lower grid and adaptive values.
-tgq
Date: 25 Nov 2002 21:51:27
Message: <3de2e1af$1@news.povray.org>
Did you use adaptive?
I'd try something like
area_light
x*size, y*size, 9, 9
// large number of samples only makes a difference
// in soft shadowed areas because of adaptive
circular orient
adaptive 1
// try 0 if it doesn't create shadow artifacts, 'cause that'll be faster.
// 1 is usually pretty safe.
 - Slime
[ http://www.slimeland.com/ ]
