POV-Ray : Newsgroups : povray.advanced-users : Radiosity flouroescent lighting troubles Server Time
22 Mar 2026 01:05:40 EDT (-0400)
  Radiosity flouroescent lighting troubles (Message 21 to 30 of 47)
Subject: Re: Radiosity flouroescent lighting troubles
Date: 28 Nov 2002 15:36:38
Message: <3DE67E56.B73BE681@gmx.de>
Michael Andrews wrote:
> Christoph Hormann wrote:
> > Sounds logical, avoiding regular patterns by randomizing the sampling
> > directions without breaking their uniform distribution.
> Have you ever actually looked at the sample distribution? It's only
> truely uniform at very specific sample numbers (51, 100-and-something,
> roughly doubling to 1600).
Well, it is not easy to create such a continuously uniform distribution,
uniform at a certain number is fairly simple on the other hand.
> I've been playing with a couple of algorithms
> to see if I could get a 'good enough' sampling at any number. The best
> I've found is using the Delaunay triangulation of a 2 unit radius disk
> and adding a new sample at the center of the largest circumcircle until
> there are 1600 samples within the 1 unit disk. Gives a reasonable
> distribution at all sample numbers.
I don't see how this creates a hemispherical distribution, sounds
two-dimensional.
> > How much speed does this additional rotation cost?
> It's only a handfull of adds and multiplies, a sin() and a cos() each
> time ra_gather() is called. Compared to the rest of the radiosity code
> it is negligible.
This i can imagine myself :-), i was interested in the actual render
times.
> Yes, but radiosity already had a random jitter in it, added in
> Start_Tracing_Radiosity_Preview() at around line 1040 in render.cpp. In
> fact I've taken this jitter out in my version to see what difference it
> made. In the scenes I've tried it doesn't seem to make much difference,
> but I can think of some where it would, so I may put it back in.
I suppose it does not have much effect in most cases (at least much less
than a rotation of sampling directions like you described), and it only
affects the pretrace so rendering without pretrace resolves the problem.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 29 Nov 2002 00:50:02
Message: <web.3de6ff1ee77700b4c571aa6c0@news.povray.org>
JRG wrote:
>So run POV-Ray and try something like:
>radiosity {
>pretrace_start 0.08
>pretrace_end 0.01
>count 300
>error_bound 0.1
>recursion_limit 2
>brightness 2 /*3... you may want to tune this value together with the
>brightness of your source*/
I tried these settings and the scene slowed down terribly. As I'm writing
this, the render has been going 56min and is only on line 258. The lo-res
preview and what's done so far looks pretty good, although there are some
odd blotches near the light sources.
I hate having to wait ages for just a test render. I think anything over 5
minutes for an 800*600 image with no AA, is too slow.
I hate slow renders.
Rohan _e_ii
Date: 29 Nov 2002 00:53:25
Message: <3DE7011B.5A00735C@pacbell.net>
If that is the case then you are using the wrong program.
May suggest MS paint instead?
Ken Tyler
Date: 29 Nov 2002 07:48:14
Message: <3DE76457.7A8925C6@frege.mathematik.uni-freiburg.de>
What is the problem you are adressing here?
My assumption (1-dimensional version): A sequence of numbers
between 0 and 1 such that for each initial segment of the sequence
the density is fairly even throughout the interval.
This can be done by choosing an irrational number r and taking the
sequence a(n)=(n*r) mod 1. The optimal r then is the golden ratio,
i.e. r=(sqrt(5)-1)/2.
Two dimensional version: here we take two such sequences, to two
irrational numbers r1 and r2. Those have to be independent in the
sense that 1, r1 and r2 are linear independent in the vector space
of the real numbers over the field of the rational numbers. While
it is easy to find such r1, r2, I do not know which give the best
results (in the same sense that the golden ration is optimal above).
The final version: So far we have a continuing uniformly distributed
sequence in the unit square. We have to map this to the hemisphere
without loosing uniformity. This can be achieved by
  (x,y) -> (sin(2pi*x)*sqrt(1-y^2),cos(2pi*x)*sqrt(1-y^2),y)
  Mark
Date: 29 Nov 2002 08:13:55
Message: <3DE76813.8B1CB162@gmx.de>
Quoting from the source:
A bit of theory: The goal is to create a set of "random" direction rays
so that the probability of close-to-normal versus close-to-tangent rolls
off in a cos-theta curve, where theta is the deviation from normal.
That is, lots of rays close to normal, and very few close to tangent.
You also want to have all of the rays be evenly spread, no matter how
many you want to use.  The lookup array has an array of points carefully
chosen to meet all of these criteria.
The problem is similar to the classical "How can I arrange N points evenly
on a sphere" problem like described in:
http://www.ogre.nu/sphere.htm
Just that it is hemispherical, not really uniform and it not only has to
be good for N points but also for N-X points (X = 1..N-1)
Date: 29 Nov 2002 08:51:38
Message: <3DE77334.999A8166@frege.mathematik.uni-freiburg.de>
That's what I thought, except I expected the probability to be
sin(theta)
(or cos(theta), if theta is the angle between ray and TANGENT), implying
fewer rays close to normal than close to tangent. Is this a typo?
Why is the lookup array fixed? It might be calculated at program start,
allowing for varying length.
  Mark
Date: 29 Nov 2002 08:56:55
Message: <3DE77226.7BC06E08@gmx.de>
> sin(theta)
I don't think so.
I'm sure if you come op with a method to generate a high quality
distribution within a fraction of a second or so everyone would be eager
to see it...
Date: 29 Nov 2002 09:07:20
Message: <3DE776E1.81EB6466@frege.mathematik.uni-freiburg.de>
> > sin(theta)
> I don't think so.
Then somebody should explain why they want their rays to be more
dense at the normal.
Especially with respect to your challenge below ;-)
> to see it...
How was the built-in array created? (I would like to know,
which quality I have to beat). In fact you already mentioned,
that you want the same quality contraints for initial segments
of the array, so my earlier suggestion might already do the trick.
  Mark
Date: 29 Nov 2002 09:36:46
Message: <3DE77DC6.DBB51BC2@frege.mathematik.uni-freiburg.de>
> sin(theta)
Am posting examples in p.b.i.
  Mark
Date: 29 Nov 2002 09:59:22
Message: <3de780ca@news.povray.org>
> sin(theta)
What you must remember is that you are trying to estimate the lighting
at a particular point.
If you have a light source almost tangential to the surface it doesn't
illuminate much and one almost normal to the surface gives high
illumination. So, if all the samples are weighted the same you want most
samples from the normal direction and few from tangential to give the
best estimate.
I suppose it could be, and I've thought about doing this. However you
would have to calculate an array for each level of radiosity recursion
because the code reduces the number of samples taken at each subsequent
recursion level. And the results wouldn't be very different anyway.
>   Mark
Mike Andrews.
