![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I tried to write IC_Mesh for iso_csg library but failed at "More than 65535
constants in all functions are not supported" error. But IC_Triangle works
pretty fine.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> pretty fine.
Maybe wait for RC6... ;-)
IC_Mesh sound pretty complicated, at least it will be awfully slow i
suppose...
Last updated 02 Jun. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:3CFBC9CD.9539E2E1@gmx.de...
65535
works
> > pretty fine.
> suppose...
Even the simple code is slow:
--- start code ---
#declare pigSea = pigment {
bozo
turbulence 1.5
sine_wave
color_map {
[ 0 rgbf <0, 1, 0, 1> ]
[ 1 rgbf <0, 0, 1, 1> ]
scale 50
#declare matSea = material {
pigment { pigSea }
normal { bozo scale 50 }
finish {
reflection { 0.1, 0.7
metallic 0.4
conserve_energy
phong 0.645
phong_size 130
metallic 0.4
interior {
ior 1.3
caustics 0.5
media {
absorption <1.0, 0.7, 0.2>*.01
method 3
samples 3,25
intervals 1
// Sky
#declare Sky1 = pigment { image_map { png "skyday9.png" interpolate 2 }
scale .5 }
#declare Sky = sky_sphere { pigment { Sky1
warp { spherical orientation z dist_exp 1 }
rotate x* 180
sky_sphere { Sky }
// Ocean
#declare fnpSea0 = function { pigment {
waves
turbulence 0.4
color_map { [ 0 rgb 0 ] [ 1 rgb 1 ] }
#declare fnpSea1 = function { pigment {
ripples
turbulence 0.9
#declare fnpSea2 = function { pigment {
bozo
turbulence 0.7
#declare fnSea = function {
fnpSea0(x*.1,0,z*.1).gray*4+fnpSea0(x*3,0,z*3).gray*2-fnpSea2(x,0,z).gray }
#declare Sea = union {
isosurface {
function { y - fnSea(x*.01,y,z*.01) }
contained_by { box { <-3000, -1, -3000>, <3000, 8, 3000> } }
accuracy 0.01
max_gradient 10
box { <-3000, -750, -3000>, <3000, -1, 3000> }
object { Sea pigment { pigSea } }
--- end code ---
And it gets worse if you replace pigSea with matSea.
Isosurface optimizations, anyone?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 5 Jun 2002 11:57:51 -0400, "David Wallace" <dar### [at] earthlink net>
But this kind of slowness not depends on isosurface but on material.
At least three:
1. use patterns instead of pigments.gray for functions
2. use scale keyword in pattern instead scaling coordinates for function
3. if possible code function directly inside isosurface to avoid referencing
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Have you actually measured that those will help?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I compared this for some previous betas - it wasn't scientific research but
just comparision in some particular scenes. I will try to make some better
comparisone and statistic later.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:u5dsfukc3ui9pd378d9mu7shaddskc7m40@4ax.com...
> At least three:
referencing
> ABX
I managed to implement points 1 and 2.... no noticeable effect.
#3 doesn't make for readable code.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 10 Jun 2002 21:15:08 -0400, "David Wallace" <dar### [at] earthlink net>
wrote:
> > At least three:
I just fiinished test with 5 passes:
- not optimized scene
- pattern instead of pigment
- scale instead of multiplications
- functions inlined completly and directly in isosurface
- all optimizations together
and difference was ~0.2% which can be just task priority issue. I think none
of my advices is valid for current release. There must be nice optimizations.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
