POV-Ray : Newsgroups : povray.advanced-users : light dependant image_map? Server Time
16 May 2025 09:55:53 EDT (-0400)
  light dependant image_map? (Message 1 to 10 of 12)
Subject: light dependant image_map?
Date: 29 Nov 2003 08:48:50
Message: <pj8hsvo9ajp3rbpqcuej2nmf45s7f9bobo@4ax.com>
Hi!
Is it possible to show different image_maps on an object depending on the
quantity of light that falls on a part of the object?
Background:
The earth should show a night bitmap (with city lights) on the night side
and another bitmap on the side that is hit by the sunlight...
Thanks!
E.D.
Erhard Ducke
Subject: Re: light dependant image_map?
Date: 29 Nov 2003 09:32:04
Message: <5pmm91-s7f.ln1@triton.imagico.de>
Erhard Ducke wrote:
> Hi!
> Background:
If you really need to have a different pigment on lit and shadowed parts
of the scene you can use the shadow_pigment feature from Mlpov.  For the
earth (light source far away, no shadows) a slope or gradient pattern
based pigment would suffice.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 29 Nov 2003 11:59:45
Message: <76jhsv4pk8ttf7o4su0flpeeja13hg5ols@4ax.com>
On Sat, 29 Nov 2003 15:24:05 +0100, Christoph Hormann
As a possible and more trivial solution I declared a texture map with a
radial pattern with frequency 1 to the planet sphere like this:
                    radial  frequency 1
                    texture_map {
                      [0.0  T_EARTH_DAY ]
                      [0.5  T_EARTH_DAY]
                      [0.5  T_EARTH_NIGHT]
                      [1.0  T_EARTH_NIGHT]
T_EARTH_DAY and T_EARTH_NIGHT contain different bitmaps for day and night.
But now I have a new problem:
When I rotate the radial around the y- and z-axis according to the position
of the sun like this:
                    radial  rotate y*TIME rotate z*ECLIPTIC_ANGLE
                    texture_map {...}
the bitmap travels with the radial pattern so that not only bright and dark
zone are moving but the whole earth seems to rotate...
I tried different positions of rotate, all give the same effect.
So it seems that the left edge of the bitmap isn't related to the sphere
any more as usual but to the radial pattern...
I hope I could make the problem clear...;-)
Erhard Ducke
Date: 29 Nov 2003 12:32:04
Message: <6l1n91-5ng.ln1@triton.imagico.de>
> texture {
>                     texture_map {...}
This is perfectly correct, you can either apply the inverse transform to
the textures or apply the transform only to the pattern and not to the
whole texture.  The latter can be obtained with pigment_pattern:
   pigment_pattern {
     radial
     color_map { [0 rgb 0][1 rgb 1] }
     rotate ...
   texture_map { ... }
the former with an inverse transform:
transform {
   inverse
Date: 29 Nov 2003 13:56:57
Message: <cjameshuff-459A0F.13570429112003@netplex.aussie.org>
In article <76jhsv4pk8ttf7o4su0flpeeja13hg5ols@4ax.com>,
>                   texture {
>                     radial  frequency 1
Radial? That seems like the wrong tool for the job when you're just
using different textures on each side of the sphere. The gradient
pattern would make more sense...or even an object pattern with a plane
object, though that would make it difficult to blend between the two.
> texture {
>                     texture_map {...}
This is because you are rotating the entire texture, not just the
pattern. You need to counter-rotate the textures in the texture_map by
-y*TIME, or use pigment_pattern or a function pattern to rotate just the
pattern. If you use the gradient pattern, you could just rotate the
gradient vector with vrotate().
http://tag.povray.org/
Date: 29 Nov 2003 14:10:01
Message: <web.3fc8eebba5497df739448a630@news.povray.org>
you should use something like that:
//start code
#declare lightsource = <0,1,1>*1000;
sphere {
        0,1
                slope {lightsource,0,1}
                texture_map {
                        [0.475 night_tex]
                        [0.525 day_tex]
        rotate -140*y
        rotate -20*x
camera {location <3,3,-3> angle 33 look_at 0}
light_source {lightsource,2.5}
//end code
Norbert
Erhard Ducke wrote:
>Hi!
>Background:
>Thanks!
>E.D.
>Erhard Ducke
Date: 30 Nov 2003 06:14:01
Message: <ptjjsvgtmvf2idoth3su5su9034e7adj4k@4ax.com>
On Sat, 29 Nov 2003 18:29:42 +0100, Christoph Hormann
>texture {
>   pigment_pattern {
>     radial
>     rotate ...
>   texture_map { ... }
Using this one I got the same 'mistake'...
//********begin pov code*********
The inverse rotating works fine:
    sphere {0,EARTH_RADIUS
                    radial
                    transform {ROT_TEXTURE}
                    texture_map {
                      [0.0  T_EARTH_DAY transform {ROT_TEXTURE inverse}]
                      [0.5  T_EARTH_DAY transform {ROT_TEXTURE inverse}]
                      [0.52  T_EARTH_NIGHT transform {ROT_TEXTURE inverse}]
                      [0.98  T_EARTH_NIGHT transform {ROT_TEXTURE inverse}]
                      [1.0  T_EARTH_DAY transform {ROT_TEXTURE inverse}]
//*********end pov code********
... but I feel there must be a simplier solution to my problem.
Thanks for your help!
Erhard Ducke
Date: 30 Nov 2003 06:22:49
Message: <ofkjsvcmmbcptqsjf4net10i3gkcf7j0s3@4ax.com>
Sorry, I have to correct my earlier followup. This one is better:
>texture {
>   pigment_pattern {
>     radial
>     rotate ...
>   texture_map { ... }
Using the code above I got the same 'mistake'...
The inverse rotating works just fine:
                    radial
                    texture_map {
... but I feel there must be a simplier and more elegant solution to my
problem. Five times the same boring inverse transformation is definitely
too much writing...;-)
Erhard Ducke
Date: 2 Dec 2003 05:08:33
Message: <3fcc64a1$1@news.povray.org>
Why not using the "phase" keyword...
The following code works fine.
#declare T1=texture {
  gradient x+y
  frequency 6
  color_map {
   [0.45 rgb <1,1,0>]
   [0.55 rgb <1,0,0>]
 finish {ambient 1}
#declare T2=texture {
  gradient z+y
  frequency 4
  color_map {
   [0.45 rgb <0,1,1>]
   [0.55 rgb <0,0,1>]
 finish {ambient 1}
sphere {
 0,1
  radial
  triangle_wave
  texture_map {
   [0.4 T1]
   [0.6 T2]
 location <3,2,-4>
 look_at 0
Date: 2 Dec 2003 09:35:17
Message: <cjameshuff-771852.09343602122003@netplex.aussie.org>
In article <3fcc64a1$1@news.povray.org>,
Not really. Due to the use of the radial pattern, the blend area gets
thinner towards the poles, pinching to a point at the poles. In real
life, it is constant. (Actually, getting slightly thicker, due to the
oblate shape of the planet.)
The gradient or slope patterns are more suited to this application.
Rotating the pattern is as simple as rotating the gradient or slope
vectors.
