POV-Ray : Newsgroups : povray.advanced-users : How do you rotate an object to face the origin? Server Time
3 May 2026 12:50:37 EDT (-0400)
  How do you rotate an object to face the origin? (Message 1 to 9 of 9)
Subject: How do you rotate an object to face the origin?
Date: 16 Dec 2003 10:35:46
Message: <Xns9453577279E6spammindspringcom@204.213.191.226>
Hi gang,
    	I've searched through the previous posts looking for an answer but
haven't found one yet.  I need to rotate many objects on their local Y axis
so that they face the origin.  The objects are placed randomly, so I don't
know "where" they are until they are transformed (or just before the
transform, I suppose).  I've looked at the reorient macro but I don't think
that's what I'm looking for.  Can anyone help me with this?
Rich Allen
Subject: Re: How do you rotate an object to face the origin?
Date: 16 Dec 2003 10:49:48
Message: <3fdf299c$1@news.povray.org>
Why not?  If where they are is a point then it is also the vector that
you want to reorient to, isn't it?
-Jim
Date: 16 Dec 2003 11:14:44
Message: <3fdf2f74@news.povray.org>
"Rich" <SrP### [at] ricoswebcom> wrote in message
> Hi gang,
axis
think
> Rich Allen
If you know the targetLocation before you translate the object and the
object is defined at the origin, then you can rotate it before moving it.
If you only need to rotate around the Y axis then the angle is the arctan in
degrees of z / x. So you can use atan2d():
#declare targetLocation = <3,4,5>;
#declare targetAngle = atan2d(targetLocation.z,targetLocation.x);
Hope I understood your question correctly.
Chris.
Date: 16 Dec 2003 13:09:14
Message: <Xns94537176EB3C0spammindspringcom@204.213.191.226>
"Chris B" <c_b### [at] btconnectcom> wrote in
news:3fdf2f74@news.povray.org:
> it. If you only need to rotate around the Y axis then the angle is the
> arctan in degrees of z / x. So you can use atan2d():
I think you do understand my question, but when I use your formula I
don't get the expected results.  I've output the relevant variable values
and copied them below.  Only one or two of these objects are actually
pointing at or nearly at the origin...
#declare rotation = atan2d(z1,x1);
#object {
  thing
  rotate <0,rotation,0>
  translate <x1,y1,z1>
Z:  0.1,  X:  3.5,  Rotation:   1.0
Z:  1.4,  X:  3.0,  Rotation:  25.0
Z:  2.3,  X:  2.0,  Rotation:  49.0
Z:  2.7,  X:  0.8,  Rotation:  73.0
Z:  2.5,  X: -0.3,  Rotation:  97.0
Z:  2.0,  X: -1.2,  Rotation: 121.0
Z:  1.2,  X: -1.7,  Rotation: 145.0
Z:  0.4,  X: -1.8,  Rotation: 169.0
Z: -0.4,  X: -1.6,  Rotation:-167.0
Z: -0.8,  X: -1.1,  Rotation:-143.0
Z: -1.0,  X: -0.6,  Rotation:-119.0
Z: -0.9,  X: -0.1,  Rotation: -95.0
Z: -0.7,  X:  0.2,  Rotation: -71.0
Z: -0.3,  X:  0.3,  Rotation: -47.0
Z: -0.1,  X:  0.2,  Rotation: -23.0
Date: 16 Dec 2003 14:06:00
Message: <3fdf5798@news.povray.org>
> #object {
>   thing
The initial axis in the Reorient macro is the initial direction your object
is pointing.  Assuming that your object is created to point in the +z
direction, this should work:
#object {
    thing
    Reorient( z, <-x1, -y1, -z1> )
    translate <x1, y1, z1>
I hope this was helpful.
Date: 16 Dec 2003 16:02:34
Message: <3fdf72ea$1@news.povray.org>
> ... snip ...
> #object {
>   thing
Hi Rich,
I should have been a bit more verbose with my response.
The targetAngle gives you the horizontal angle between the positive x-axis
and the target position.
Looking at what you want to do you will need to work with 90-targetAngle,
which you actually get if you take the arctan of x / z.
You will then need to compensate for the direction that your object is
pointing in when you defined it, so if it points at -z to start with you
don't need to compensate at all and you can use rotation = atan2d(x1,z1);
If your object points out along +z you will need to add or subtract 180.
e.g. rotation = 180 + atan2d(x1,z1);
If it's +x then add 90, for -x subtract 90 (I think!!).
This is all from memory, so you may need to adjust stuff or if you still
have trouble post a small, but working example so someone can check it out
and correct any errors.
Chris.
> ... snip...
Date: 16 Dec 2003 16:16:50
Message: <Xns9453914531EC4spammindspringcom@204.213.191.226>
news:3fdf72ea$1@news.povray.org:
> 90-targetAngle, which you actually get if you take the arctan of x /
> z. You will then need to compensate for the direction that your object
> is pointing in when you defined it, so if it points at -z to start
> with you don't need to compensate at all and you can use rotation =
> atan2d(x1,z1); If your object points out along +z you will need to add
> or subtract 180. e.g. rotation = 180 + atan2d(x1,z1);
Swapping the x and z values in the atan2d formula did the trick.  Thank you
very much!
Rich
Date: 16 Dec 2003 16:21:43
Message: <Xns94539218C9F8spammindspringcom@204.213.191.226>
"David Wallace" <dar### [at] earthlinknet> wrote in
news:3fdf5798@news.povray.org:
> object is pointing.  Assuming that your object is created to point in
> the +z direction, this should work:
> #object {
>     thing
Hmm.  I guess what I didn't understand about the Reorient macro was how to
determine the values it wanted.  I never would have thought to put negative
versions of the object's position, for example.  ChrisB's help solved the
problem, and I actually understand a bit of why it worked!  Thanks for your
help, now that I have the problem solved I can look into the reorient macro
code more  closely to see if I can figure out what it does and needs.
Rich
Date: 30 Dec 2003 17:27:34
Message: <3ff1fbd6$1@news.povray.org>
> > #object {
> >     thing
negative
your
macro
> Rich
Your object is meant to be placed at <x1,y1,z1>.  For the object to point
back at the origin you need the direction vector <-x1, -y1, -z1>.  If you
use <x1, y1, z1> then your object would point away from the origin.  Try
both and see.  Also try Reorient(-z, <x1, y1, z1>), which points the rear of
the object away from the origin, hence the front at it.
David Wallace
TenArbor Consulting
"Just in Time Cash"
http://www.tenarbor.com
