POV-Ray : Newsgroups : povray.advanced-users : Speeding up media Server Time
26 Jun 2024 05:51:38 EDT (-0400)
  Speeding up media (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Speeding up media
Date: 5 Feb 2021 07:00:00
Message: <web.601d3280df5181b61f9dae300@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> I have a planetary atmosphere with both scattering and absorption
> interior media. It renders very slowly. Any tips on speeding it up? Thanks.
> Mike
it's likely not your media - but your media settings.
try:
http://news.povray.org/povray.newusers/message/%3C59a9ec1c%40news.povray.org%3E/#%3C59a9ec1c%40news.povray.org%3E
Date: 5 Feb 2021 09:55:09
Message: <web.601d5bbedf5181b679819d980@news.povray.org>
hi,
> Here is the media: ...
tweaking the code may gain you some, but, perhaps, you can cheat and clip the
sphere/planet just behind the horizon, saving ~40%.
>       [0 rgb 0/10]
confused why you don't write just '[0 rgb 0]'.
regards, jr.
Date: 6 Feb 2021 02:41:24
Message: <601e4824$1@news.povray.org>
Op 05/02/2021 om 11:59 schreef Mike Horvath:
>> Thanks.
>> Mike
> Here is the media:
I am studying/testing your media, but need a little time...
Date: 6 Feb 2021 22:41:29
Message: <601f6169$1@news.povray.org>
> try:
I'm not sure how that applies to my case. I am not using emissive media
or the "samples" keyword.
Mike
Date: 6 Feb 2021 22:43:00
Message: <601f61c4$1@news.povray.org>
On 2/5/2021 9:52 AM, jr wrote:
> hi,
It's actually a cylinder or ring, so it reflects upon itself on the insides.
>>        [0 rgb 0/10]
> regards, jr.
I use fractions a lot and like to keep the source code tidy.
Mike
Date: 7 Feb 2021 02:23:31
Message: <601f9573$1@news.povray.org>
Op 07/02/2021 om 04:41 schreef Mike Horvath:
>> try:
There is nothing really wrong with your code as far as I can tell and
from own experience. From the outside (of the media) it is even rather
fast due to the default intervals 1 and samples 1 (Yes! you /do/ use
samples, even if you don't).
However, depending on the location of the camera within or without the
media, render times can be very different; you even may need to increase
the samples value to avoid splotches, and that will decrease render time
even more although not that much.
Using media is time consuming. There is no alternative.
Date: 8 Feb 2021 10:16:10
Message: <602155ba$1@news.povray.org>
>>> try:
>> media or the "samples" keyword.
The default for samples is 10.
samples default to 1 when using sampling method 1 or 2.
The default are, as of version 3.6 :
sampling_method 3
intervals 1 //DO NOT increase !
samples 10
Increasing intervals dramatically increase the rendering time without
giving any appreciable improvement.
samples 10 intervals 3 render slower than samples 50 intervals 1.
Date: 9 Feb 2021 02:30:23
Message: <60223a0f@news.povray.org>
Op 08/02/2021 om 16:16 schreef Alain Martel:
>>>> try:
>> increase the samples value to avoid splotches, and that will decrease
>> render time even more although not that much.
> sampling_method 3
> samples 10
I don't know where in the wiki there was a line saying defaults being
intervals 1 and samples 1,1. Of course, I cannot find that paragraph
anymore (typical!); but you are right of course: default samples is 10.
Date: 11 Feb 2021 10:45:30
Message: <6025511a$1@news.povray.org>
>>>>> try:
>>> rather fast due to the default intervals 1 and samples 1 (Yes! you
>>> /do/ use samples, even if you don't).
>>> the media, render times can be very different; you even may need to
>> sampling_method 3
>> samples 10
You have a mixup between the old version 3.5 and newer version 3.6
documentations.
The format : samples 1,1
is that of method 1 and 2. It's used to set the number of samples for
dark, bright intervals.
It's a leftover from the pre 3.6 version when the default sampling
method was method 1. It demanded an intervals number large enough to
match the number of distinct illuminated areas along a tracing path. If
you had 20 spotlights shining through some media, then, you needed 40,
or more, intervals : One interval for each illuminated part and one
interval for each non-illuminated parts between the illuminated ones.
When using the default method 3, when you have two values for samples,
the second is silently ignored.
Date: 12 Feb 2021 02:33:43
Message: <60262f57@news.povray.org>
Op 11/02/2021 om 16:45 schreef Alain Martel:
> documentations.
The wiki documentation then needs some updating here or a further
elaboration.
