POV-Ray : Newsgroups : povray.advanced-users : Locus of a moving point? Server Time
13 May 2025 14:50:04 EDT (-0400)
  Locus of a moving point? (Message 1 to 8 of 8)
Subject: Locus of a moving point?
Date: 12 Sep 2018 17:58:41
Message: <5b998c11$1@news.povray.org>
I am thinking of creating a model of the solar system in POV-Ray.
However, one of the things I would like to do is trace the path (locus)
of each planet around the sun so that the distance traveled so far is
visible. How would I accomplish this in POV-Ray? Thanks.
Mike
Subject: Re: Locus of a moving point?
Date: 13 Sep 2018 15:25:00
Message: <web.5b9ab8c8e18145f2a47873e10@news.povray.org>
As a purely visable trail that builds up as a planet moves? Or as a numerical
distance? The former is something I've done before, although I no longer have
the code. (I used closly-packed spheres to trace the trajectory, adding more
spheres during an animation). But I don't remember if I did it all within the
scene code, or if had to resort to #write/#read to another file, to recall all
the previous positions.
Date: 13 Sep 2018 15:35:01
Message: <web.5b9abb0ee18145f2a47873e10@news.povray.org>
> distance? The former is something I've done before...
Actually, it might be a simple procedure (but it's only my thought experiment,
beware!) The planet needs some starting position; then use a #while or #for loop
to advance that position incrementally, adding a small sphere there each time.
At the end of the loop, add your planet object. There should be a visible trail
of spheres as the trajectory. I think!
Date: 13 Sep 2018 19:40:01
Message: <web.5b9af47ee18145f2458c7afe0@news.povray.org>
> Mike
You should be able to peg that to whatever you're using to determine the
position of the planet in the animation.
So just use a torus, or section of scaled torus, or an elliptical sphere sweep
that starts at zero, and goes to wherever your planet currently is.
I managed to use a Dupin cyclide - but nevermind me.
Have you managed to determine how all the planets are aligned at some initial
starting point?
Date: 13 Sep 2018 19:45:49
Message: <5b9af6ad$1@news.povray.org>
> starting point?
Here's what I've done so far.
https://www.geogebra.org/m/prtwmh2d
It's two-dimensional, but I have calculated the coordinates for the
third dimension as well.
I think I can sample points along the orbits and connect them with
lines. Or create a parametric object that uses the same formulas. It
will take some work however.
Mike
Date: 13 Sep 2018 19:46:43
Message: <5b9af6e3$1@news.povray.org>
I have done this very thing in 2D, but it does not look nice or smooth.
Thanks.
Mike
Date: 13 Sep 2018 20:23:23
Message: <5b9aff7b@news.povray.org>
>> experiment,
>> #for loop
>> each time.
>> visible trail
> Thanks.
> Mike
Then, use a sphere_sweep using every 10th sphere.
Date: 14 Sep 2018 03:06:35
Message: <5b9b5dfb$1@news.povray.org>
>>> experiment,
>>> or #for loop
>>> each time.
>>> visible trail
>> Thanks.
>> Mike
This does seem to be the best (and easiest) solution unless I want to
wait many hours for the parametric objects to render. (I am creating an
animation.)
Mike
