POV-Ray : Newsgroups : povray.advanced-users : memory usage & large number of objects Server Time
7 Mar 2026 16:25:14 EST (-0500)
  memory usage & large number of objects (Message 1 to 7 of 7)
Subject: memory usage & large number of objects
Date: 17 Nov 2009 05:40:28
Message: <4b027d9c$1@news.povray.org>
I'm trying to render a scene with a large number of objects (scene
generated by a 3D fractal); 3 milion and more objects.
As you'll understand this will use a lot of memory.
Now I was wondering: what object is the most memory efficient? Currently
Currently I'm using "box { <here> <there> texture { pigment { rgb <0.25,
1.0, 0.25> } } }" but maybe other objects use less resources?
Also I set for each object the color but it is the same color for all of
them. Maybe that can be optimized?
Thanks,
Folkert van Heusden
www.vanheusden.com
Subject: Re: memory usage & large number of objects
Date: 17 Nov 2009 06:48:50
Message: <op.u3je3ok67bxctx@e6600>
On Tue, 17 Nov 2009 11:40:28 +0100, Folkert van Heusden
If triangles will suffice, then generating a mesh should be the most
efficient.
Far more efficient to use a single texture/material applied to the
aggregate object.
FE
Date: 17 Nov 2009 07:01:55
Message: <4b0290b3$1@news.povray.org>
>> generated by a 3D fractal); 3 milion and more objects. As you'll
>> understand this will use a lot of memory. Now I was wondering: what
> efficient.
Will try.
But are you sure? As you then have twice as much objects.
Or are boxes internally split-up in 6 x 2 (2 triangles per side)
triangles?
>> of them. Maybe that can be optimized?
> aggregate object.
What do you mean with aggregate? According to wikipedia it means
composite (am not a native speaker. Does that mean with respect to povray
something like this?
#declare myobj =
        box { <0, 0, 0>, <1, 1, 1> texture { pigment { rgb <0.25, 1.0,
0.25 } } }
and then use
object { myobj rotate <somevalue> translate <someohter> }
Date: 17 Nov 2009 07:11:53
Message: <op.u3jf53eo7bxctx@e6600>
On Tue, 17 Nov 2009 13:01:55 +0100, Folkert van Heusden
>> efficient.
> Will try.
You collect all the triangles into a single mesh object.
http://www.povray.org/documentation/view/3.6.1/292/
http://www.povray.org/documentation/view/3.6.1/293/
>> aggregate object.
http://www.povray.org/documentation/view/3.6.1/304/
A few examples of what can be accomplished with the right approach:
http://news.povray.org/povray.binaries.images/message/%3Copr48epnpgzjc5hb%40news.povray.org%3E
FE
Date: 17 Nov 2009 07:13:53
Message: <op.u3jf9eqo7bxctx@e6600>
I accidentally hit Send too soon...
I meant to also include:
http://news.povray.org/povray.binaries.images/message/%3Copr6rtu8fxzjc5hb%40news.povray.org%3E
FE
Date: 17 Nov 2009 19:52:11
Message: <4b03453b$1@news.povray.org>
This definitely calls for "blob" or "mesh"/"mesh2".
If you use suitable parameters, the blob object will behave almost as a
collection of spheres. (Note that there is some upper limit on the total
number of blob elements, and you may even need a multitude of blob objects.)
With mesh or mesh2 objects (both are just different syntax variants for
one and the same underlying object), you can assemble whatever you deem
the most fitting basic shape: Boxes, tetrahedrons, or maybe just plain
flat triangles. (Maybe there's a limit on the number of triangles there,
too, but I never met any.)
Both objects support either per-element or per-object texturing. I don't
think it makes any difference memory-wise as long as you use just a
small set of #define'd textures.
As an alternative, you might also try using a df3 file (basically a 3D
bitmap) as the basis for an isosurface. If you intend to have a
densely-filled space, then this is likely to be the most
memory-efficient way to go, and may also be easiest to generate.
Date: 17 Nov 2009 20:01:50
Message: <4b03477e@news.povray.org>
>> efficient.
> Will try.
> triangles?
Boxes, like any objects in POV-Ray, are not represented as polygon
meshes (except for mesh objects of course :-)), but as a set of
parameters to an object-type-soecific algorithm that will test whether
and where a straight line intersects the object, or whether a given
point is inside the object.
Theoretically, this would leave you with two coordinate points for
boxes, but three coordinate points for triangles.
In practice however, each object also stores a bunch of additional data
common to /all/ object types: A transformation matrix, a reference to a
texture, and a reference to an interior, to name just a few.
With a bunch of boxes, you get this overhead once per box. With a mesh,
you get this overhead once per mesh.
> #declare myobj =
> 0.25 } } }
> and then use
No, more like
union {
   box {...}
   box {...}
   box {...}
   texture { ... }
