POV-Ray : Newsgroups : povray.advanced-users : Help with special density for blob: getting my feet wet Server Time
28 Jul 2024 16:28:50 EDT (-0400)
  Help with special density for blob: getting my feet wet (Message 1 to 4 of 4)
Subject: Help with special density for blob: getting my feet wet
Date: 10 Jan 2005 21:30:00
Message: <web.41e339a7fbc78a8ae4b238f30@news.povray.org>
Hello,
I am trying to get my blob to behave like cell walls: where the surface is
parellel to the plane of projection the wall looks pritty much clear and as
the wall bends towards perpendicular to the plane of projection the wall
becomes more opaque. I don't know if I'm being clear. Glass is simmilar.
I tried density maps but I dont know how to use them correctly I think.
Thanks for the help!
Subject: Re: Help with special density for blob: getting my feet wet
Date: 10 Jan 2005 23:43:36
Message: <hStLLCAqg14BFwqw@econym.demon.co.uk>
Wasn't it wade who wrote:
>Hello,
That sounds a bit like the Angle Of Incidence pattern available in
MegaPOV but not in Official POV-Ray. Except it doesn't happen with
glass.
The value returned by this pattern is proportional to the angle between
a certain ray and the (perturbed) normal at the surface of the object.
So you can use a colour_map to vary the transparency.
  pigment {aoi
    colour_map {
      [0.1 rgbt <.3,.5,0,1>]
      [0.5 rgbt <.3,.5,0,0>]
Mike Williams
Gentleman of Leisure
Date: 11 Jan 2005 02:16:49
Message: <41e37d61$1@news.povray.org>
The mention of glass confused me, was thinking of plate glass turned edge-on
and yet this being about a blob shape I thought of something rounded.
If it were like a microscopic view of a plant cell I imagine this would be
about the extinction of light across denser places along line of sight. What
Mike suggests could work, I guess, just that I was thinking of media getting
thicker at the outer edge of a spherical shape and thinner in the middle.
Much like the Earth's atmosphere, as seen from orbit.
If you fill the object with media uniformly then the opposite will happen.
That is, if not only a shell. So, it would seem a shell is needed. The shape
of the blob object might make that difficult. A sphere alone would be very
simple, though, by using the 'spherical' pattern in the density_map.
Well, I don't have any brilliant ideas to share really, just wanted to
elaborate this question a bit. However, I do have a little scene of a plant
cell-like thing showing an example of media filling a blob. Should be
obvious enough to understand. Basically just a positive strength sphere and
negative strength side spheres to make it boxy and 'boxed' patterns for both
surface color and interior. Feel free to do whatever you want with this if
it is any good at all for what is needed. If not, continue asking... maybe
at povray.general or povray.newusers, too, since there's more traffic there.
/* BEGIN */
global_settings {
 assumed_gamma 1
 location -5*z
 look_at 0
 angle 50
 rotate <30,30,0>
light_source {
 -1000*z, 1
 rotate <30,-30,0>
plane { // floor
 y,-2/3
  rgb 1
// plant cell?
blob {
 threshold 0.5
 sphere {
  0,1.75,1
   boxed
   color_map {
    [0.45 color rgbt <0.1,0.6,0.1,0.9>]
    [0.55 color rgbt <0.6,0.1,0.1,0.3>]
   scale 1.3
 sphere {
  0,1,-1
  scale <0.5,2,2>
  translate x
 sphere {
  0,1,-1
  scale <0.5,2,2>
  translate -x
 sphere {
  0,1,-1
  scale <2,2,0.5>
  translate z
 sphere {
  0,1,-1
  scale <2,2,0.5>
  translate -z
 sphere {
  0,1,-1
  scale <2,0.5,2>
  translate y
 sphere {
  0,1,-1
  scale <2,0.5,2>
  translate -y
  color rgb 1
  interior {
   media {
    method 2
   // samples 10
    absorption <0.9,0.1,0.9>*9
    emission <0.1,0.9,0.1>
    scattering {
     4, rgb 4
     // eccentricity 0.2
     // extinction 0
  density {
   boxed
   density_map {
    [0.45 color rgb <0.6,0.1,0.1>*0]
    [0.55 color rgb <0.1,0.6,0.1>*1]
    [0.65 color rgb <0.1,0.6,0.1>*0]
   scale 1.3
 hollow
/* END */
Date: 11 Jan 2005 05:42:50
Message: <41e3adaa@news.povray.org>
  What happens with glass is that they reflect more light at shallow
angles. If you look at a window directly from the front, the amount of
reflection is very small and mostly you see through. If you look at the
window from a very small angle, you see mostly the reflection (of course
this effect can be accentuated or diminished by the coating of the glass).
  If this is the effect you are looking for, try variable reflection
(supported by POV-Ray).
