POV-Ray : Newsgroups : povray.advanced-users : Blue haze at the horizon? Server Time
29 Jul 2024 02:33:26 EDT (-0400)
  Blue haze at the horizon? (Message 1 to 4 of 4)
Subject: Blue haze at the horizon?
Date: 1 Jul 2003 12:08:23
Message: <3f01b1f7$1@news.povray.org>
Hi there!
Any idea how one can create a realistically looking blue-ish haze
affecting far-away objects? I've been fiddling around for a while trying
various kinds of scattering media - with the effect that the sky_sphere
virtually always turned completely white.
Thank you in advance -
	Torsten
Subject: Re: Blue haze at the horizon?
Date: 1 Jul 2003 12:21:49
Message: <cjameshuff-5FD16F.11210801072003@netplex.aussie.org>
In article <3f01b1f7$1@news.povray.org>,
    The sky_sphere feature just provides a background. It is considered
to be infinitely distant, which gives you an infinite amount of media in
front of it. Try putting your media in a container that simulates an
actual atmosphere.
    Since you are just doing atmospheric haze, you might find fog easier
to control and faster to render. It is far less flexible and less
accurate, but much faster. You won't see light and shadows in it, so it
isn't good for dense fog, but it should be fine for an even haze.
http://tag.povray.org/
Date: 1 Jul 2003 20:54:41
Message: <3f022d51@news.povray.org>
If you want to use media, try the following,
-use a container object for the media: this will allow you to control the
depth of the haze and I think it is faster than uncontained media.
- discard the sky_sphere: if the media is properly scaled it should not only
give a blueish cast to distant (dark) objects, but also provide the blue sky
color (against a black background). Here is where a container object can be
useful - a small media "depth" overhead and a greater "depth" at the horizon
can provide a nice color gradient.
- try using method 2 if you can get away with it, an set the sampling as low
as possible while still retaining image quality.
- also remember, lighter objects will generally tend towards red instead of
blue with distance. Absorption media would work here.
Abe
"Torsten Crass" <tor### [at] eBiologyde> wrote in message
news:3f01b1f7$1@news.povray.org...
> Hi there!
> Torsten
Date: 3 Jul 2003 02:46:09
Message: <3f03d131@news.povray.org>
Hi Chris, hi Abe!
Thanks a lot for your advice - I tried both a scattering medium
constrained by a (large) object as well as ground fog. After tuning all
parameters, I got nice looking results with both methods, but since fog
really renders much faster I think I'll go for this solution.
Thanks again, and happy raytracing -
	Torsten
