"Andrew Coppin" <orp### [at] btinternet com> wrote in message
news:3d921bfb@news.povray.org...
<snip>
Andrew, by coincidence I've been playing with the same problem, and have just
posted an image in binaries.images (code below).
BTW do you really need an iso for your water? Photons work fine with a normal.
The only reasons to use an iso IMHO would be:
a) your function is not suitable for a normal (anyone want to comment on this?)
b) you are showing the water surface where it touches another object, and you
therefore want a genuinely perturbed surface.
Here is the code to my scene if it helps (some stuff surplus to your
requirements):
// Persistence of Vision Ray Tracer Scene Description File
// File: tmland?.pov
// Vers: 3.5
// Desc: IRTC Wip
// Date: mm/dd/yy
// Auth: Tom Melly
#version 3.5;
#include "functions.inc"
#declare Do_photons = true;
#declare Do_media = true;
#declare Do_bed = true;
#declare Do_env = true;
#declare Do_rock = true;
#declare Do_qrock = false;
#declare Photon_sp = 0.2; //.2
#declare Cont_rad = 35; // 35
#declare Sea_col = <1,1,1,1>; //<0.5,0.9,1.0,1.0>;
#declare Sea_medcol = <0.8,0.2,0.1>*0.75; // 0.75
#declare Dens_min = 0.1;//.1
#declare Cam_z = -15;
#declare Do_sea = true;
#if(abs(Cam_z)+10>(Cont_rad))
Camera too far away!
global_settings {
assumed_gamma 1.0
ambient_light 0
#if(Do_photons)
photons{
spacing Photon_sp
autostop 0 jitter 0.4
#if(Do_media)
media 100
save_file "tmland6.ph"
//load_file "tmland6.ph"
#declare Dens_func = function(x,y,z){min(1,Dens_min + pow(x/Cont_rad,2) +
pow(z/Cont_rad,2))}
#declare Sea_media =
media{
method 3
intervals 10
samples 3,15
scattering {1,0.025 extinction 0.8} //0.025
absorption Sea_medcol
density{function{Dens_func(x,y,z)}}
location <0.0, 0.0, Cam_z>
look_at <0.0, -5.0, 35>
sky_sphere {
wrinkles scale 0.25
color_map {
[0.0 rgb <0.6,0.7,1.0>]
[0.7 rgb <0.2,0.4,0.8>]
light_source {
<0, 0, 0>
color rgb <1, 1, 1>*2.5
media_interaction on
media_attenuation on
fade_distance 1500
fade_power 2
translate <1000, 2000, -500>
#if(Do_bed)
#declare Bed_func = function(x,y,z){
y +
5 +
(sin(x*5 - sin(z + f_noise3d(x,0,z))*1)/20) -
(sin((x+z)*1 -
sin(z + f_noise3d(x,0,z))*1)/30)
#else
#declare Bed_func = function(x,y,z){y + 5}
#declare Bed_base =
difference{
isosurface {
function { Bed_func(x, y, z) }
contained_by {sphere{0,Cont_rad}}
accuracy 0.001
max_gradient 2
rotate y*35
plane{z,Cam_z-10}
pigment{rgb<0.9,0.9,0.6>}
#declare Sea_func = function(x,y,z){y - 5}
#declare Sea_top =
difference{
isosurface{
function { Sea_func(x*1, y*1, z*1) }
accuracy 0.001
max_gradient 5
rotate y*25
plane{z,Cam_z-10}
pigment{rgbf Sea_col}
normal{bozo 5 scale 1/4}
hollow
#if(Do_photons) photons{target refraction on reflection on} #end
finish{
reflection{fresnel on}
ambient 0 diffuse 0 conserve_energy
interior{
ior 1.34
#if(Do_media)
media{Sea_media}
#declare Wall =
difference{
sphere{0,Cont_rad}
sphere{0,Cont_rad - 0.01}
plane{y,-7}
plane{-y,-7.5}
plane{z,Cam_z-10}
pigment{rgb 0}
#if(Do_photons) photons{collect off} #end
#if(Do_env|Do_bed)
object{Bed_base}
#if(Do_env|Do_sea)
object{Sea_top}
object{Wall}
#declare FAgate = function {
pigment { agate color_map { [0 rgb 0] [1 rgb 1] }}
#declare FGranite = function {
pigment { granite color_map { [0 rgb 0] [1 rgb 1] }}
#declare Rock_func = function(x,y,z){
(x*x + y*y + z*z)
+ f_noise3d(x,y,z)/2
- FAgate(x,y,z).gray/5
- FGranite(x,y,z).gray/7
- 1/2
#declare Rock =
isosurface {
function { Rock_func(x/5, y/8, z/5) }
contained_by { box { -10, 10 } }
accuracy 0.001
max_gradient 10
pigment{rgb 0.5}
translate <0,-3,0>
#if(Do_rock)
object{Rock}
#else
#if(Do_qrock)
sphere{
0,4
scale <1,1.5,1>
pigment{rgb 0.5}
normal{agate scale 10}
normal{granite scale 1/4}
translate <0,-3,0>
