POV-Ray : Newsgroups : povray.advanced-users : How would i do a Mitt? means put two pipe together seamless at 90 degree. Server Time
11 Apr 2026 17:59:38 EDT (-0400)
  How would i do a Mitt? means put two pipe together seamless at 90 degree. (Message 1 to 5 of 5)
Subject: How would i do a Mitt? means put two pipe together seamless at 90 degree.
Date: 25 Jun 2001 03:22:54
Message: <3b36e6ce@news.povray.org>
I'm wondering how you would like take two cylinder at like 90 degree or 45
degree  then put the end together but the end part would stick out of each
others, how would u cut those end part off and delete it so the pipe like
fits together without any gap or junk sticking out??
kind of like
thanks in advance
Subject: Re: How would i do a Mitt? means put two pipe together seamless at 90 degree.
Date: 25 Jun 2001 06:27:25
Message: <3B371282.7C2E7260@hotmail.com>
> kind of like
> thanks in advance
You could use an intersection between an infinite cylinder from
shapes.inc and a plane.  I usually just stick in a sphere to close the
gap.
Dan Johnson
http://www.geocities.com/zapob
Date: 25 Jun 2001 11:08:06
Message: <3b3753d6@news.povray.org>
"Dan Johnson" <zap### [at] hotmailcom> wrote in message
news:3B371282.7C2E7260@hotmail.com...
45
each
like
> gap.
Or use blob maybe.  For components in the blob just two cylinders would do
okay, as in:
light_source {<1,1,-10>,1}
camera {location -5*z angle 60 look_at y}
blob {
        cylinder {2*x,0,.5,1 rotate 45*z}
        cylinder {2*x,0,.5,1 rotate 90*z}
        threshold 0.001
  pigment {rgb 1}
   rotate 22.5*z
Bob H.
Date: 25 Jun 2001 16:12:37
Message: <3b379b35@news.povray.org>
Surely simply using a CSG difference between the cylinder and a box
would
work fine?  You could either translate the cylinders to their final
positions, then chop off the box, or use a bit of trig if you wanted to
chop
first and move later.
I imaging this method should render faster than the other two
suggestions so
far.  Permission to quote me on that is witheld, though :)
or 45
each
like
> kind of like
> thanks in advance
Date: 26 Jun 2001 16:37:32
Message: <3B38F2AF.2F0C7929@ibras.dk>
If you want a sharp bend you could do it like this:
#declare cut_cylinder=difference { // cylinder cut at 45deg
   cylinder { <-100, 0, 0>, <20, 0, 0>, 5 }
   plane {-x, 0 rotate <0, 45, 0> }
#declare deg90_cylinder=union{
   object { cut_cylinder }
   object { cut_cylinder rotate <0, -90, 0> scale <-1, 1, 1> }
If you want a softer bend, you can just connect two cylinders with a
sphere like this:
#declare soft90deg_cylinder=union{
   cylinder { <-100, 0, 0>, <0, 0, 0>, 5 }
   sphere { <0, 0, 0>, 5 }
   cylinder { <0, 0, 0>, <0, 0, -100>, 5 }
/Ib
Gallery: http://www.ibras.dk
