POV-Ray : Newsgroups : povray.advanced-users : should be normal weighted ? Server Time
12 Oct 2026 18:25:51 EDT (-0400)
  should be normal weighted ? (Message 1 to 23 of 23)
Subject: should be normal weighted ?
Date: 4 Dec 2000 03:31:42
Message: <3a2b566e@news.povray.org>
I have point O and points P1, P2, ... PN
connected as traingles P1OP2, P2OP3, ..., PN-1OPN, PNOP1
I want calculate best normal at point O for all this triangles.
Should it be simple normalized summary of all normals
or waighted one depend of areas of each triangle ?
Maybe other way ?
ABX
Subject: Re: should be normal weighted ?
Date: 4 Dec 2000 04:41:39
Message: <3a2b66d3@news.povray.org>
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote:
: Should it be simple normalized summary of all normals
: or waighted one depend of areas of each triangle ?
  It depends on how you want it to look like.
  Try both methods with your object and choose the one you like the most.
Date: 4 Dec 2000 13:20:49
Message: <3A2BE07B.9EE186F8@spiritone.com>
Using Warps read me file for his mesh smoother, I find that normalizing
the normal vectors of each triangle, then averaging them, works the
best. Of course, if you are using the vcross command to find your
normals, remember that the length of the resultant vector has a length
of the dot product, which will be at it's maximum when the vectors are
orthogonal (ie, 90 degrees apart).
Since this doens't make a lot of sence, I'll try to have a few pictures
for you soon.
Josh
> Maybe other way ?
> ABX
eng### [at] spiritonecom
Date: 4 Dec 2000 13:38:39
Message: <slrn92np5i.mrd.ron.parker@fwi.com>
It's not the same as the dot product.  The length of the cross product
vector is A*B*sin(t) and the dot product is A*B*cos(t).
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 4 Dec 2000 15:01:57
Message: <3A2BF82F.BC751AD@spiritone.com>
I thought that I read in the docs that the length was the dot product, but
in fact they say "The resulting vector is perpendicular to the two original
vectors and its length is proportional to the angle between them." In my
experiments, that distance did seem to be at its largest when the vectors
were orthogonal.
Thanks for the clarification.
Josh
Date: 4 Dec 2000 15:40:25
Message: <slrn92o09s.ms8.ron.parker@fwi.com>
>were orthogonal.
Proportional to the sine of the angle between them.  Remind me to check the
docs when I get home.  Sine has a maximum at 90 degrees, so your experiments
were correct.
Date: 4 Dec 2000 15:51:49
Message: <3A2C04A9.5129AD6D@pacbell.net>
Ron Parker wrote:
> Remind me to check the docs when I get home.
Ron,
Check the docs when you get home.
Ken Tyler
Date: 5 Dec 2000 04:19:29
Message: <3a2cb321@news.povray.org>
Josh English wrote in message <3A2BE07B.9EE186F8@spiritone.com>...
normalizing
thanks. little more about my problem
I play with specialized patch for non-linear deforms
I have builded mechanizm to implement different types of deformations
geometry is supported ok but problem is with normals
first I thought just simple - (un)deform IPoint and IPoint+INormal
and calculate new normal
but this isn't correct -
therefore I discover such method:
find INormal and IPoint
find N points around of IPoint (with very small distance)
points are on flat plane perpendicular to normal
(un)deform points
now they are not on plane
this mean that my virtual smooth triangles are very small
I leave simple averaging normals
real problem will be with inherited nonlinear transformed textures....
ABX
Date: 5 Dec 2000 05:52:46
Message: <3a2cc8fe$1@news.povray.org>
>>were orthogonal.
>were correct.
Hm... it certainly does say "proportional to the angle".  That's a doc bug.
Date: 5 Dec 2000 06:18:37
Message: <3a2ccf0d@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: Of course, if you are using the vcross command to find your
: normals, remember that the length of the resultant vector has a length
: of the dot product, which will be at it's maximum when the vectors are
: orthogonal (ie, 90 degrees apart).
  Actually, the length of the normal vector calculated using cross-product
of two vectors is (also) exactly the area of the parallelogram formed by the
two vectors.
  To get the area of the triangle formed by the two vectors, divide the
length of the cross-product by 2.
Date: 6 Dec 2000 12:09:28
Message: <3A2E72C7.E98DA9C8@spiritone.com>
I thought that the area of the parallelogram was equal to the dot product. I
seem to remember that we were able to find the area with some simple vector
calculation. Too bad my book is at home.
Josh
> two vectors.
Date: 6 Dec 2000 12:37:40
Message: <3a2e7964@news.povray.org>
: I thought that the area of the parallelogram was equal to the dot product.
  Nope.
  For example, the area of the parallelogram formed by the vectors
<1,0,0> and <2,0,0> is 0, but the dot-product of the vectors is 2.
Date: 6 Dec 2000 12:39:22
Message: <3A2E79CA.FED51176@spiritone.com>
I'm pretty sure I read something about this in Calc 3... I'll have to check
tonight when I get home.
Josh
>   Nope.
Date: 6 Dec 2000 12:43:05
Message: <3a2e7aa8@news.povray.org>
: I'm pretty sure I read something about this in Calc 3... I'll have to check
: tonight when I get home.
  The area of the parallelogram is |uxv| (ie. the length of the cross-product
of the two vectors u and v).
Date: 6 Dec 2000 12:57:04
Message: <slrn92svfi.rfu.ron.parker@fwi.com>
Nope, the dot product is more closely related to the projection of one
vector onto another [the length of the projection of b onto a is
vdot(a,b)/vlength(b)].  The length of the cross product is related to
the orthogonal component [the length of the component of b orthogonal
to a is vlength(vcross(a,b))/vlength(a)].
Since the area of a parallelogram is base (length of a) times height
(length of the component of b orthogonal to a) it turns out that the
area of the parallelogram is exactly the length of the cross product.
In my experience, this fact is rarely useful, but the two above often
are.
Date: 6 Dec 2000 13:18:56
Message: <3a2e8310@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: In my experience, this fact is rarely useful
  Perhaps it could be used, as proposed earlier, to calculate the weigthed
average of the normal vectors instead of just the average.
  It makes sense that the normal vector of a larger triangle has more
effect in the normal of the vertex than a smaller triangle.
  Of course doing it this way can result in degenerate triangles, which
is a problem.
Date: 7 Dec 2000 11:19:05
Message: <3A2FB865.A0DF3FC4@spiritone.com>
Thanks, that's what I was able to look up. The scary part was I couldn't find it
on the 'net anywhere, but I wasn't checking anything about the cross product.
I can't wait to teach this stuff, I'll really know it well, then
Josh
Date: 7 Dec 2000 13:01:32
Message: <3A2FD07C.7FA03F08@spiritone.com>
Better Nate than Lever... I have a small explination that hopefully will
help out here:
http://www.spiritone.com/~english/cyclopedia/smooth2.html
As always, send feedback and WTF's via email.
Josh
> for you soon.
> Josh
> > Maybe other way ?
> > ABX
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia http://www.spiritone.com/~english/cyclopedia/
Date: 7 Dec 2000 14:36:13
Message: <3a2fe6ad@news.povray.org>
: Better Nate than Lever... I have a small explination that hopefully will
: help out here:
: http://www.spiritone.com/~english/cyclopedia/smooth2.html
  Note that if you use a weighted average to smooth the triangles, you can
get degenerate triangles. This is a bad problem.
  For example, suppose that you have a triangle with a normal vector
pointing at <0,1,0> and an adjacent triangle with its normal vector pointing
at <1,-1,0>. Let's say that the area of the first triangle is 10 square
units and the area of the second triangle is 1 square unit.
  If we calculate the normal vector of a common vertex using the weighted
average of the triangle normal vectors, it will be:
  <0,1,0>*10 + <1,-1,0>*1 = <1,9,0>
  If you apply that <1,9,0> as the normal vector to a vertex of the second
triangle, it will be degenerate. That's because the angle between the
normal vector of the second triangle and that <1,9,0> vector is larger
than 90 degrees.
  (It can be checked from the dot-product; if the dot-product of the
two vectors is negative, then the triangle is degenerate:
  <1,-1,0>.<1,9,0> = 1*1 + (-1)*9 + 0*0 = -8  )
  By the way: It's interesting to note that this same problem can appear
even if we use the average of the normalized normal vectors of the triangles.
  I have never thoight about that...
  However, I would say that the problem is less probable in the latter case.
Date: 7 Dec 2000 14:37:24
Message: <3a2fe6f4@news.povray.org>
By the way, the link at the beginning of the page is wrong.
  It's not "PovUntils" :)
Date: 7 Dec 2000 16:19:43
Message: <3A2FFEEC.511BBC56@spiritone.com>
> : help out here:
> than 90 degrees.
Thanks for the tip on that. I didn't associate negative dot products with
degenerate triangles. So is it always true that a negative dot product reflects
an obtuse angle?  A cursory check would make it seem that way.
No, sadly, it's not. I got several degenerate triangles, then I changed n to be
5 or 6, it worked, set it back to 4, and it worked. I have no idea why it did
that, though. This was when the normal at the apex of the triangles was along
<0,1,0>.
Josh
Date: 7 Dec 2000 16:20:55
Message: <3A2FFF37.47FE1D19@spiritone.com>
OOPS. I was looking at my bookmarks screen one one machine and typing on the
other....
It's fixed.
By the way, thank you for that read me file, it made my life very easy on
several occasions.
Josh
Date: 8 Dec 2000 07:35:58
Message: <3a30d5ae@news.povray.org>
Warp wrote in message <3a2fe6ad@news.povray.org>...
appear
triangles.
than if this appear for both method (weighted and not)
than consider comparison for proper triangles
(picture sended at p.b.i)
ABX
