POV-Ray : Newsgroups : povray.advanced-users : Keeping objects spaced enough using Array? Server Time
21 Mar 2026 00:15:31 EDT (-0400)
  Keeping objects spaced enough using Array? (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Keeping objects spaced enough using Array?
Date: 25 Mar 2002 05:06:10
Message: <3c9ef692@news.povray.org>
Actually, the following at least seems to work.  Of course, I have not checked
if it doesn't corrupt any internal data:
    #declare foo = array[40];
    #declare foo[1] = array[10];
    #declare foo[2] = array[5];
    #declare foo[1][5] = 5.0;
As far as I can tell this is, together with the ability to undef arrays
sufficient to build linked structures...
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Mar 2002 05:32:10
Message: <22vt9u8jvqkto0feosejmc6chmierd8lqm@4ax.com>
On Mon, 25 Mar 2002 10:45:41 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> Actually, this implies it isn't possible to make an array (of arbitrary size,
> of course) an element of another array, or is this possible?  I have to admit
> I never tried, but from the code I cannot really see a reason why it shouldn't
> be possible other than as being a yet another parser limitation...
something related
http://news.povray.org/6lpkut0vdh0h6gljr7u2v4mip6olddkmel%404ax.com
ABX
Date: 25 Mar 2002 05:44:46
Message: <3c9eff9e@news.povray.org>
In article <3c9ef692@news.povray.org> , "Thorsten Froehlich" <tho### [at] trfde>
For example:
#declare treeroot = array[3];
#declare rd = seed(1);
#macro randfilltree(node, i)
 #declare node[2] = array[1];
 #declare node[2][0] = rand(rd) * 1000 + 10;
 #if(i > 0)
  #if(rand(rd) > 0.1)
   #declare node[0] = array[3];
   randfilltree(node[0], i - 1)
  #if(rand(rd) > 0.1)
   #declare node[1] = array[3];
   randfilltree(node[1], i - 1)
#macro dumptree(node)
 #debug " ("
 #debug str(node[2][0], 0, 0)
 #if(defined(node[0]))
  dumptree(node[0])
 #if(defined(node[1]))
  dumptree(node[1])
 #debug ")"
#macro findmaxtree(node)
 #if(defined(node[0]) & defined(node[1]))
  max(node[2][0], findmaxtree(node[0]), findmaxtree(node[1]))
 #else
   max(node[2][0], findmaxtree(node[0]))
  #else
    max(node[2][0], findmaxtree(node[1]))
   #else
    0
randfilltree(treeroot, 6)
#debug str(findmaxtree(treeroot), 0, 0)
dumptree(treeroot)
Date: 25 Mar 2002 05:52:54
Message: <3c9f0186@news.povray.org>
>> shouldn't be possible other than as being a yet another parser limitation...
> something related
> <http://news.povray.org/6lpkut0vdh0h6gljr7u2v4mip6olddkmel%404ax.com>
Yes, exactly!  I was sure it couldn't be a new idea, but somehow few people
have discovered everything possible with arrays yet.
BTW, when building trees recursively there is always the macro recursion
limit, but trees with a height of 98 are either very big or not well balanced
anyway...
    Thorsten
Date: 25 Mar 2002 06:39:07
Message: <0k2u9uso8jitmnmjc9v6dusa75e6f9v5hr@4ax.com>
On Mon, 25 Mar 2002 11:52:53 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> anyway...
But even then there is a workaround - iteration instead of recursion with
stack placed in another array. Operations on stack can be realised via
Resize_Array macro. This method works fine in my recent implementation in
IC_Text addition for iso_csg library.
ABX
Date: 25 Mar 2002 06:52:31
Message: <3c9f0f7f@news.povray.org>
Yes, but I am not sure it is possible to access an array with an arbitrary
number of dimensions this way.  Take a look at the example macros I posted.
They all depend on passing of array elements that are arrays...
    Thorsten
Date: 25 Mar 2002 08:28:30
Message: <slrna9u9fv.804.ron.parker@fwi.com>
On Mon, 25 Mar 2002 10:45:41 +0100, Thorsten Froehlich wrote:
> In article <slr### [at] fwicom> , Ron Parker
><ron### [at] povrayorg>  wrote:
>> It wouldn't be any slower than a regular binary tree, but it would have a
>> limit on the maximum depth, it would take up more storage than absolutely
>> necessary, and it couldn't be balanced.
I didn't mean to imply that.  What I was saying was that using an array to
represent the tree directly using the scheme I mentioned limits the depth
to a maximum, unless you want to spend lots of time enlarging the array.
However, I think perhaps we could add a few lines to Parse_Array_Declare to
allow syntax like this to enlarge an array more quickly:
#declare A=array[5] {1, 2, 3, 4, 5}
#declare B=array[10] A
or maybe something a little more attractive...
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 25 Mar 2002 08:35:10
Message: <jn9u9uo9g7bl033h4rbmirfboekqpaon00@4ax.com>
That's not fair for other feature requests ;-)
( there are lines
  //#macro Insert_In_Array(Item, DestArray, Index)
  //#macro Insert_Array_In_Array(ItemArray, DestArray, Index)
  //#macro Append_To_Array(Item, DestArray, Index)
  //#macro Append_Array_To_Array(ItemArray, DestArray, Index)
in arrays.inc I'm working on)
ABX
Date: 25 Mar 2002 08:43:27
Message: <slrna9uac1.804.ron.parker@fwi.com>
Don't worry; it's not likely to happen anyway.  I haven't even had time
lately to work on the bugs I've agreed to take on.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 25 Mar 2002 09:11:18
Message: <3c9f3006@news.povray.org>
> Resize_Array macro.
  The problem with using Resize_Array() is that it defies the whole purpose
of using binary trees. The main reason of using trees is that adding,
removing and searching values are all O(log n) operations, which makes it
awesomely fast.
  However, if you have to recurr to Resize_Array(), you are making it O(n),
which effectively destroys its speed benefits.
