POV-Ray : Newsgroups : povray.advanced-users : Using images in density-medias? Server Time
17 May 2025 21:29:29 EDT (-0400)
  Using images in density-medias? (Message 1 to 10 of 14)
Subject: Using images in density-medias?
Date: 5 Feb 2002 13:58:06
Message: <3C602B2E.39A4AA9F@gmx.de>
I wanted to create an emission-media which actually uses
an image as base, simulating a glowing image.
Before, all I did, was use image-map right inside
the density-statement, but I don't get it to work.
Anyone know how to?
Tim Nikias
Subject: Re: Using images in density-medias?
Date: 5 Feb 2002 14:04:10
Message: <3c602caa@news.povray.org>
Already tried image_pattern?
Date: 5 Feb 2002 14:12:09
Message: <MPG.16ca4ce65d03bb809896da@news.povray.org>
In article <3C602B2E.39A4AA9F@gmx.de>, tim### [at] gmxde says...
What exactly was the problem? When I tried this some time ago it worked
without probs.
Lutz-Peter
Date: 5 Feb 2002 14:17:02
Message: <3C602F9E.846E21E2@gmx.de>
I only get a gray-scale image then.
Tim Nikias
Date: 5 Feb 2002 14:18:00
Message: <3C602FD7.A4A4928@gmx.de>
> without probs.
It returns error message and points at the image_map statement inside
the density.
Some time ago, this way worked for me as well...
I'm stuck!
Tim Nikias
Date: 5 Feb 2002 14:28:41
Message: <MPG.16ca50b3e22f3aa69896db@news.povray.org>
In article <MPG.16ca4ce65d03bb809896da@news.povray.org>, lpv### [at] gmxde
says...
> without probs.
Oh, I just tried re-render it, and it didn't work anymore.
So propably i created that one in MegaPov...
However, using image_pattern or a function makes it work but without
color, so you will have to use 3 medias (one for each color component).
Is there a reason why Pov 3.5 doesn't accept an image_map inside a
density?
Lutz-Peter
Date: 5 Feb 2002 14:33:19
Message: <3C60336F.830840EF@gmx.de>
Thanks for your testing, but I guess I'll have to stick to a "normal"
image (not glowing).
Also, while testing, I've found that using a contrast-adjusted and
shadow-midtone-highlight-adjusted image, I can achieve something
pretty realistic.
It was meant for a dark room, without much light, and the adjustments
to the image-map made if appear more like an in-scene radiosity-affected
image-map (though it isn't, of course).
I'll post a version of that on my homepage WIP sometime this night.
Tim Nikias
Date: 5 Feb 2002 15:31:55
Message: <3c60413a@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote:
:>   Already tried image_pattern?
: I only get a gray-scale image then.
  It's difficult to tell what is wrong without seeing any code.
Date: 5 Feb 2002 16:33:04
Message: <3c604f8f@news.povray.org>
  Same case here... I used it on my IRTC entry for "LABORATORY", but that
was MegaPOV. I don't know right now if it was posible with 3.1, but I
doon't think so. Anyhow, I don't remember to have seen this specified as a
MegaPOV feature.... hmmmm.
  Indeed, this was very handy for "luminous" objetcs with global ambient
set to 0.... I'm also curious about why this does not work on 3.5. Must
investigate...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 5 Feb 2002 16:40:24
Message: <3C605138.2B584D4C@gmx.de>
In basic, its like this:
object{ Area hollow pigment{rgbt <0,0,0,1>}
 interior{media{emission 1 intervals 1 method 3 samples 1,5
 density{image_map{tga "image.tga"} translate -.5 /*centers the image*/}
It does create some sort of emission, based on the calculated grayness
of a colored pixel, but the colors get lost. That's not the behaviour of
POV-Ray 3.1g, and probably MegaPOV (I don't use MegaPOV).
Tim Nikias
