POV-Ray : Newsgroups : povray.advanced-users : Photon Questions again! Server Time
17 May 2025 20:42:35 EDT (-0400)
  Photon Questions again! (Message 1 to 3 of 3)
Subject: Photon Questions again!
Date: 26 Jan 2002 05:41:57
Message: <3C5287D5.4779A2D0@gmx.de>
I'm not sure if this is the right group to post this in, but I'll
apologize if need arises and post to the correct group...
So, I was wondering, what exactly are photons internally?
Small lightsources or something like "glows" from MegaPOV,
which only brighten up the places without actually doing
lighting? And are photons interpolated in 3D-Space, but
wrapped onto surfaces, or what?
I was just wondering about a late image I made, and the strange
speckle sizes the photons appeared to have. And while wondering
about that, I though one could maybe create a SDL Photon
lightmapper using trace and lightsources...
Well, I'll wait and see what happens with this post... ;)
See ya,
Tim
Tim Nikias
Subject: Re: Photon Questions again!
Date: 26 Jan 2002 06:17:20
Message: <r3355ukoo0almj4qv2dqit52n5kb3ggjss@4ax.com>
On Sat, 26 Jan 2002 11:41:25 +0100, Tim Nikias <tim### [at] gmxde>
Internally, each photon has a location, a color, an intensity, and
also remembers the direction it came from (and some info for the
octree).
>lighting?
Lightsources are more like it.
They reside in 3D space. They can even reside in media if you tell
them so. Lightmapping is used in pure radiosity (i.e. not monte carlo)
calculations and is a completely different beast.
A case of parameter tuning, I believe.
>And while wondering about that, I though one could maybe create
>a SDL Photon lightmapper using trace and lightsources...
Yes, it can be done. And it will be dreadfully slow, if POV doesn't
run out of memory building the light buffers.
I had the exact same idea quite some time ago (before I discovered
these newsgroups) - using virtual lightsources to model caustics. It
turned out that someone has invented the wheel already as this was how
Radiance (I think) included mirroring surfaces in radiosity
calculations. Alas, my programming skills were not sufficient by far
at the time so I only got to coding the parsing and put it off. I'm
glad I did as Nathan kame up with UVPOV soon after that and all my
efforts would have been in vain if I had not :)
Anyway, back to your question, you could simulate reflective photons
using point lights with a small fade_distance (although photons do not
fade themselves there's no other way to localize their effect). You'll
need some crazy light_grouping but it might as well work. I think
using spotlights will be a better choice, though, as you'll be able to
localize the effect in a more controllable fashion.
Hope I'm making some sense so early in the morning (1:15 pm :) ).
Peter Popov ICQ : 15002700
Date: 27 Jan 2002 04:03:18
Message: <3c53c256@news.povray.org>
Naa ... I think it's ok here. It's "quite" advanced, but
you can apologize, for not looking "a bit" on the typical
websites, where POVers expect this stuff to be written...
would you mind reading http://nathan.kopp.com/photons.htm ?
If you have still questions, post again ?
[Talking about cardriving]
"People are opstacles?
Oh...I always treat them as bonus points..." [Ian Burgmyer in p.o-t]
// Jan Walzer <jan### [at] lzernet>
