POV-Ray : Newsgroups : povray.advanced-users : need help with threads (for bolts & such) Server Time
19 Oct 2024 11:25:41 EDT (-0400)
  need help with threads (for bolts & such) (Message 1 to 5 of 5)
Subject: need help with threads (for bolts & such)
Date: 6 Dec 2000 14:01:39
Message: <c03t2ts9rc1r7ar0n3f5deje6aoh5pkmmb@4ax.com>
Somewhere, long ago, I seem to recall seeing a macro for creating
threads.  Now that I'm working on something with threaded parts, I
can't find it and my own attempts at threading just don't work.
Anybody have some ideas?
Defective O-O
http://members.home.com/redundant/Defective/
(yes, I know that's the wrong membername...ran out of space at
http://members.home.com/defective/)
Subject: Re: need help with threads (for bolts & such)
Date: 6 Dec 2000 14:13:08
Message: <3A2E9090.613232D7@pacbell.net>
http://www.ica.uni-stuttgart.de/~marc/bolts.html
http://www.ica.uni-stuttgart.de/~marc/nuts.html
Date: 6 Dec 2000 17:13:31
Message: <chrishuff-398EA9.17141706122000@news.povray.org>
In article <c03t2ts9rc1r7ar0n3f5deje6aoh5pkmmb@4ax.com>, Defective
Well, I can't help with the macro, but threads are usually done with
either a triangle mesh, a CSG with lots of small objects chopping away
at or adding to a larger one in a spiral, or by using the parametric or
isosurface objects in MegaPOV.
Using a parametric or isosurface would be the most memory efficient
method, and can give smooth results. They can be slow, but that wouldn't
be a problem unless the threaded part covers a large area of the final
image.
It can be hard to get smooth shapes with the CSG technique, you have to
use a large number of shapes to get it right, and it can be slow and
memory consuming.
Meshes could be pretty fast and could be generated automatically with a
macro, but can have visible "facets" if you don't use a high enough
resolution, and can't be used in CSG (using CSG with meshes works in
MegaPOV, but it isn't very reliable yet). Though they can use a lot of
memory, copies of a mesh can use very little additional memory, because
they can share data. Because screws and bolts have a very repetitive
shape, a macro could make a basic "thread" shape like a short segment of
a bolt, and use groups of these scaled and translated to make the actual
screws/bolts very efficiently. That way, there would only be one basic
"building block" that all the bolts in the scene could be constructed
from, possibly saving a lot of memory.
Christopher James Huff
Date: 7 Dec 2000 03:57:30
Message: <k0ku2t8ggo8c4k1hpde3390fcj5i4lp6rb@4ax.com>
On Wed, 06 Dec 2000 11:16:32 -0800, Ken <tyl### [at] pacbellnet>
blathered:
hhhmmm...
Looks promising...gonna download those & see how well they work.  With
luck, I can eliminate the head and make threaded rod too...
Thanks
Defective O-O
Date: 7 Dec 2000 04:08:21
Message: <q5ku2tofjd2okpfkl8jbee3ncmrt5k21kt@4ax.com>
On Wed, 06 Dec 2000 17:14:17 -0500, Chris Huff <chr### [at] maccom>
blathered:
Threaded objects I'm building need to be part of CSG objects.  So this
rules out meshes.  CSG could be ok, that's what I've been trying with.
(just my clumsy coding may be the problem...)
>image.
Isosurface sounds promising, I'm already using an isosurface supplied
by David Wilkinson for the expanded steel parts.
>memory consuming.
This is part of why I gave up on my attempts so far...test renders
taking forever...
Like I said above...need to be able to put them in CSGs...bummer...
Defective O-O
