POV-Ray : Newsgroups : povray.advanced-users : Bamboo Server Time
20 Jan 2025 03:57:02 EST (-0500)
  Bamboo (Message 1 to 6 of 6)
Subject: Bamboo
Date: 4 Dec 2000 05:12:25
Message: <3A2B6DD2.992503A1@worldonline.nl>
Has anyone ever created a bamboo texture? I'm creating a scene in which
I use several sticks of bamboo and could use some hints and tips on the
creation of the bamboo texture.
Rob.
Subject: Re: Bamboo
Date: 4 Dec 2000 09:49:47
Message: <3A2BAF0D.B5FFCD89@gmx.de>
Rob Verweij wrote:
> Hi,
> Rob.
There are a lot of different types of bamboo, a lot of them have some kind
of gradient structure (resulting in 'rings' across the length)
You could use a gradient pattern for simulating this but remember the
geometry changes similar to the texture, so you should consider putting
the plant together from different individually textured elements.
Subject: Re: Bamboo
Date: 4 Dec 2000 13:29:46
Message: <3A2BE294.25480FF@spiritone.com>
I found some pictures here :
http://pw1.netcom.com/~rdlewis1/plants.html
and it looks like a macro creates several segments should work well. To
fake one stalk of bamboo, I would create a long tall cylinder along the y
axis and use a gradient y pigment, with a scallop wave, so the first parts
of the color map are the brownish segments, then the yellow or green takes
up most of the color map. Then you might want to add another texture with
another pattern that is partially to totally transparent.
Good hunting, and please share your findings ; )
Josh
Rob Verweij wrote:
> Hi,
> Rob.
eng### [at] spiritonecom
Subject: Re: Bamboo
Date: 4 Dec 2000 15:57:52
Message: <chrishuff-A185C9.15583504122000@news.povray.org>
In article <3A2B6DD2.992503A1@worldonline.nl>, Rob Verweij
Not an answer to your question, but isosurfaces seem just perfect for
doing the geometry of bamboo stalks...the texture would be fairly simple.
Christopher James Huff
Subject: Re: Bamboo
Date: 5 Dec 2000 11:18:03
Message: <3A2D1503.39FC1395@worldonline.nl>
Thanks, I'll look into it.
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Subject: Re: Bamboo
Date: 9 Dec 2000 10:11:03
Message: <v8f43tgml38hg2tc60h47f85c63nqj6hlp@4ax.com>
Try this function in an isosurface:
sqrt(3*cos(x/5))+y^2+z^2-10}
I can't remember if it was good.. It's from a little library I have of
functions discovered by chance. It might get you started at least.
sig
ICQ 74734588
